Reading: DCS Alarm Summary Dashboard using Microsoft Power BI
Inst Tools > Blog > Control Systems > DCS Alarm Summary Dashboard using Microsoft Power BI
I’ve developed this Alarm Summary Dashboard using Microsoft Power BI which visualizes DCS alarms for a healthy control system environment.
Last updated: February 28, 2024 2:57 pm
Control Systems
ICS – Industrial control system is the backbone of a process or plant. It involves operation components like open loops, closed loops, 3rd party communications, and critical parameters like fire & gas, ESD trips & shutdowns.
Operator interaction with operator station is focused on all above components’ operating & monitoring. Monitoring important parameters is a higher priority to maintain balance in the entire process establishment at the primary level.
Though panel operators are habited for quick response over parameter ups & downs, during process abnormality they can handle it very well, but each parameter variation may cause alarm flooding on the operator station.
Due to the flooding, the panel operator may miss some of the important alarms during process abnormality & it may increase the risk from small-scale to high scale production loss as well as big disaster causing financial as well as human life loss.
To maintain alarm generation, EEMUA 191 standard was published in 1999 and it is globally accepted for good practice of alarm management or can say alarm rationalization.
I’ve developed this Alarm Summary Dashboard using Microsoft Power BI which visualizes DCS alarms which is helpful to manage/rationalize alarms & make a healthy control system environment. Microsoft Power BI is a single-page visualization to explain a scenario.
The visualizations on a dashboard are generated from the dataset which is imported from in various formats such as Excel, CSV, SQL, or Web URL. DAX functions in Power BI make visualization more powerful, effective & time-saving.
Here in this dashboard, we can import DCS alarms in excel or CSV format in Power BI and it will represent each visualization as per data imported. In this dashboard you can have:
  • Alarm count summary: Total alarms, Alarms per 10/5/1 minute, ESD alarms & NC Alarms (Not connected/off-display alarms)
  • Alarm counts by source controller
  • Top 10 tags from alarms
  • Alarm category type pie chart
  • Alarm count plot of 24 hours
The most interesting thing is the dashboard is user interactive. It means it reacts as per filter selection on the dashboard. For example, if you select any alarm type from the filter available on the right bottom corner, it will refresh & represents alarm counts, controller, top 10 tags, 24 hours plot & pie chart.
Using this user interactive alarm dashboard, you can analyze alarms generation based on process parameter variation/deviation, loop issues, unnecessary alarms, field equipment error, repetitive alarms, logical errors, the recovery rate of parameter, process interlocks, Realtime-based alarm counts & most/least count of tags which as generating alarms.
This saves a lot of time of analyzing alarms and plan alarm rationalization in the most meaningful way (for both maintenance & production team) to maintain EEMUA 191 standard resulting in better process stability, and so better performance of ICS by decreasing load on the controller as well as ICS network by removing unnecessary alarm flooding.
In addition, I’ve prepared this dashboard in a dark mode which is a famous trend for user interface nowadays.
Thanks to Microsoft for such a powerful tool ‘Power BI’
(Year, Tags & controllers in the image are hidden to respect the data privacy)
I hope this may be helpful for you & your feedback will be appreciated, it will be helpful for my upcoming article contribution.
Author: Sanjay Mistry
  • PLC Alarm Acknowledge
  • Categorization of Alarms
  • What is Alarm Prioritization?
Capacitive Coupling Effects
Alarm and Trip Systems
Control Systems Interview Questions & Answers
Control System Architecture
Cascade Control Principle
4-wire Transmitters Current Loops
Overview of PID Control terms
Understanding a Process Control Loop
Centralized vs Decentralized Automation Systems
DCS Program to Maintain Draft in Furnace
Design & Construction of Process Plant
Two wire loop powered transmitters
SinkingOutput
Difference Between the Sinking and Sourcing?
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Control Sytem Open Loop and Closed Loop
Introduction to Control System
Hook-up Diagram for Pressure Gauge
What is Instrument Hook Up Diagram ?
Find the Fault in the Temperature Loop
Pressure instruments example circuit
Motion-Balance and Force-Balance Instruments
Power Supply Voltage Regulator Problem
Troubleshooting a Power Supply Circuit
Masking in PLC
What is Masking in PLC?
Magnetic Wind Instruments Questions & Answers
Flange Types and Definitions
Snubber Circuits
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
High Integrity Pressure Protection System HIPPS
Overview of HIPPS System
Electric Circuits Objective Questions – Set 14
