Reading: DC Generator Internal Losses
Inst Tools > Blog > Electrical Theory > DC Generator Internal Losses
Last updated: July 27, 2018 11:25 pm
Electrical Theory
3 Min Read
There are four internal losses that contribute to lower efficiency of a DC generator.
  • Copper losses
  • Eddy-current losses
  • Hysteresis losses
  • Mechanical losses
Copper Losses
Copper loss is the power lost as heat in the windings; it is caused by the flow of current through the coils of the DC armature or DC field. This loss varies directly with the square of the current in the armature or field and the resistance of the armature or field coils.
Armature : Ia2 Ra
Field : If2Rf
Eddy-Current Losses
As the armature rotates within the field, it cuts the lines of flux at the same time that the copper coils of wire that are wound on the armature cut the lines of flux. Since the armature is made of iron, an EMF is induced in the iron, which causes a current to flow. These circulating currents within the iron core are called eddy-currents.
To reduce eddy-currents, the armature and field cores are constructed from laminated (layered) steel sheets. The laminated sheets are insulated from one another so that current cannot flow from one sheet to the other.
Hysteresis Losses
Hysteresis losses occur when the armature rotates in a magnetic field. The magnetic domains of the armature are held in alignment with the field in varying numbers, dependent upon field strength. The magnetic domains rotate, with respect to the particles not held in alignment, by one complete turn during each rotation of the armature. This rotation of magnetic domains in the iron causes friction and heat. The heat produced by this friction is called magnetic hysteresis loss.
To reduce hysteresis losses, most DC armatures are constructed of heat-treated silicon steel, which has an inherently low hysteresis loss. After the heat-treated silicon steel is formed to the desired shape, the laminations are heated to a dull red and then allowed to cool. This process, known as annealing, reduces hysteresis losses to a very low value.
Mechanical Losses
Rotational or mechanical losses can be caused by bearing friction, brush friction on the commutator, or air friction (called windage), which is caused by the air turbulence due to armature rotation. Careful maintenance can be instrumental in keeping bearing friction to a minimum.
Clean bearings and proper lubrication are essential to the reduction of bearing friction. Brush friction is reduced by assuring proper brush seating, using proper brushes, and maintaining proper brush tension. A smooth and clean commutator also aids in the reduction of brush friction.
Synchronous Motors
DC Motor Theory
Electrical System Components and Protection Devices
Block Diagram
Y and Delta Resistor Network Calculations
Magnetism
  • Rabson phiri says:
    July 21, 2019 at 9:11 pm
    That’s good
Classification of Transformers
Series-Wound Motor
Discharge and Charging of Lead-Acid Battery
Battery Hazards
Power Factor
Types of AC Generators
Batteries Theory
Series-Wound DC Generators
Chemical Battery
Batteries
Electric Open Circuit
Series Open Circuit Faults
Moving Iron Vane Meter Movement
Calculate Power in Series RL Circuit
Total Resistance in a Parallel Circuit
Resistance in Parallel Circuits
DC Generator
DC Generator
Power Triangle
Apparent Power, True Power, Reactive Power & Total Power
Types of Batteries
Types of Batteries
PLC Program with 2 Toggle Switches and 4 Motors
Measurement and Calibration Objective Questions and Answers
Control Panel Instruments
Control Panel Instruments Problem Threatened Plant Shutdown
Vibration Monitoring System Troubleshooting
Vibration Monitoring System Step by Step Troubleshooting Guide
Optimal Control Systems
Remote Diaphragm Seal Transmitter for Vacuum Application
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
Inductive proximity switches
How to Connect Proximity Switch (Source Type) to Make LED ON ?
