Reading: Conveyor Speed Logic using Structured Text in PLC
Inst Tools > Blog > PLC Tutorials > Conveyor Speed Logic using Structured Text in PLC
In this article, we will see how to write a conveyor speed control logic using structured text language in PLC controller.
Last updated: October 7, 2024 4:15 pm
Whenever a PLC programmer starts to develop logic, the first thing he faces is which language to select. As there are five languages in PLC programming, choosing the right one according to your requirements is necessary for easy understanding.
Conveyor Speed LogicStructured Text in PLC
Structured text is a language which is high-level and used by many programmers for complex calculations and algorithms. One of the general logic used in many systems is conveyor speed control. In this post, we will see how to write a conveyor speed control logic using structured text language.
First, let us see the test bench criteria and condition of the logic. As soon as the start button is pressed, the conveyor will start. When the stop button is pressed, the conveyor will stop.
When the conveyor is running, a three-speed selector switch will be taken into consideration. It will be an analog input with a preset speed of 10%, 40% and 80%.
Corresponding to this, the actual PLC input in raw counts will be 5, 20, and 40. Whichever speed input is received, the speed target percentage will be moved to the analog output of the conveyor speed reference.
When the conveyor is not running, then the speed too will be zero.
Now that we have seen the question, let us come up with an answer using structured text language. Refer to the below image for the logic written.
We have used two inputs – start and stop push buttons, one output – logic running, one analog input – for speed input, and one analog output – for speed reference.
Now, let us start developing the PLC logic. As per the first condition, when we press start, the conveyor turns on and when we press the stop button, the conveyor turns off. So, we have used an if statement. If the start push button is received, then the conveyor will run; and when the stop button is received, then the conveyor will stop.
[For comparing, “=” is used and for assigning a value, “:=” is used. Each statement needs to be terminated by a semicolon and a preceding word – “END_IF”. Semicolon does not come in the condition; it comes in the assignment statement. Refer to the image for more understanding.]
Now, when the conveyor is running, we use the analog input as speed input. In the field side, it is a 3-way selector switch. At the first position, a raw count of 5 is received in the input. At the second position, a raw count of 20 is received in the input. At the third position, a raw count of 40 is received in the input.
For simplicity and shortcuts, we use case statements. As the name implies, it takes the case number of the analog input. So, when the number is 5, we move a value of 10 in the analog output. When the number is 20, we move a value of 40 in the analog output. So, when the number is 40, we move a value of 80 in the analog output.
As per the last condition of the question, by pressing the stop button, the speed should be zero. So, on this input, we have reset the conveyor output bit and also moved the value ‘0’ in the analog output. This is written in the else statement. This means, if the conveyor is running, then move analog speeds, else move zero.
In this way, we have seen the conveyor speed logic using structured text.
  • Difference Between PLC and CNC Machine
  • PLC Conveyor Ladder Logic Programming
  • AI, AO, DI, DO Questions (PLC I/O Types)
  • Global Acknowledgment in Safety PLC Logic
  • How to Detect Speed of Conveyor in PLC?
PLC Programming for Baking with Auto and Manual Modes
PLC based Auto/Manual Operation of Roll down Shutters in Industry
Parts of PLC
Basic PLC Alarm Programming Example
PLC Brands Software Information
How to Choose the Right Industrial Automation Solution?
Tia Portal – OB30 Cyclic Interrupt Organization Block
Features of Scada Which are Must in an IoT System
PLC Program for Flow Totalizer
Functions of SCADA
How to Solve Electrical Ground Loop Problems?
Difference Between FC and FB in Tia Portal
Motor Feedback Fail Logic in PLC
Current to Voltage Conversion Circuit
How to Convert Current to Voltage using Resistor ?
Failsafe interlock Design
Failsafe Wiring Practices
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
OFF Delay Timer using PLC
How-to do Security of SCADA Systems
How-to do Security of SCADA Systems?
PLC Program for Controlling Sequence of Conveyors with Interlocking
PLC Ladder Logic Example
PLC Tag Naming Conventions
De-energized Electrical Circuits
De-energized Electrical Circuits, Networks, and Equipment
Turbine and Compressor Control System
Induction Motor Rotor Frequency
Machine Learning
Difference Between Machine Learning and Artificial Intelligence?
Dual Solenoid Valve on Control Valve
Why we Require Dual SOV on a Control Valve?
Advantages of Pneumatic Systems in the Automotive Industry
Displacement Level Transmitter in situ calibration
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
