Reading: Components of Bourdon Tube – Questions and Answers
Inst Tools > Blog > Instrumentation MCQ > Components of Bourdon Tube – Questions and Answers
Study the components of the Bourdon tube pressure gauge with the questions and answers about the construction, and working principles.
Last updated: July 24, 2024 2:52 pm
Instrumentation MCQ Pressure Measurement
8 Min Read
Components of Bourdon TubeWhat component of a Bourdon tube gauge converts tube deformation into needle movement?Which part of the Bourdon tube gauge typically houses the Bourdon tube itself?What material is commonly used to manufacture Bourdon tubes for general pressure measurement?How does the Bourdon tube respond to internal pressure changes?What is the primary function of the pinion gear in a Bourdon tube pressure gauge?Which component directly interacts with the Bourdon tube to initiate needle movement?In a Bourdon tube pressure gauge, what component is crucial for protecting the gauge from overpressure?What is the role of the spiral spring in a Bourdon tube pressure gauge?Which part ensures the dial and needle are securely held in place within the Bourdon tube gauge?What does the pointer do in a Bourdon tube pressure gauge?What is the primary purpose of the dial on a Bourdon tube pressure gauge?How does the rotating spindle contribute to the function of a Bourdon tube pressure gauge?What component in a Bourdon tube pressure gauge helps prevent damage from sudden pressure spikes?In a Bourdon tube gauge, what is the function of the Bourdon tube itself?Which part of the Bourdon tube pressure gauge connects the Bourdon tube to the dial mechanism?What type of Bourdon tube is used for high-pressure measurements?Which component ensures the Bourdon tube returns to its original shape after pressure is released?What is the role of the relief valve in a Bourdon tube pressure gauge?What material is often used for the dial of a Bourdon tube pressure gauge to enhance readability?Which component of a Bourdon tube pressure gauge helps reduce mechanical wear?What is the primary material used for the gears in a precision Bourdon tube pressure gauge?How does the mounting flange contribute to the functionality of a Bourdon tube pressure gauge?In what form is the Bourdon tube typically shaped to measure pressure?What component of the Bourdon tube pressure gauge provides the necessary calibration marks?Which component ensures the Bourdon tube returns to its original position after pressure decreases?What type of Bourdon tube is best suited for low-pressure measurements?How does the bezel enhance the functionality of a Bourdon tube pressure gauge?Which component of a Bourdon tube pressure gauge is responsible for translating pressure into motion?
You will find the detailed explanations for each objective question about the bourdon tube in the below video.
Bourdon Tube Pressure Gauge (Components) - Instrument Questions
Question 1
A. Rotating spindle
B. Link and lever mechanism
C. Spiral spring
D. Pinion gear
Show the Answer
Question 2
A. Case
B. Dial
C. Link and lever
D. Rotating spindle
Show the Answer
Case
Question 3
A. Stainless steel
B. Aluminum
C. Copper
D. Titanium
Show the Answer
Stainless steel
Question 4
A. Expands axially
B. Contracts radially
C. Twists longitudinally
D. Bends outward
Show the Answer
Bends outward
Question 5
A. Amplify tube deformation
B. Reduce mechanical friction
C. Transmit needle movement
D. Protect internal components
Show the Answer
Question 6
A. Dial
B. Helical spring
C. Rotating spindle
D. Link
Show the Answer
Link
Question 7
A. Relief valve
B. Spiral spring
C. Snubber
D. Overrange protector
Show the Answer
Overrange protector
Question 8
A. Maintain constant pressure
B. Stabilize the needle movement
C. Transmit pressure to the Bourdon tube
D. Indicate pressure reading
Show the Answer
Question 9
A. Dial holder
B. Pressure chamber
C. Mounting flange
D. Bezel
Show the Answer
Bezel
Question 10
A. Displays the pressure reading
B. Stabilizes the internal pressure
C. Converts pressure to mechanical motion
D. Protects the tube
Show the Answer
Question 11
A. Protect internal components
B. Indicate the pressure reading
C. Stabilize the needle movement
D. Secure the Bourdon tube
Show the Answer
Question 12
A. Amplifies pressure signals
B. Transmits needle movement
C. Reduces friction in the system
D. Protects internal components
Show the Answer
Question 13
A. Damping device
B. Relief valve
C. Snubber
Show the Answer
Snubber
Question 14
A. Generate electrical signals
B. Convert pressure into mechanical motion
C. Protect the internal components
D. Indicate the pressure reading
Show the Answer
Question 15
A. Link
B. Bezel
C. Spiral spring
D. Relief valve
Show the Answer
Link
Question 16
A. Helical Bourdon tube
B. C-type Bourdon tube
C. Diaphragm Bourdon tube
D. Spiral Bourdon tube
Show the Answer
Question 17
A. Dial
B. Spiral spring
C. Lever mechanism
D. Snubber
Show the Answer
Spiral spring
Question 18
A. Protect against overpressure
B. Amplify the pressure reading
C. Indicate the accurate pressure
D. Stabilize needle movement
Show the Answer
Question 19
A. Aluminum
B. Brass
C. High-impact plastic
D. Polycarbonate
Show the Answer
High-impact plastic
Question 20
A. Bezel
B. Spiral spring
C. Helical tube
D. Damping device
Show the Answer
Damping device
Question 21
A. Plastic
B. Steel
C. Brass
D. Aluminum
Show the Answer
Brass
Question 22
A. Provides a secure installation
B. Enhances pressure measurement
C. Protects internal components
D. Reduces mechanical wear
Show the Answer
Question 23
A. Spiral
B. Helical
C. C-shape
D. Linear
Show the Answer
C-shape
Question 24
A. Link
B. Pointer
C. Dial
D. Case
Show the Answer
Dial
Question 25
A. Spiral spring
B. Link
C. Bezel
D. Dial
Show the Answer
Spiral spring
Question 26
A. Helical tube
B. Spiral tube
C. Diaphragm tube
D. C-type tube
Show the Answer
C-type tube
Question 27
A. Reduces internal friction
B. Protects the dial and pointer
D. Amplifies pressure readings
Show the Answer
Question 28
A. Dial
B. Bourdon tube
C. Pointer
D. Spiral spring
Show the Answer
Bourdon tube
  • Bourdon Tube Gauge Animation
  • Identify the Pressure Gauge Error
  • Bourdon Gauge Spiral Spring
  • Pressure Gauge Dial Full Details
  • Pressure Gauge Accessories
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Quiz on Sensor Transducer
Pressure Measurement using Manometer
Beam Balance Systems Objective Questions
What is Static Pressure Limit in DP Transmitter ?
How to Prepare Pressure Gauge Datasheet ?
The Principle of Dead Weight Pressure Tester
Top 100+ SCADA Questions
Inverse Transducers Objective Questions
Process Pressure Measurement Objective Questions
5 Valve Manifold Operation
Functions of Pressure Detectors
Fiber Optic Sources and Detectors Questions and Answers
Valves MCQ
Valves MCQ
Gyroscope Objective Questions
Gauge Cock
Pressure Gauge Cocks
Compression load cell Principle
Types of Load Cells
Measurement of Errors Objective Questions
Recording Systems Objective Questions
Pressure Transmitter Circuit
Dataloggers Objective Questions
Data Loggers Objective Questions
Retro-Reflective Sensor
Thermal Protection Relay Testing and Commissioning
Testing of Thermal Protection Relay for Motors
Flow Measurement Quiz
Flow and Level Measurement Quiz
What is a Dosing Pump? - Types, Advantages, Applications
What is a Dosing Pump? – Types, Advantages, Applications
Differential Pressure Switch Calibration Procedure - Copy
Electrical Welding Multiple Choice Questions and Answers
Electrical Welding Multiple Choice Questions and Answers (MCQ)
Moisture and Dew Point Analyzer Problems
Moisture and Dew Point Analyzer Problems and Troubleshooting Tips
HART
List of Tools used by Instrument Technician or Engineer
