Reading: Classification of HVAC Chillers
Inst Tools > Blog > Common > Classification of HVAC Chillers
In this post, we will learn the various type of chillers used in HVAC. Chiller is a refrigerant component which is used to cool the temperature.
Last updated: September 28, 2022 4:16 pm
Common
Classification of HVAC ChillersTypes of Chillers based on Cooling MediumWater ChillersAir ChillersTypes of Chillers based on General Working PrincipleVapour Compression ChillersVapour Absorption ChillersTypes of Chillers based on Compressor TechnologyReciprocating ChillersScrew ChillersCentrifugal Chillers
HVAC is a very vast field and it comprises of many devices. One of the main components in HVAC is a chiller.
Chiller is a refrigerant component which is used to cool the temperature of water, air or evaporation. They are used in many commercial and industrial applications.
Classification of HVAC chillers
In this post, we will see the various types of chillers used in HVAC.
To understand first of all how a refrigeration cycle works, refer the below link. It will help to then understand the chillers more easily.
HVAC Refrigeration Cycle
The chillers are classified into two types based on cooling medium. They are water chillers and air chillers.
Water Chillers
As the name implies, the water chiller uses the water as a condensing medium. In condensers, water from cooling tower is used to condense the hot gas coming from compressor.
The remaining refrigerant cycle remains the same. When the final gas reaches evaporator coils, it does heat exchange with warm medium (water or air) and cools it’s temperature.
Air Chillers
As the name implies, it is a chiller which uses the air as a condensing medium. Condensing fans are used to condense the hot gas coming from compressor.
The chillers are classified into two types based on working principle. They are vapour compression chillers and vapour absorption chillers.
In the vapour compressor chiller system, a compressor is used to compress the refrigerant gas. The gas is then pushed by the compressor and rotated in the whole circuit.
This means that the vapour is compressed and then rotated in the whole system by the compressor. So, in this chiller, compressor is the integral part.
Unlike the previous one, the vapour absorption chillers does not use compressor; but instead it uses a heat source to move the refrigerant around the circuit.
The heat source can be hot water or steam. The main components instead of compressor are absorber, pump and generator.
The chillers are classified into two types based on compressor technology. They are reciprocating chillers, screw chillers, and centrifugal chillers.
HVAC Chiller
The reciprocating chiller has compressor which uses piston for compressing the refrigerant.
Reciprocating compressors are positive displacement machines that use the reciprocating action of a piston inside a cylinder to compress refrigerant. As the piston moves downward, a vacuum is created inside the cylinder.
Due to this, the refrigerant is sucked into the cylinder. After the piston reaches its bottom position it begins to move upward. As the piston continues to move upward it compresses the refrigerant, increasing its pressure.
At a certain point the pressure exerted by the refrigerant forces the exhaust valve to open and the compressed refrigerant flows out of the cylinder. Once the piston reaches it top-most position, it starts moving downward again and the cycle is repeated.
Screw Chillers
This compressor uses two helical rotors which propels and compresses the refrigerant gas. It consists of two mating helical grooved rotors-the male lobes and the female gullies. They are housed in a stationary casing and move simultaneously.
As they rotate, the refrigerant gas is compressed by direct volume reduction between the two rotors, and transformed into vapor.
This compressor uses an impeller, which is must like a water pump. This impeller is used to compress the refrigerant.
In this way, we understand the various types of chillers used in HVAC.
What is a Thin Film Deposition System? How do they work?
Thread Sealant Types and Selection for Instrumentation Applications
Types of Renewable Energy Sources
Why Industrial Safety Automation Matters Today?
Introduction to Wastewater Treatment Works and Pumping Station
Difference Between Microcontroller and Microprocessor
Difference Between NPT, BSPP and BSPT Seals
Self-balancing Pneumatic Instrument Principles
What are Micro Electro-Mechanical Systems (MEMS)?
What is an Automotive Radiator?
Basic Components of HVAC System
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 2
Industrial Automation Sales and Marketing Tools
Introduction to Mechatronics
Supermarket HVAC Ventilation System
Supermarket Ventilation System – HVAC Basics
Essential Safety Tips for Glass Workers
What is IO-Link in Smart Manufacturing
What is IO-Link in Smart Manufacturing?
CNC Machine Tools Problems and Solutions
Common Problems With CNC Machine Tools & Their Solutions
temperature sensor
Dead time
Shaper Machine Hydraulic Circuit Design
Hydraulic Shaper Machine – Components, Circuit, Principle
P & ID Valve Status Symbols
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 4
Top US Universities that Offer Online Education
Pressure Gauge Problems
Installation & Commissioning Tips for Wireless HART Devices
Installation & Commissioning Tips for HART Devices
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Classification of valves
Introduction to Types of Valves
Instrument Control Package (ICP)
Package Control and Safety Systems Implementation Methods
Difference between Signal Cables and Control Cables
Distribution transformer
Different Types of Transformers
Seismic Transducers Objective Questions
