Reading: What is Cell Constant in Conductivity Analyzer? and its Importance
Inst Tools > Blog > Analyzers > What is Cell Constant in Conductivity Analyzer? and its Importance
The cell constant in conductivity analyzer is directly proportional to the electrodes distance and inversely proportional to surface area.
Last updated: August 7, 2023 10:07 am
vicky
Analyzers
The conductivity analyzer is one of the most important analyzers used in water treatment plants. The quality of the water is mainly decided by the conductivity of the water. Hence, to determine the accurate conductivity of water or any given solution we use a conductivity analyzer.
Importance of Cell ConstantWhat is Cell Constant?Why we need different Cell Constants?
Contact type Conductivity analyzers are widely used in water treatment plants. You also might have come across these analyzers. But have you noticed that every conductivity sensor has a different cell constant. If you have noticed cell constant then you might have seen letter “k” which is nothing but cell constant.
You might have also experienced problem when operation department says that the conductivity analyzer is not showing exact value or while replacing a conductivity sensor you see some different conductivity sensors with different cell constants like 0.01, 0.1, 1.0 and get confused while choosing one from them. So, lets clear your confusion as we always do.
Now the question is that
To answer this question, we need to go through some basics. Let us recall how the conductivity analyzer works.
The conductivity analyzer has a sensor and a transmitter. The conductivity transmitter gives AC voltage to the conductivity sensor. The conductivity sensor is immersed in the solution whose conductivity is to be determined.  The conductivity sensor has 2 plates as shown in the figure.
Two Electrode Conductivity Probes
Now when the AC voltage is given to the conductivity sensor, the current starts flowing between the sensor plates. The current flows due to the ions present in the water. We need to know the conductivity of the given sample. This conductivity is surely dependent on the area and length of the conductor used. Now this value is compensated by the term cell constant.
Cell constant (k) is nothing but a term which is directly proportional to the distance of the electrodes of the conductivity sensor and inversely proportional to the surface area.
Hence, we can say that if the distance between the plates and/or surface area of the plate changes, the cell constant also changes. This is the reason behind every conductivity sensor having its own cell constant.
Image: Hamilton Conducvity Sensor with Cell Constant K = 6.3
Now the next question which arises is that why we need different cell constants? Why do manufacturers create conductivity sensors with different cell constants? All the manufacturers should create a standard conductivity sensor with same cell constant and that cell constant value shall be made a universal standard value.
So, there is a big NO for making same cell constant.
Before proceeding further, let us see some waters with different conductivities:
  1. Ultra-pure water: conductivity between 0.01 µS/cm and 0.1 µS/cm
  2. Demineralised water: conductivity between 0.1 µS/cm and 10 µS/cm
  3. Fresh water: conductivity between 1 µS/cm and 100 µS/cm
  4. River water: conductivity between 50 µS/cm to few hundred µS/cm
  5. Sea water: conductivity in few ten thousand µS/cm
Now, you might have seen that in ultra-pure and pure water service, conductivity sensor with cell constant with 0.01 is used. Also, in demineralised water, conductivity sensor with cell constant of 0.1 is used.
As a thumb rule, always remember, in solution or water having very low conductivity, the path between the plates for ions to travel or say distance between the plated should be very less to get accurate readings. So, as per our discussion, if distance is reduced, then the cell constant will also get reduced.
Hence in ultra-pure water and pure water, conductivity sensors with cell constant 0.01 are preferred to get accurate readings.  Similarly, for solutions having large conductivity, we use conductivity sensor with large cell constant to get accurate readings. Cell constants like 10 or 100 are used to measure conductivity of river water or sea water.
This is the main reason to have conductivity sensors with different cell constants.
  • Oxygen Gas Measurement
  • Carbon Dioxide in Flue Gas
  • pH Analyzer Common Problems
  • Absolute and Relative Humidity
  • Troubleshooting Oxygen Analyzer
Pulsed Fluorescence SO2, H2S, CS Analyzer Working Principle
Ammonia Gas Detector Working Principle and Calibration
Dew Point Meter Principle
What is the Application of Electrical Conductivity Meter?
Troubleshooting pH Analyzer Common Problems
Total Organic Carbon Analyzers Questions and Answers
Gas Filter Correlation (GFC) Spectroscopy
Hydrazine Analyzer Working Principle
Gas chromatograph Working Animation
Scintillation Counter Principle
Humidity Sensor Working Principle
Humidity Sensing Absorption Hydrometer Principle
Chlorine dioxide Analyzer Principle
Thermal Conductivity Detector (TCD) Principle
process chemical analyzer calibration
Automated Calibration
process gas chromatographs
Multi Column Gas Chromatograph
Free chlorine Analyzer Principle
Infrared Flue Gas Analyser
What is Infrared Flue Gas Analyzer? – Working Principle
what-is-gas-metering-system
What is Gas Metering System?
online silica analyzer
Silica Analyzer Problems and Troubleshooting Tips
Analytical Standards
mass spectrometer sample system
Mass Spectrometer Working Principle
Single Phase Induction Motors Questions and Answers
Nano Instrumentation Objective Questions
Fixed Type Motor control center (MCC)
Motor Control Center (MCC) Signal Interface Termination (SIT)
How to Apply on Online JOB Portal Website
How to Apply on Online JOB Portal Website?
What is calibration?
Wedge Flow Meter
Wedge Flow Meter Principle
Displacer Level Transmitter Calibration Procedure
Displacer Level Transmitter Calibration using Water & Process Liquid
Asynchronous Down Counter Objective Questions
