Reading: Cathodic Protection – Sacrificial Anodic and Impressed Current
Inst Tools > Blog > Electrical Basics > Cathodic Protection – Sacrificial Anodic and Impressed Current
In this article, we will learn about the corrosion, cathodic protection, sacrificial anodic and impressed current protection methods.
Last updated: September 28, 2022 1:58 pm
Anurag Mathur
Electrical Basics
6 Min Read
What is Corrosion?
Corrosion is a natural destructive phenomenon where metal in presence of moisture and air (oxygen) form its metallic oxide, hydroxide, or sulfide form.
What is Corrosion?Types of CorrosionWays to Prevent CorrosionTypes of Cathodic ProtectionSacrificial Anodic ProtectionImpressed Current ProtectionFactors affecting corrosion rate
For e.g. when iron comes in contact with air and moisture it forms iron oxide.
The reddish-brown color which forms on the metal surfaces is known as rust while the phenomena of chemical reactions happening on the metal surface are known as corrosion. So, corrosion is a process while rust is the end result.
corroded tank
Figure: corroded tank
Rusting is a Redox reaction that is a combination of Reduction and Oxidation. The reduction reaction is a process where an element gains an electron while the oxidation reaction is a process where an element loses an electron.
Most metals are easily oxidized, they tend to lose electrons to oxygen. As oxygen is reduced (gains electron), it forms an oxide with the metal.
Types of Corrosion
  • Galvanic Corrosion – When reduction and oxidation takes place on different kinds of metal in contact with one another, the process is called galvanic corrosion.
  • Electrochemical Corrosion – it occurs commonly in electronic equipment, water or other moisture becomes trapped between two electrical contacts that have an electrical voltage applied between them. This result in an unintended electrolytic cell.
corroded pipeline
Figure: corroded pipeline
Corrosion causes huge losses to any organisation. To prevent corrosion we use a Cathodic Protection system.
Cathodic protection is a process of providing protection to the buried and submerged or above ground metallic parts against corrosion it is also used to prevent corrosion in a bridge, an oil rig and other metallic structures.
It increases the lifespan of metallic structures thus increasing productivity & safety. Here the metal to be protected acts as a cathode, therefore the term cathodic protection.
Now we will discuss about cathodic protection and its different types.
Here we will discuss about the two types of cathodic protection methods.
They are
  1. Sacrificial Anodic Protection and
  2. Impressed Current Protection
Sacrificial Anodic Protection used in underground pipelines, crude tanks.
In sacrificial anodic protection a more reactive metal (such as Zinc, Aluminium, and Magnesium) is used as an anode because they have low electrochemical potential as compared to steel) while the metal to be protected acts as a cathode.
When two metals are electrically connected to each other in an electrolyte e.g. seawater, electrons will flow from the more active metal to the other, due to the difference in the electrical potential.
When the most active metal (anode) supplies current, it will gradually dissolve into ions in the electrolyte, and at the same time produce electrons, which the least active (cathode) will receive through the metallic connection with the anode.
The result is that the cathode will be negatively polarized and hence be protected against corrosion.
It is temporary Cathodic protection. Its minimum Lifespan is 25 years. In a year, if 2ma current is sent continuously, then 3gm of zinc anode will corrode.
Impressed Current Protection used in storage tanks and mounded bullets.
The impressed current method is used for the protection of large underground structures like the tank bottom and bullets.
Here the anode is an MMO anode (Mixed metal oxide) with small proportions of titanium and indium. The number of MMO anode rings varies according to the diameter of the tank/structure.
Three loops are taken out from MMO anodes and are connected to the Anode junction box. When DC potential is applied current starts to flow from anode to cathode (the structure to be protected).
HDP sheet is provided such that electrons can flow from anode to cathode. The CuSO4 electrodes are installed in different locations to monitor the pipe to soil potential. 60% of sand in the bitumen layer to ensure continuity of electron flow.
Two drain points are provided to complete the circuit. One measuring point is given to measure the current. If corrosion occurs on the tank bottom then at that part the resistance will be high.
So there will be a voltage drop and the reference electrode at that part will show a drop in potential. Future monitoring pipelines to monitor the pipe to soil potential manually.
Some factors which affect the rate of corrosion are-
  • Temperature – Steel and other metals corrode faster in high temperatures. So, metallic structures exposed to higher temperature will corrode much faster.
  • Conductivity – For Corrosion to occur there has to be conductivity between two parts of corrosion reaction. Corrosion will not happen in distilled water, however it will be maximum in saline water.Therefore corrosion happens more in coastal & humid areas.
What is an Electrical Drive? Types, Advantages, Disadvantages
Motor Cooling Methods
Dahlander Motors – Principle, Advantages, Disadvantages
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Formula of AMP, KW, KVA, HP for AC and DC Voltages
Difference Between Isolator and Circuit Breaker
Automatic Transfer Switch – Electrical Circuit, Operation, Video
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
Difference Between Flame Resistant and Flame Retardant Cables
Worldwide Voltage & Frequency Values
De-energized Electrical Circuits, Networks, and Equipment
What is a Magnetic Contactor? – Principle, Types, Advantages
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
Difference Between Open Circuit and Close Circuit
Motor Maintenance
Motor Maintenance, Troubles, Regular Checks, Performance
Types of Tripping Protection in MCCB
Electrical Voltage and current Signals
VFD Engineer Roles - Installation and Commissioning
VFD Engineer Roles – Installation and Commissioning
Difference between Current Transformer and Potential Transformer
Why Damper windings used in synchronous motors
Earth Meter Working Principle
How Earth Resistance is Measured
Cycloconverters Objective Questions
How to Test a Motor using Megger
How to Test a Motor using Megger?
Two Wire Sensors Animation
Two Wire Sensor Working Principle and Animation
Spiral bimetallic thermometer principle
Spiral Bimetallic Thermometer Principle
PLC Program for Conveyor System
PLC Conveyor Ladder Logic Program
Demystifying Reynolds Number
Why Viscosity is Not Included in the Orifice Equation?
