Reading: Cars Garage Counter From the Same Door PLC Logic
Inst Tools > Blog > PLC Tutorials > Cars Garage Counter From the Same Door PLC Logic
Write a PLC program to count the number of cars in the garage knowing that the entrance and the exit of the garage are the same one door.
Last updated: March 4, 2021 11:02 am
Inputs & outputs PLC Logic
There are 2 photocells one in the outer side of the garage and the other in the inner side.
Note the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs & outputs
I0.0: outer photocell
I0.1: inner photocell
I0.2: reset
C1: Counter.
T1: Timer 01
T2: Timer 02
MW10: counter-current value.
M0.1: count up.
M0.5: count down.
PLC Logic
  • In this example, we rely on the concept of positive edge and negative edge.
  • When the car enters the garage the outside photocell is energized first after that the inside photocell would be energized in order.
  • So to detect that the car is entering the garage the outside sensor negative edge should be detected after that the positive edge of the inside photocell. And vice versa for the car comes out from the garage.
Network 01
In case of the count-down, memory is off and the negative edge of the outer photocell detected then energizes the memory bit in the flip flop and resets it in the case of counting up.
After that, the next step is to detect the positive edge of the inner photocell to set the memory bit of counting up.
To reset the count up SR flip flop the negative edge of the inner photocell should be detected in case of counting up after a delay of 50 ms, that delay is to ensure the interlocking between the counting up and counting down.
As it’s an extended on delay timer a reset bit should be added, so the count up memory should reset the timer.
Network 02
PLC based automatic car parking counter
In case of the count up memory is off and the negative edge of the inner photocell detected then energizes the memory bit in the flip flop and resets it in the case of counting down.
After that, the next step is to detect the positive edge of the outer photocell to set the memory bit of counting down.
To reset the countdown SR flip flop the negative edge of the outer photocell should be detected in case of counting down after a delay of 50 ms, that delay is to ensure the interlocking between the counting up and counting down.
As it’s an extended on delay timer a reset bit should be added, so the countdown memory should reset the timer.
Network 03
Up Down Counter (S_CUD)
The count up memory increment the counter by one, and the count down memory decrement the counter by one.
The reset button resets the counter counts value to 0.
The counter counts value is registered in the MW10.
Author: Karim Ali Anwar
  • VFD Ladder Logic
  • Open Source PLC
  • Proximity Switch
  • Filter in AC Circuits
  • Single-phase Power
Exhaust Fan Control: Example of PLC Timer Programming
Basics of Motion Controllers
Finding the Best PLC for Your Project – Tips and Tricks
Chemical Mixing Process using PLC
PLC Electric Motor Interlocks
Electrical Switches Principle & Types
Conveyor Sorting System with Color Detection PLC Logic
Establishing a Modbus Driver for SCADA Indusoft Web Studio
#17 PLC Best Practices – Log PLC Uptime and Trend it on HMI
MCQ on PLC (Programmable Logic Controller)
SCADA for Substation Automation
Digital input signals in safety circuits
1oo2 Evaluation Safety Instruction in Safety PLC
Omron PLC painting program
Product Painting PLC Program using Omron CX-Programmer
PLC Count values higher than 999
Car Parking System PLC Program Example
Schneider Electric: Car Parking System with Calculations in PLC
Midline output instruction
What is Midline Instruction in Siemens PLC?
Gas Turbine Temperature Control using Siemens Tia Portal
Modbus in Industrial Networks
ControlLogix 5580 Controllers
Rockwell PLCs for Large Scale Applications
Wiring Diagram Forward-Reverse for 3 Phase Motor
Motor Forward and Reverse Direction Control using Limit Switches
Non-Contacting-Radar-Level-Transmitter-Animation
Non Contacting Radar Level Transmitter Animation
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
Example Program Logic in Allen Bradley PLC
PLC Programming Examples on Industrial Automation
Air Pre-heater
What is an Air Pre-heater? – Types, Working, Advantages
Electrical Conduit
What is Electrical Conduit? Types, Advantages, Disadvantages
ControlLogix
Difference Between CompactLogix and ControlLogix
Electrical Machines MCQ Series 20
