Reading: RTD Calculator : Calculate Temperature from Resistance
Inst Tools > Blog > Instrumentation Tools > RTD Calculator : Calculate Temperature from Resistance
Last updated: November 12, 2019 4:56 pm
Instrumentation Tools Temperature Measurement
9 Comments
2 Min Read
RTD Conversion tool: R to T
This is used to calculate temperature value of RTD sensor from known resistance.
This calculation tool used to find out the temperature value of a RTD sensor with known resistance.
Formula:
Resistive Temperature Detectors (RTDs) relate resistance to temperature by the following formula:
   RT = Rref[1 + α(T − Tref)]
Where,
RT = Resistance of RTD at given temperature T (ohms)
Rref = Resistance of RTD at the reference temperature Tref (ohms)
α = Temperature coefficient of resistance (ohms per ohm/degree)
Example:
The following example shows how to use this formula to calculate the resistance of a PT100 RTD with a temperature coefficient value of 0.00392 at a temperature of 35 degrees Celsius:
Assuming Temperature Reference = 0 Degrees
For PT100 RTD the Rref = 100
RT = 100 Ω[1 + (0.00392)(35 − 0)]
RT = 100 Ω[1 + 0.1372]
RT = 100 Ω[1.1372]
RT = 113.72 Ω
For Temperature to Resistance conversion also the same above formula applies.
The above given is a basic equation only for RTD calculation.
Note:
1.The above RTD calculation tool designed for a standard PT100 sensor.
2.If you are interested to calculate for a different RTD then change the fixed constant values as per the sensor type.
Temperature Controller Problem
Problems of Reference Junction Compensation : Thermocouples
What is Temperature ?
Temperature Sensor Failure
Components of RTD
How Does an Infrared Thermometer Work?
9 Comments
  • Anonymous says:
    April 13, 2015 at 6:34 pm
    Excellent Work Dude…. Thanks for sharing
  • C RamMohan says:
    April 20, 2015 at 4:54 am
    Its a great instrumentation tool.
  • Dayanand says:
    November 12, 2015 at 4:46 pm
    its great bt plz send mi various formula sits in excel type file on my mail id
  • dheeraj dhawas says:
    February 27, 2016 at 3:35 am
    Dear sir,
    tell me how u have calculate temperature coeff. Value of resistance.
    • S Bharadwaj Reddy says:
      February 27, 2016 at 5:22 am
      Hello Dheeraj, For Temperature Coefficient Value – Pl Click here to Read
  • Isreal Casteel says:
    September 16, 2020 at 9:42 am
    Pharm line is going down
  • andrew says:
    August 14, 2021 at 8:30 am
    145 degrees convert to resistance
  • Mansingh Rathore says:
    September 23, 2021 at 10:51 pm
    great explain the RTD but send me PDF all formula
  • Amin Hassan says:
    October 30, 2021 at 11:15 am
    Measurement of temperature changes using electric resistance measurement,
    I will use to apply to Motor winding temperature monitoring
Thermowell Problems
RTD Calibration
Temperature Switch Working Principle
What is a Head Mount Temperature Transmitter? – Advantages
Convert current (4-20mA) to Percentage (0-100%)
Stability and Uniformity of Temperature Bath
RTD Testing Methods in Calibration Laboratory
Thermistors and Resistance Temperature Detectors (RTDs)
bimetallic thermometer working principle
Different Types of Thermometers
Temperature Sensors Questions
Questions on Thermocouple and Pyrometer
RTD Accuracy
What is RTD Accuracy ?
RTD Construction
Introduction to RTDs
field-mounted thermocouple
Thermocouple Extension Wires
Skin Type Thermocouple
Thermocouple Law of Intermediate Metals
Thermocouples Law of Intermediate Metals
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Dry-Leg
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Single-Phase Full Wave AC-DC Converter Questions
Allen Bradley PLC Emulator
How to Work with Allen Bradley RsLogix Emulator?
Difference between KW and KVA
Thyristors Objective Questions and Answers
Power Supply Circuit Working Animation
Asynchronous Motor Animation
Flow meter Turndown Ratio
Importance of Flow Meter Turndown Ratio
