Reading: What is Cable Bending Radius? – Definition & Calculation
Inst Tools > Blog > Common > What is Cable Bending Radius? – Definition & Calculation
The electrical cable bending radius is the smallest radius that a cable can be bent around without damaging it.
Last updated: March 27, 2023 10:57 am
Shiv Kumar
Common
In this article, you will learn about the cable bending radius and the calculation of Cable Bending Radius.
Cable Bending RadiusSetup for OverheadSetup for duct close to the floorSetup for pulling around bendsMaximum Pulling TensionSide Wall PressureCalculation of Cable Bending Radius
The cable bending radius is the smallest radius that a cable can be bent around without damaging it. The greater the material’s flexibility, the smaller the bending radius. Generally, cable bending radius is stated as an element of cumulative cable dimension like 10D, the outer diameter of that cable.
To prevent the over-bending of cables, here are a few recommendations on cable feeding during the setup process.
Setup for Overhead
Feeding cables overhead into a cable tray, a cable drum on jacks or cable stands can be mounted so that the cable can be easily pulled from the top.
This is the recommended orientation for pulling cables rather than from the underside this protects the cable from potential damage caused by over-bending or friction against the ground, particularly if sharp objects such as rocks or nails are present.
Feeding or installing the cable in a duct close to the ground surface, the cable is pulled from the underside instead. Considering placing cable rollers for easy installation and to prevent damage to your cable sheath.
Pulling around bends requires a larger shaft assembly than the minimum bending radius. The position of the pulleys must be in a way that the effective curvature is smooth instead of polygonal.
During large cable installation, it is highly preferred to have a cable-pulling grip connected to the top end of the metallic conductor.
Pulling accessories on cables must be protected with shielded tape to prevent the scoring of cable trays, cable ladders, and installation pulleys. A dynamometer is used to verify that the cable’s maximum pulling tension must not exceed as advised by the manufacturer/vendor.
 The below table represents the maximum permissible pulling  Tension in Kgf.
Cable Maximum Pulling Tension
Note:
1.  The cable must be pulled at a constant speed.
2. Long-length cable drum must not be rotated very fast because overrun makes cable damage if the pulling speed is reduced or stopped immediately.
Side Wall Pressure
The tension experienced by the cable as it is pulled through a curved section is known as sidewall pressure. Sidewall pressure is calculated by both the pulling tension on the cable and the cable’s bending radius limitation. To prevent cable damage, side wall pressure is maintained below the maximum permissible limit of 500 Kgf/m.
Mathematically,
Side Wall pressure to cable is given by the ratio of Pulling Tension in Kgf to Bending Radius in meter
Side Wall pressure to cable = Pulling Tension in Kgf / Bending Radius in meter
Side Wall pressure to cable = T/R
To setup and configure these electrical cables to ensure safety without impacting their electrical and physical properties,
Cable Bending Radius is given by
Cable Bending Radius (R)   = 4* Diameter.
For a cable with a diameter D= 21.4 mm
Bending Radius of cable (R)   = 4*D = 4 x 21.4 mm = 85.6 mm
The below three tables represents the minimum bending radius required for various cable types.
 Minimum Cable Bending Radius for Fire Resistant Cable. (as shown below image)
Fire Resistant Cable Bending Radius
Minimum Cable Bending Radius for PVC Insulated Power Cables. (as shown below image)
PVC Insulated Power Cable Bending Radius
Minimum Cable Bending Radius for XLPE Insulated Power Cables. (as shown below image)
What are the factors that influence Minimum Bending Radius?
Factors that influence Minimum Bending Radius are as follows.
  • The Cable Size,
  • The Cable Construction,
  • The Conductor Type
  • Sheathing Type And
  • Insulation Types.
  • What is an HRC Fuse?
  • SCADA in Power System
  • What is a Buchholz Relay?
  • Motor Winding Sensors
  • Electrical Panel Bus Coupler
Common Materials used in Instrumentation Cables
HVAC Water Chillers Principle
Best Online Courses to Learn Electrical Engineering
Smart Transmitters Advanced Diagnostics
Best Engineering Mobile Apps on Google Play & App Store
Digital Measuring Instruments – Types, Functions, Advantages, Disadvantages
Automation in the Construction Industry
Step-by-Step Guide: How PCBs are Manufactured from Start to Finish
What is Arduino? Different Models of Arduino Controllers
Wireless Electric Vehicle Charging
Basic Principles of Solar Technology
Pneumatic Load Cell Principle
Electronic Diagrams, Prints and Schematics
Top 3 Online Bachelor’s Programs in Electronics Engineering
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Single Block and Bleed Valve Manifold
Single Block and Bleed Valve Manifold Operation
Laser Doppler anemometer
Laser Doppler Anemometer
IP transducer
Pilot Valves and Pneumatic Amplifying Relays
Bagging Machine Controller
Bagging Machine Controller – Principle, Operation Sequence
GPS Fleet Tracking Software
What’s the Best GPS Fleet Tracking Software and Systems?
Career Scope in Electronics Engineering
types of maintenance programs
different flow measurement technologies
Different Flow Measurement Technologies
Units of Electrical Measurement
Two-element drum level control system
Two Element Drum Level Control System
Multistage Flash Drums Erratic Level Readings
If Else Statement in SCL Language
Relay ladder diagram example
How to Draw a Schematic Diagram ?
PLC XOR LOGIC with Ladder Diagram
PLC Logic Functions
Seismic Transducers Objective Questions
