Reading: Bucket Steam Trap
Inst Tools > Blog > Process > Bucket Steam Trap
Bucket Steam Trap
Last updated: May 18, 2018 7:43 pm
Process
1 Min Read
In general, a steam trap consists of a valve and a device or arrangement that causes the valve to open and close as necessary to drain the condensate from piping without allowing the escape of steam. Steam traps are installed at low points in the system or machinery to be drained.
Bucket Steam Trap
A bucket steam trap is illustrated in Figure. As condensate enters the trap body, the bucket floats. The valve is connected to the bucket in such a way that the valve closes as the bucket rises. As condensate continues to flow into the trap body, the valve remains closed until the bucket is full. When the bucket is full, it sinks and thus opens the valve. The valve remains open until enough condensate has passed out to allow the bucket to float, and closing the valve.
Bucket Steam Trap
Figure : Bucket Steam Trap
Precoat Filters
What is a Deaerator? – Working Principle
Superheated Steam Temperature Control System
Flame Arrester Principle
Deep-Bed Filters
Backwashing
Process Control Loop Testing
Water Treatment Plant
Difference Between ETP, STP, and WTP – Treatment Plants for Water
Hazards of Compressed Air
Introduction to Wastewater Treatment Works and Pumping Station
What is Pump Redundancy?
Y Strainer
What is a Y Strainer ?
Working of Air Compressor
Working of Air Compressor – Types – Control Techniques
What is Heat Pump Water Heater?
Compressor Did Not Trip
RCA – Compressor Did Not Trip on Suction Pressure Low Low
Process Control Fundamentals
Gas Compressor Seal Oil System
Rotary Liquid Seal Ring Air Compressor
Rotary Compressors
Why Restriction Orifice is some distance from Blowdown valve
Why Restriction Orifice is some distance from Blowdown valve ?
belt conveyors principle
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
Ball Valve Material Selection
Logic Gates and Truth tables
Thyristor Protection Objective Questions and Answers
Synchronous Machine Multiple Choice Questions
SCADA System Vulnerabilities
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
knock-out drum
Applying Probability Laws to a Safety Instrumented System
