Reading: Top Questions on Bernoulli’s Principle in Flow Meters
Inst Tools > Blog > Flow Measurement > Top Questions on Bernoulli’s Principle in Flow Meters
Test your knowledge of Bernoulli's Principle and flow meters with our in-depth questions focused on fluid flow, pressure, and velocity.
Last updated: August 31, 2024 8:14 pm
Flow Measurement Instrumentation MCQ
15 Min Read
Test your knowledge of Bernoulli’s Principle and flow meters with our in-depth questions focused on fluid flow, pressure, and velocity in flow measurement systems.
Bernoulli’s Principle in Flow MetersWhat does Bernoulli’s principle relate in a fluid flow?How does Bernoulli’s principle apply in a Venturi meter?Why is pressure lower at the throat of a Venturi meter?What assumption is made about the fluid in Bernoulli’s principle?In which scenario does Bernoulli’s principle NOT apply?How does a Pitot tube uses Bernoulli’s principle?What is the role of pressure differential in a Venturi meter?Which of the following is a key limitation of Bernoulli’s principle?What happens to fluid velocity as pressure decreases, according to Bernoulli’s principle?In an orifice plate flow meter, how does Bernoulli’s principle help measure flow rate?Why must the flow be steady for Bernoulli’s principle to be accurate?What is a key design consideration for using Bernoulli’s principle in flow meters?Which of the following statements about Bernoulli’s principle is true?What is the effect of fluid density on Bernoulli’s principle?Which factor must remain constant for Bernoulli’s equation to be valid?In which type of flow does Bernoulli’s principle most accurately predict pressure changes?Why is the vena contracta important when applying Bernoulli’s theorem to an orifice plate?Why is Bernoulli’s principle less accurate at high speeds?What happens to fluid velocity as the cross-sectional area decreases in a pipe, according to Bernoulli’s principle?How does the orifice plate in a flow meter create the conditions described by Bernoulli’s theorem?What does the term “stagnation pressure” refer to in Bernoulli’s principle?How does Bernoulli’s principle affect the pressure on an airplane wing?How does fluid compressibility affect the application of Bernoulli’s principle in an orifice flow meter?What is the impact of Reynolds number on the performance of an orifice flow meter?How does Bernoulli’s theorem explain the pressure drop in an orifice flow meter?What is the relationship between the cross-sectional area and velocity in an orifice flow meter according to Bernoulli’s theorem?Why is Bernoulli’s theorem essential in the design of orifice flow meters?According to Bernoulli’s theorem, what happens to pressure energy as fluid velocity increases in an orifice meter?What is the significance of the pressure drop measured in an orifice flow meter?How does Bernoulli’s theorem justify the use of an orifice flow meter for fluid flow measurement?What assumption does Bernoulli’s theorem make about the flow in an orifice meter?According to Bernoulli’s theorem, what is the impact of fluid velocity on pressure when flowing through an orifice?Why does Bernoulli’s theorem assume negligible friction in an orifice flow meter?How does Bernoulli’s theorem explain the flow rate change as fluid passes through an orifice?What is the primary energy conversion that occurs in an orifice meter according to Bernoulli’s theorem?How does Bernoulli’s theorem relate to the concept of head loss in an orifice flow meter?What does Bernoulli’s theorem suggest about the relationship between flow velocity and pressure in an orifice meter?Why is Bernoulli’s theorem particularly useful in understanding the operation of orifice flow meters?According to Bernoulli’s theorem, what happens to the kinetic energy of fluid as it flows through an orifice?In which scenario would Bernoulli’s principle be least applicable?
Here this video provides you with detailed explanations for Bernoulli’s theorem questions and answers.
Bernoulli
Question 1
A. Pressure and density
B. Velocity and pressure
C. Temperature and velocity
D. Flow rate and pressure
Show the Answer
Question 2
A. It increases flow speed
B. It decreases pressure at the throat
C. It equalizes pressure
D. It measures temperature changes
Show the Answer
Question 3
A. Increased fluid velocity
B. Decreased fluid temperature
C. Reduced fluid density
D. Increased fluid viscosity
Show the Answer
Question 4
A. Fluid is compressible
B. Fluid is at constant temperature
C. Fluid is incompressible
D. Fluid is turbulent
Show the Answer
Question 5
A. Laminar flow
B. Turbulent flow
C. Steady flow
D. Incompressible flow
Show the Answer
Turbulent flow
Question 6
A. It measures fluid temperature
B. It determines the fluid’s density
C. It measures stagnation pressure to find velocity
D. It decreases flow pressure
Show the Answer
Question 7
A. It indicates fluid temperature
B. It measures fluid viscosity
C. It determines the flow rate
D. It balances fluid velocity
Show the Answer
Question 8
A. Assumes viscous fluid
B. Requires turbulent flow
C. Neglects friction losses
D. Assumes compressible fluid
Show the Answer
Question 9
A. Velocity decreases
B. Velocity remains constant
C. Velocity increases
D. Velocity oscillates
Show the Answer
Velocity increases
Question 10
A. It measures fluid temperature change
B. It detects fluid density variations
C. It relates pressure drop to flow velocity
D. It balances static pressure
Show the Answer
Question 11
A. To maintain constant temperature
B. To ensure consistent fluid properties
C. To avoid turbulence effects
D. To balance energy equations
Show the Answer
Question 12
A. Fluid color
B. Fluid density variations
C. Pipe material
D. Smooth, non-turbulent flow
Show the Answer
Question 13
A. It only applies to gases
B. It applies to compressible fluids
C. It assumes no energy loss
D. It neglects velocity variations
Show the Answer
Question 14
A. Directly affects pressure drop
B. Has no impact on pressure
C. Increases temperature
D. Only affects flow direction
Show the Answer
Question 15
A. Fluid viscosity
B. Fluid height
C. Fluid velocity
D. Fluid density
Show the Answer
Fluid density
Question 16
A. Compressible flow
B. Viscous flow
C. Steady, laminar flow
D. Unsteady, turbulent flow
Show the Answer
Question 17
A. It is the point of maximum fluid velocity and minimum density
B. It is the point of minimum fluid velocity and maximum pressure
C. It is the point of maximum fluid velocity and minimum pressure
D. It is the point of maximum fluid temperature and minimum pressure
Show the Answer
Question 18
A. Fluid density decreases
B. Pressure variations become negligible
C. Compressibility effects become significant
D. Temperature becomes a factor
Show the Answer
Question 19
B. Velocity increases
C. Velocity remains constant
D. Velocity fluctuates
Show the Answer
Velocity increases
Question 20
A. By restricting the fluid flow to decrease velocity and increase pressure
B. By restricting the fluid temperature to increase velocity and reduce pressure
C. By restricting the fluid flow to increase velocity and reduce pressure
D. By restricting the fluid flow to increase velocity and reduce density
Show the Answer
Question 21
A. Pressure due to fluid height
B. Static pressure at a point
C. Pressure where fluid velocity is zero
D. Minimum pressure in the flow
Show the Answer
Question 22
A. Increases pressure on top
B. Increases pressure on bottom
C. Equalizes pressure on both sides
D. Decreases pressure on the top
Show the Answer
Question 23
A. It increases fluid velocity
B. It causes energy losses
C. It enhances measurement accuracy
D. It has no effect on measurements
Show the Answer
Question 24
A. It stabilizes temperature
B. It affects the flow coefficient
C. It has no impact
D. It only affects laminar flow
Show the Answer
Question 25
A. Pressure increases due to velocity
B. Pressure drop is due to energy loss
C. Pressure drop is due to increased fluid velocity
D. Pressure remains constant across the orifice
Show the Answer
Question 26
A. Velocity decreases as area decreases
B. Velocity increases as area decreases
C. Area and velocity are independent
D. Area and velocity both increase
Show the Answer
Question 27
A. It predicts temperature changes
B. It provides a basis for pressure and velocity relationship
C. It assumes fluid is compressible
D. It ignores energy losses
Show the Answer
Question 28
A. Pressure energy increases
B. Pressure energy decreases
C. Pressure energy remains constant
D. Pressure energy converts to thermal energy
Show the Answer
Question 29
A. Indicates temperature rise
B. Reflects the energy loss
C. Directly relates to flow rate
D. Indicates a constant flow rate
Show the Answer
Question 30
A. It relates fluid density to temperature
B. It connects pressure drop to flow rate
C. It assumes constant temperature in the fluid
D. It stabilizes the fluid’s velocity
Show the Answer
Question 31
A. Flow is compressible
B. Flow is turbulent
C. Flow is incompressible and steady
D. Flow is unsteady
Show the Answer
Question 32
A. Pressure increases with velocity
B. Pressure decreases with velocity
C. Pressure remains unchanged
D. Pressure oscillates with velocity
Show the Answer
Question 33
A. To simplify flow calculations
B. To increase pressure drop
C. To focus on temperature changes
D. To account for fluid viscosity
Show the Answer
Question 34
A. Flow rate decreases with pressure
B. Flow rate increases with pressure
C. Flow rate is independent of pressure
D. Flow rate is proportional to the square root of pressure drop
Show the Answer
Question 35
A. Thermal to kinetic energy
B. Kinetic energy to pressure energy
C. Pressure energy to kinetic energy
D. Potential energy to thermal energy
Show the Answer
Question 36
A. Head loss is minimized by increasing velocity
B. Head loss is unrelated to Bernoulli’s theorem
C. Head loss is the energy loss due to pressure drop
D. Head loss increases fluid temperature
Show the Answer
Question 37
A. Pressure and velocity are directly proportional
B. Pressure remains constant as velocity changes
C. Velocity increases as pressure decreases
D. Pressure increases as velocity increases
Show the Answer
Question 38
A. It explains temperature fluctuations
B. It relates pressure, velocity, and flow rate
C. It assumes fluid compressibility
D. It only applies to laminar flow
Show the Answer
Question 39
A. It decreases
B. It remains unchanged
C. It increases as pressure decreases
D. It converts into potential energy
Show the Answer
Question 40
A. Fluid flowing through a narrow pipe
B. Fluid flow with rapid expansion
C. Fluid moving in a steady, incompressible manner
D. Fluid flow in a slowly converging pipe
Show the Answer
  • Differential Pressure Flow Transmitter Questions
  • Gas and Liquid Measurement Processes Solutions
  • Factors Affect the Stability of Flow Meter Readings
  • Pitot Tube Problems and Troubleshooting Steps
  • Troubleshooting DP Type Transmitter Problems
Thermocouple Temperature Range Questions and Answers
Difference between Different Types of Flow Meters
Digital Input Output Devices Objective Questions
Frequency Measurement Objective Questions
Proportional Integral Derivative Controllers – PID MCQ
100 Test and Electrical Measurement Objective Questions and Answers
Coriolis Flowmeter Advantages and Limitations
Why Flow is Directly Proportional to the Square Root of DP?
Split-Range, Auto-Selector, Ratio & Cascade Systems
What is a Turbine Flow Meter?
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
Objective Questions of Building Fire and Gas Detectors
Semiconductor Sensors Objective Questions
Orifice Plate
Orifice Plate Questions and Answers
What is an Orifice Flange ?
What is an Orifice Flange? – Purpose and Applications
Dataloggers Objective Questions
Data Loggers Objective Questions
Measurements & Instrumentation Quiz – Set 1
Electro Mechanical Transducers Objective Questions
What is a Condensate Pot? How to Install it?
Turbine Flow Meter Animation
Turbine Flow Meter – Principle, Advantages, Disadvantages
Electro Magnetic Flow Meter Animation
Difference between DSP and DAC - Digital Electronics
Difference between DSP and DAC – Digital Electronics
% of Reading vs. % of Full Scale Accuracy
Gas Valve Sizing
Gas Valve Sizing
Personal Protection Equipment
What is PPE? – Types – Personal Protection Equipment
Power Systems Operation and Control Interview questions
Electromagnetic Noise Interference
What is Electromagnetic Noise Interference?
Swiss Screw Machining
Things You Should Know About Swiss Screw Machining
Gas Suppression System
What is Gas Suppression Systems ?
