Reading: Basic Temperature Sensors MCQ Questions Answers
Inst Tools > Blog > Instrumentation MCQ > Basic Temperature Sensors MCQ Questions Answers
Test your knowledge of basic temperature sensors with this MCQ questions and answers on types, working principles, and advantages.
Last updated: July 24, 2024 4:04 pm
Instrumentation MCQ Temperature Measurement
6 Min Read
Basic Temperature Sensors MCQWhich temperature sensor works by measuring the change in electrical resistance of a material?How does a thermocouple generate a voltage?What is the principle behind the operation of an RTD?What type of sensor uses two metals with different coefficients of expansion to measure temperature?Which type of temperature sensor provides rapid response to temperature changes?How does a thermistor’s resistance typically change with temperature?Which sensor can measure temperature without physical contact?What is a primary disadvantage of using thermocouples for temperature measurement?Which temperature sensor type uses a liquid-in-glass mechanism for temperature measurement?How does a bimetallic strip temperature sensor work?What is a common use for thermistors in electronic circuits?How does a thermocouple measure temperature?Which temperature sensor is often used for non-contact temperature measurements in industrial settings?What material is commonly used in RTD elements?What is the main reason RTDs are preferred in industrial applications?Which type of temperature sensor is commonly used in thermostats for household heating systems?How does the accuracy of thermocouples compare to RTDs and thermistors?Which property of infrared radiation is utilized by infrared temperature sensors?What is a key advantage of RTDs over thermocouples?How do fiber optic temperature sensors measure temperature?Why are thermocouples commonly used in gas turbine engines?How do infrared temperature sensors measure temperature?How do thermocouples typically handle very high temperature environments?
This detailed video provides the temperature sensors multiple choice questions and answers with explanations.
Basics of Temperature Sensors - Instrument Technician Questions
Question 1
A. Thermocouple
B. Thermistor
C. Infrared Sensor
D. Pyrometer
Show the Answer
Thermistor
Question 2
A. By changing resistance
B. By varying capacitance
C. By generating infrared radiation
D. By the Seebeck effect
Show the Answer
Question 3
A. Seebeck effect
B. Change in inductance
C. Change in resistance
D. Emission of infrared radiation
Show the Answer
Question 4
A. Pyrometer
B. Bimetallic Strip
C. RTD
D. Thermistor
Show the Answer
Bimetallic Strip
Question 5
A. RTD
B. Thermistor
C. Thermocouple
D. Infrared Sensor
Show the Answer
Thermocouple
Question 6
A. Increases linearly
B. Decreases linearly
C. Increases exponentially
D. Decreases exponentially
Show the Answer
Question 7
A. Thermistor
B. RTD
C. Infrared Sensor
D. Bimetallic Strip
Show the Answer
Infrared Sensor
Question 8
A. High cost
B. Limited temperature range
C. Low sensitivity
D. Complex circuitry
Show the Answer
Low sensitivity
Question 9
A. Thermocouple
B. RTD
C. Mercury Thermometer
D. Thermistor
Show the Answer
Mercury Thermometer
Question 10
A. By generating a voltage
B. By changing capacitance
C. By bending due to expansion
D. By changing resistance
Show the Answer
Question 11
A. Voltage regulation
B. Temperature compensation
C. Signal amplification
D. Power conversion
Show the Answer
Question 12
B. By generating a voltage
C. By varying capacitance
D. By changing inductance
Show the Answer
Question 13
A. RTD
B. Thermistor
C. Infrared Sensor
D. Thermocouple
Show the Answer
Infrared Sensor
Question 14
A. Silicon
B. Platinum
C. Nickel
D. Copper
Show the Answer
Platinum
Question 15
A. Low cost
B. High durability
C. Fast response time
D. High accuracy
Show the Answer
High accuracy
Question 16
A. Thermocouple
B. RTD
C. Thermistor
D. Infrared Sensor
Show the Answer
Thermistor
Question 17
A. More accurate
B. Less accurate
C. Equally accurate
D. Varies with temperature
Show the Answer
Less accurate
Question 18
A. Emission of visible light
B. Absorption by liquids
C. Reflection by metals
D. Emission by all objects
Show the Answer
Question 19
A. Higher temperature range
B. Greater durability
C. Better linearity
D. Faster response time
Show the Answer
Better linearity
Question 20
A. By changing light intensity
B. By changing electrical resistance
C. By bending with temperature
D. By emitting infrared radiation
Show the Answer
Question 21
A. High accuracy
B. Fast response and wide range
C. Low cost
D. Easy calibration
Show the Answer
Question 22
A. By touching the object
B. By detecting visible light
C. By measuring emitted infrared radiation
Show the Answer
Question 23
A. By cooling the sensor
B. By using protective coatings
C. By selecting specific metal combinations
D. By increasing resistance
Show the Answer
  • Temperature Sensor Failure
  • Temperature Sensor Accessories
  • Bi-metal Temperature Sensors
  • Filled-bulb Temperature Sensors
  • Temperature Sensor calibration
Pressure Measurement Multiple Choice Questions
RTD Sensor Connections
Photo Electric Transducers Objective Questions
Temperature Switch Working Principle
Feedback Pneumatic Load cell Objective Questions
DCS Quiz
Basics of Thermocouples and RTD
RTD Standards
Industrial Instrumentation Quiz
Types of Relays – Questions and Answers
Sensors Objective Questions
Why RTD installed after the Orifice Plate ?
Temperature Calibration Bath Principle
Flip Flop Circuits Objective Questions
Test and Electrical Measurement Objective Questions and Answers
100 Test and Electrical Measurement Objective Questions and Answers
Measurement of Impedance Objective Questions
Shift Registers and Counters Objective Questions
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
Four Wire RTD Circuit
What is a Four-wire RTD ?
Landline Telemetry Objective Questions
Process Control Questions & Answers
Servo Operated Electro Magnetic Flowmeter Objective Questions
Ladder Diagram circuit
PLC Practice Questions
Car Wash Program using Functional Block Diagram (PLC)
Laser Diode Working Principle
Ultrasonic Transmitters vs. Guided Wave Radar Transmitters
Comparison of Pressure Instruments - Industrial Instrumentation
Comparison of Pressure Instruments – Industrial Instrumentation
What is a Fusible Loop System
What is a Fusible Plug? – Working, Advantages, Disadvantages
How do you select a Pressure sensor
How do You Select a Pressure sensor?
Career Scope in Electronics Engineering
