Reading: Fire and Gas system Audible and Visual Alarms
Inst Tools > Blog > Fire & Gas System > Fire and Gas system Audible and Visual Alarms
Last updated: January 23, 2019 10:45 pm
Fire & Gas System
A fire alarm system has a number of devices working together to detect and warn people through visual and audio appliances when smoke, fire, carbon monoxide or other emergencies are present.
These alarms may be activated automatically from smoke detectors, and heat detectors or may also be activated via manual fire alarm activation devices such as manual call points or pull stations.
Alarms can be either motorized bells or wall mountable sounders or horns. They can also be speaker strobes which sound an alarm, followed by a voice evacuation message which warns people inside the building not to use the elevators.
Fire alarm sounders can be set to certain frequencies and different tones including low, medium and high, depending on the country and manufacturer of the device.
A fire alarm system component with discrete identification that can have its status individually identified or that is used to individually control other functions.
Selection Criteria for Audible and Visual Alarms
Following are some minimum requirement applicable for Audible and Visual Alarms (Addressable Devices) selection, however requirements vary from industry to industry.
The audible and visual alarm shall be compatible with the fire and gas system panels from which it is connected to have automatic initiation from the panel.
The units shall be of wall/ceiling/floor mounting type to meet the installation requirements.
Audible alarms shall be rated for continuous operation.
Audible alarms used for Fire and Gas system shall be 0f low current consumption.
Audible alarms for Fire and Gas system shall be distinguishable from audible alarms used for other purposes. The audio signal shall be 0f different tones for fire, combustible gas and toxic gas alarms.
Audible signal appliances intended for of peration in the public mode shall have a sound level of not less than 85 dBA at 3 m or more than 120 dBA at a minimum hearing distance from the audible appliance.
To ensure that audible public mode signals are clearly heard, they shall have a sound level at least 15 dBA above the average ambient sound level or 5 dBA above maximum sound level having a duration of at least 60 seconds, whichever is greater, measured 1.5m above the floor in the occupied area. (The average ambient sound level used for design guidance in mechanical equipment rooms shall be 85 dBA or actual measured value , whichever is higher).
Alarms mounted outside the central control facility shall be audible in all areas of the facility.
A manual operation should be required to silence the alarm. The alarm shall not be automatically silenced or canceled.
Visual alarms shall be capable of continuous operation without adverse effects.
The colour of the transmitted Iight, power output and operation shall be such that it is clearly visible from all areas it covers and readily discernible against artificial lighting internally and sunlight externally.
Visual alarms which uses tungsten lamps shall use lamps underrun to ensure maximum life. long-life, high-quality lamps to the latest technology shall be used.
Warning flashing fire alarm beacons provided for high noise level areas to compliment the audio alarms shall be complete with xenon strobe light (Red lens) and totally enclosed solid state circuitry.
The audio and visual alarms shall be rated to operate on a nominal voltage of 24V DC unless otherwise specified.
Articles You May Like :
What is Alarm Management System ?
What is a Mimic Panel ?
Importance of Fire & Gas Detection
Argonite Fire Suppression System
Fire Alarm System Questions
Standard Gas Detection Definitions
Flame Detector Testing Procedure
Factors for Setting Alarm Levels on Toxic Gas Detectors
Smoke Detector Testing Procedure
Infrared Hydrocarbon Gas Detector Calibration Procedure
Basics of Foam Fire Fighting System
Fixed Gas Detectors vs. Portable Gas Detectors
Flame Detectors Working Principle
Chlorine Gas Hazards
Carbon Monoxide Gas Hazards
How to identify location of Fire Detectors
Fire and Gas System Interview Questions & Answers
Selection Criteria for Toxic Gas Detector
What is Gas Suppression Systems ?
Deluge Valve Operation
Deluge Valve Working Principle
Difference Between Passive and Active Fire Protection
Active and Passive Fire Protection
Rate of Rise Thermal Detectors Working Principle
Gas Detection System Abbreviations
What is an FACP
What is an FACP? (Fire Alarm Control Panel)
Infrared Gas Detectors Principle
Infrared Gas Detectors Working Principle
fire alarm system operation
What is Fire Alarm System?
Fire Hydrant System
Basics of Fire Fighting Hydrant Systems
PLC Program for Daily Production Record
PID Control Theory
Overview of PID Control terms
Safety in Automation Systems
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
SCADA Systems
SCADA Systems
On Delay Timer using PLC
ON Delay Timer using PLC
Difference between Analog Signal and Digital Signal
Single-Phase Full Wave AC-DC Converter Objective Questions
