Reading: How ANSI Class Relates to PSI ?
Inst Tools > Blog > Common > How ANSI Class Relates to PSI ?
Last updated: August 9, 2020 6:30 pm
Common
3 Min Read
Take a look through our website and you’ll see most of our pressure ratings are expressed as PSI – pounds per square inch.
In this article, we’d like to talk about the exception to that rule, which is the ANSI class rating.
Let me just start by saying this article is more of an introduction to the ANSI class system than an all-inclusive explanation.
To fully understand the system, you’ll want to research the documentation provided by the ANSI as described below (ANSI B16.5). It’s dozens of pages long and cannot be expressed in just a few paragraphs.
ANSI CLASS
ANSI stands for American National Standards Institute, which oversees the measurement standards in the United States.
ANSI works along with the American Society of Mechanical Engineers (ASME) to identify acceptable standards for all kinds of mechanical measures – from pipe thread taper to acoustic signal processing.
The standard we are concerned with is the ANSI B16.5, the class system for measuring allowable non-shock pressure as related to temperature.
It is very similar to a PSI and the pressure rating could be expressed as either an ANSI class or PSI. You can find both listed on a variety of parts.
Some parts, though, are more commonly associated with classes than others. Specifically, I am talking about parts with flanged connections (i.e. bolt connections rather than threaded). Most valves with flanged connections are traditionally expressed in ANSI classes.
As far as I can tell, it’s just one of those quirks of the market.
This chart is an example of ANSI pressure class ratings for specific grades of steel. Please consult the ANSI B16.5 for pressure ratings of particular materials.
SO, HOW WOULD YOU CONVERT AN ANSI CLASS TO A PSI RATING AND VICE VERSA?
Great question! I knew there was a reason I liked you.
For that, we need to look at the type of material being used.
Different materials rated in specific classes react differently as the temperature changes.
Understand that if you are putting this information into practice, you should really look up ANSI B16.5.
DO NOT rely solely on the chart above (to the right). It reflects a specific group of materials.
Next, we will convert the classes to megapascals (Mpa), another pressure measure which relates better to the class system: Class 150 equals 2.0Mpa; Class 300 is 5.0Mpa; Class 400 is 6.3Mpa; etc.
The conversion rate is 1 PSI = 0.0069Mpa. Multiply the psi rating by 0.0069 and that will give you the Mpa related to the class.
The chart above (to the right) lists out each of the classes and their corresponding megapascal ratings, as well as the way that temperatures affect the performance of the valve.
Author : Kirk Dickey
Reference : directmaterial.com
Also Read : Difference between NPT, BSPP & BSPT Seals
Difference Between Predictive Maintenance and Preventive Maintenance
Difference Between Belt Conveyor and Roller Conveyor
Different Types of HVAC Applications
Why PDMS is Used For Fabrication?
What is Optical Modulation? – Methods of Optical Modulation
How to Begin Learning Programming and Succeed?
  • ayub says:
    August 13, 2018 at 1:19 am
    a very nice one for me, now I understood
    thanks a lot, bro
Why does SMPS Need isolation? – Switch Mode Power Supply
Steps Followed Before Creating CNC Program
Strip Chart Recorder Working Principle
7 Investments for Single Mothers
Advancements in Lime Slaking Technology: What’s New And What’s Next
Data Preparation for AI: For Successful Machine Learning
Important Applications of Rapid Prototype CNC Machining Services
ISA Codes & Symbols for Process Instrumentation
Hydraulic Systems
Instrumentation Word Game
Load Cell Assembly
Urea Bagging Plant – Process Flow
Ultrasonic Thickness Gauge
How to Use a Paint Thickness Gauge?
7 Marketing Strategies for Engineering Companies
What is Transparent Solar Panel
What is Transparent Solar Panel? – Working Principle and Theory
Artificial intelligence in supply chain management
Good and Bad Wiring Practices
Relation Control
Relation Control System
Why is Motor Control Required in Control Systems
Why is Motor Control Required in Control Systems?
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
heated instrument enclosures
What is Instrument Heated Enclosure or Protection Box?
Library of PlantPAx Process Objects
Root Cause Analysis on Hunting of Control Valves
Parity Checkers Objective Questions
Understanding the Chiller Maintenance - HVAC Tutorials
Understanding the Chiller Maintenance – HVAC Tutorials
