Reading: How to Configure an Alarm in InTouch SCADA?
Inst Tools > Blog > PLC Tutorials > How to Configure an Alarm in InTouch SCADA?
Last updated: March 4, 2021 12:06 pm
3 Min Read
Alarms are used to give a warning message or to alert us to do something about it. Learn how to configure an alarm in InTouch SCADA software.
Likewise, In industries, there are many processes where there is a certain set point and if the process variable goes beyond the set point we need an alarm to display a message.
Now we are gonna see how to implement an alarm in Intouch SCADA.
Imagine that we are programming to show an alarm for a tank filling process. And the PLC should read the input from LT1 (Level Transmitter)
I am gonna add a slider to the window. And when I increase the slider’s value it reflects it on the tank.
InTouch SCADA Tank Design
Now let’s give the tag name for the slider as LT1 and define it as Memory real data type.
So basically the slider will act as a sensor. Except it is used for simulation purposes for better understanding the concept.
Also, we are gonna give the Percent fill of the tank the same tag name as the slider so whenever the slider increases the value reflects on the tank.
To implement the Alarms concept we are going to navigate to the alarms section while defining the tag name. And enable the LoLo, Low, Hi, HiHi alarms.
InTouch tagname Dictionary
Intouch has many alarm priorities from 0 to 9999. We can prioritize accordingly so that we know that whenever the alarm with high priority pops up we need to give more importance for that alarm.
Configure Tag in InTouch Scada
Now let’s add an alarm display to the window to view the alarms.
Add an alarm display to the graphics.
Let’s go to the run time and see how the alarm display works.
As you can see in the series of images below, the alarm displays a message at each stage of the process.
Also, note that the priority number is also being displayed in the images.
When the Level Transmitter (LT1) is at 0%
SCADA Alarm Configuration
When the Level Transmitter (LT1) is at 10%
When the Level Transmitter (LT1) is at 80%
When the Level Transmitter (LT1) is at 100%
Author: Abishek D
  • Scaling with Parameters
  • Namur Digital Input Card
  • Allen Bradley Powerflex VFD
  • Voltage Signal Systems
  • InTouch Scada using Scripting
Communicating Delta PLC Software to Simulator
Tia Portal – Different Instances of Calling a Function Block
PLC Memory Organization – Data Files and Program Files
Allen Bradley Math Functions
SCADA Communication and Protocols
Problem on PLC, HMI, VFD, and Motor Circuit
PLC Logic for Automatic Bending Machine for Exhaust Pipe
1oo2 Evaluation Safety Instruction in Safety PLC
How to Convert Current to Voltage using Resistor ?
Equivalent Logic Gates using PLC Ladder Diagrams
Tia Portal – OB20 Time Delay Interrupt Organization Block
PLC Latching Function
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
Redundant system communication cable
What is Interface Module in Siemens PLC?
Interlock Philosophy
Types of Interlocks
PLC Programming for Train Detection and Gate Operation
Coil Type Timers in Siemens PLC Programming
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
Diode-positive-limiter
Positive & Negative Diode Clippers
Pressure Transmitters Purged impulse lines - 2
Nonlinear Control Systems
Electromagnetic Field Test Questions
DCS Vs PLC
DCS versus PLC Architecture
PLC Program for Washing Machine
Foundation Fieldbus Interview Questions and Answers
PLC program for VFD Drive Multiple Speeds
Drive Multiple Speeds with Different Reference using PLC
