Reading: PLC Programming Example on LED Control
Inst Tools > Blog > PLC Tutorials > PLC Programming Example on LED Control
Study the PLC programming example on LED control using the ladder logic diagram and learn the program description.
Last updated: March 12, 2024 3:14 pm
PLC Programming LED ControlDigital InputsDigital InputsLadder Diagram for LED ControlPLC Program DescriptionWhen Switch 1 and Switch 2 are ONWhen Switch 2 and Switch 3 are ONPLC Tutorial Video
This PLC example is for engineering students who are interested in learning and practicing the PLC exercises. The real-time industrial PLC programs will be provided with more safety features.
We are using three toggle Switches to control three LED’s
  • If Toggle Switch 1 and Toggle Switch 2 are ON, then LED 1 and LED 2 will be ON.
  • If Toggle Switch 2 and Toggle Switch 3 are ON, then LED 2 will be OFF, and LED 3 will be ON.
Digital Inputs
The required inputs are listed below.
Toggle Switch 1: I0.0
Toggle Switch 2: I0.1
Here we call these toogle switches as simple “Switch” in our next discussions, But remember these are toggle-type switches.
Digital Inputs
The required outputs are listed below.
LED 1: Q0.0
LED 2: Q0.1
LED 3: Q0.2
  • For this application, we used EcoStruxure Machine Expert Basic v1.2 software for programming.
  • In the above program, we have used Normally Open Contacts for Switch 1 (I0.0), Switch 2(I0.1), and Switch 3 (I0.2). We have also used Normally Closed Contact for Switch 3 (I0.2).
  • Switch 1 and Switch 2, present in Rung0 are connected in series for LED 1 and LED 2, thus implementing AND logic gate.
  • With Switch 1 and Switch 2, Switch 3 is connected to LED 3 as Normally Closed Contact.
  • For LED 3, Switch 2 and Switch 3 present in Rung1 are connected in series, thus implementing the AND logic gate.
  • For LED 1 to be ON, Switch 1 and Switch 2 should be ON.
  • When Switch 1 and Switch 2 are turned ON and Switch 3 is OFF, then LED 2 will be ON.
  • When Switch 2 and Switch 3 are ON, LED 3 will be ON.
  • Turning ON Switch 3 will turn OFF LED 2.
PLC Programming LED Logic
In Rung0, the signal through Switch 1 and Switch 2 when turned ON.
As a result, LED 1 and LED 3 will turn ON. Switch 3 is used as a Normally Closed Contact for Switch 3 when in a false state, it will allow the signal to turn ON LED 2.
The signal through Switch 2 and Switch 3 in Rung1, that turns ON LED 3.
In Rung0, switch 3 is taken as Normally Closed Contact, when in the true state, it will not allow signal to pass through it. As a result, LED 2 will turn OFF. Switch 3 is connected to LED 1 and therefore, it will remain ON.
PLC Tutorial Video
You can also watch the tutorial video below for this LED control PLC example program.
LED Control in PLC using Switch Inputs: Example-Based Learning
  • PLC Objective Questions
  • True or False PLC Quiz
  • PLC Multiple Choice Questions
  • Troubleshooting PLC
  • PLC Animation
Top 100+ SCADA Questions
How to Work with Allen Bradley RsLogix Emulator?
FIFO Instruction in Allen Bradley PLC Programming
PLC Interview Questions and Answers
What is Process Control?
1 to 8 Demultiplexer PLC ladder diagram
What is NOR Flash Memory in PLC?
Software Troubleshooting Errors and Faults in Siemens PLC
Applications of SCADA
PUT Command in Siemens PLC – TIA Portal Basics
Automatic Door Operation PLC Programming and Simulation
How to Select the Right Encoder for Your Machine?
HMI Simulation for PID Controller
PID Controller Output Types – PID_PWM and PID_Output
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
Allen Bradley PLC to PLC Communication in Studio 5000
Create an Application in HMI using Tia Portal
Industrial motor control using PLC instruction list programming
PLC Instruction List for Motor Reverse and Forward Direction
PLC Subroutine
Allen Bradley PLC Subroutines
SCADA and HMI Systems - Differences, Similarities, Purpose
SCADA and HMI Systems – Differences, Similarities, Purpose
Worldwide Voltage & Frequency Values
electromechanical-level-measurement-working-principle
ElectroMechanical Level Measurement Working Principle
Automatic Liquid Mixing Application
Dual Converters Multiple Choice Questions
What is a Bourdon tube
Bourdon Tube Pressure Gauge Advantages and Disadvantages
MOSFET Objective Questions
Temperature Control System Example
Chemical Reactor Temperature Control System
