Reading: Dependent Voltage Source
Inst Tools > Blog > Electronic Devices & Circuits > Dependent Voltage Source
Last updated: October 6, 2016 6:33 am
2 Min Read
Dependent Sources
An ideal source, either voltage or current, whose value depends upon some parameter (usually a voltage or current) in the circuit to which the source belongs is known as a dependent or controlled source.
The Dependent Voltage Source
A dependent voltage source establishes a voltage across its terminals, independent of the current through it, which is determined by the voltage or current at some other location in the electrical system. There are two types of dependent voltage source – the voltage-controlled voltage source (VCVS) and the current-controlled voltage source (CCVS).
Note that the dependent source is represented by a diamond-shaped symbol so as not to confuse it with an independent source.
These  sources  are  mathematical  models  that  are  useful  in  modelling  real circuits and systems, e.g. they are used in modelling operational amplifiers.
Example:
Consider the circuit shown below. This circuit contains a dependent source whose value in this case depends on the voltage across the 4 Ω resistor – it is a VCVS.
dependent-voltage-source-circuit-example
To analyse the circuit, we apply KVL and obtain:
v1 – 3v2  + v2  = 12
or:
v1 – 2v2  = 12
By Ohm’s Law:
v1  = 2i
and
v2  = 4i
Therefore:
2i – 2(4i ) = 12
2i – 8i = 12
– 6i = 12
i = -2 A
Hence:
v2  = 4i = -8 V
and the value of the dependent voltage source is:
3v2  = -24 V
Permanent Magnet Moving Coil Instruments (PMMC)
Full Wave Voltage Doubler using Diodes
Difference between ideal diode & conventional diode
Schottky Diode Working Principle
Freewheeling Diode Working Principle
Summary Of Transistor Bias Circuits
Current Divider Rule
Basic Electronics Questions & Answers
Comparison of Half wave Rectifiers and Full wave Rectifiers
Types of Resistors
Amplifiers Questions & Answers
Voltage Divider Rule
Full Wave Rectifier
Transistor as an Amplifier in Common Emitter
Bipolar Junction Transistor Construction
Peak Inverse Voltage of Center Tap Rectifier
Derivation-of-Ohms-Law
Basics of Ohm’s Law
How a Multi Color LED Works
How a Multi Color LED Works ?
Dependent Current Source
What is a Memristor
What is a Memristor? Principle, Advantages, Applications
Diode-positive-limiter
Positive & Negative Diode Clippers
Semiconductors Diodes Questions & Answers
number-systems-questions-answers
Number Systems Questions & Answers
Single Phase Voltage Source Inverter Quiz
Safety Questions and Answers
PLC Program to Separate Different Size Objects
Flip Flops Objective Questions – Part 1
Transformer as a Magnetically Coupled Circuit
field-transmitter-communication-troubleshooting
Field Transmitter Communication Troubleshooting
Motor ladder Logic
