Reading: Working Principle of Overload Relay
Inst Tools > Blog > Electrical Basics > Working Principle of Overload Relay
In this post, we will learn the working principle of overload relay, types, and applications.
Last updated: October 17, 2023 1:55 pm
Electrical Basics
Overload RelayTypes of Overload RelaysBimetallic Thermal Overload RelayElectronic Overload RelayApplications of Overload Relays
Motor overload is defined as a condition where the motor draws excessive load current and heats it up. This condition can damage the motor windings.
To protect it from damage, an overload relay is used in series with its contactor; to protect the motor from overload and over-current. It is used in almost every motor starter.
The function of the overload relay is to continuously sense the load current and tripping the power supply to the motor. Thus, the motor is protected from overload and over current.
Overload Relay
Refer to the below image for its general connection. The three-phase supply from raw incoming power is fed to a contactor through MCB; and then to the motor through an overload relay.
The overload relay continuously monitors the load current drawn and cuts off the power supply when it exceeds a certain high limit.
Usually, the relay has the following terminals – L1, L2, L3 (for incoming power); T1, T2, T3 (for outgoing power), auxiliary contact for providing feedback to any control circuit; ampere range knob setting in the relay; trip reset button and a test button to test the control wiring.
Basically, this relay works in the principle of thermal heating. As current increases, the temperature of phase windings in the motor and wire too increases.
This temperature is sensed to determine the overload condition and when the temperature exceeds a predefined high set value, it trips the circuit.
Owing to this working, there are two types of overload relay –
  1. bimetallic thermal overload relay and
  2. electronic overload relay.
In the bimetallic relay, a bimetallic strip is used and is placed in the circuit in such a way that the current flows through it.
The strip gets heated continuously due to its properties. When the current exceeds the limit, it gets heated in such a large way that it breaks the contact with the outgoing supply from it.
This is the traditional working of an overload relay. An overload relay was founded on the basis of this working principle.
In an electronic relay, temperature sensors and current transformers are in the motor circuit to sense the rise in temperature and current.
PTC sensors are used to sense temperature. Due to use of microprocessors and sensors, the sensing technology of this type of relay is much accurate than a traditional bimetallic relay.
Also, the heat losses inside the relay are much lesser in this type than a bimetallic relay.
Overload relays are extensively used in control circuits of motors; as they provide an auxiliary contact to the PLC.
This helps in additional protection of the overall circuit. You just have to set the tripping current in the relay according to your needs and also select the relay based on trip class.
Trip class is nothing but a trip check timer. It varies depending on various classes and considers the corresponding check timer to trip the circuit when it has sensed overload condition.
  • Motor Controller
  • Motor Protection Circuit
  • Bimetallic Thermometer
  • Contactor and its Principle
  • Spiral Bimetallic Thermometer
What are Inverse Time and Instantaneous Trip Circuit Breakers?
Importance of Neutral Wire
What is a VFD? – Theory, Advantages, Disadvantages
How Do Electrical Shorts and Ground Faults Trip Circuit Breakers?
How to Check the Continuity of Protective Conductors?
One Nation One Grid One Frequency – Electrical Engineering
Why is IGBT used in VFD?
Cells and Batteries – Types, Applications, Explanation
What is ELCB? Principle, Advantages, Disadvantages, Applications
Motor Control Circuit Wiring
Difference Between Short Circuit and Ground Fault
What is Electrical Panel Door Earth Bonding? Explained
Motor VFD Drive features
Electrical Terminology
Circuit Breaker Making Capacity
What is Trunking
Difference Between Trunking and Conduit
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
Residual Current Circuit Breaker (RCCB)
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
Rotary UPS or Dynamic UPS
Applications of Electrical Conduit System
What is an Electrical Conduit? – Types – How to Choose?
PLC Program
Example PLC Program
car parking example logic
Up Down Counter Instruction in PLC
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
Venturi Flow Measurement Principle
Why Flow is Directly Proportional to the Square Root of DP?
Compressor IP Case Discharge Temperature Gradually Increases
Compressor Anti-Surge Control near-miss incident
Rotational Viscometer
What is a Viscometer? – Types, Applications, Advantages
Metering components to measure flow of Natural gas
Is it Easy to Measure Natural Gas Flow and Volume?
Electric Circuits Objective Questions – Set 4
