Reading: Why Fire and Gas Detectors are 3-Wire types instead of 2 Wire?
Inst Tools > Blog > Fire & Gas System > Why Fire and Gas Detectors are 3-Wire types instead of 2 Wire?
Fire and gas detectors often use a 3-wire system rather than a 2-wire system for better functionality and safety.
Last updated: June 19, 2023 11:29 am
Fire & Gas System
3 Min Read
Why Fire and Gas Detectors are 3-Wire Types?2-Wire Detectors3-Wire Detectors4-Wire DetectorsConclusion
Both 2-wire (also known as loop-powered) and 3-wire (typically, but not always, a separate powered device) detectors can use the 4-20 mA standard for analog signaling in industries. This standard is used because it’s relatively immune to noise and voltage drops over long distances.
2-Wire Detectors
In a 2-wire system, the device gets its power from the loop itself. It’s advantageous because it simplifies wiring and reduces installation costs. The devices regulate the current on the loop to represent the measured parameter (e.g., gas concentration). However, the power available to the device is limited by the loop voltage and resistance.
Therefore, if the fire and gas detector requires more power to operate correctly (for example, for heaters in certain gas detectors, or for advanced diagnostic capabilities), a 2-wire system may not be adequate.
3-Wire Detectors
In a 3-wire system, the device has a separate power supply, which means it’s not limited by the loop voltage and can, therefore, handle more power-intensive operations. This can be advantageous for devices that need additional power, beyond what the 4-20 mA loop can provide, to function correctly or for additional features.
So having a separate power supply can provide redundancy and improve system reliability in case of a failure in the 4-20 mA loop.
4-Wire Detectors
We can also go with 4-wire detectors but they will increase the project costs due to additional wire and lead to high-installation costs when compared to 2-wire and 3-wire detectors.
Conclusion
The 4-20 mA signals inherently mitigate issues of voltage drop over long cable runs, the distinction between 2-wire and 3-wire devices has more to do with power availability for the device operation rather than signal integrity.
The preference for a 2-wire or 3-wire system would depend on the specific needs of the detector and the power availability and requirements of the particular installation. For a device with higher power requirements or sophisticated functionality, a 3-wire system may be more appropriate, whereas a 2-wire system may be more suitable for simpler devices or for installations where wiring costs need to be minimized.
  • Fire Fighting System
  • Industrial Flame Detectors
  • Gas Detectors Practical Problems
  • Ultrasonic Gas Leak Detectors
  • Infrared Open Path Gas Detector
Which Gases Can a Multi-Gas Detector Detect?
Hydrogen Sulfide Gas Detector Calibration Procedure
What is a Fire Pump? – Definition, Principle, Types, Comparison
Interview Questions on Fire Alarm System
Overview of Fire/Smoke/Flame/Heat/Gas Detectors
Heat Detector Testing Procedure
  • Hénoc Mulumba says:
    June 28, 2023 at 10:56 pm
    What do I need to follow all the courses in full and what are your conditions because I want to improve my skills in Instrumentation and control? And also is there a way to follow in French
Infrared Open Path Gas Detectors Working Principle
What is a Fusible Plug? – Working, Advantages, Disadvantages
Fire and Gas system Audible and Visual Alarms
Fire Dampers in Fire Protection
Active and Passive Fire Protection
Basic Guidelines for Selection of Fire and Gas Detectors
Catalytic Gas Detectors Principle
Deluge System for Transformer Protection Animation
Fire and Gas System Interview Questions & Answers
Gas Suppression System
What is Gas Suppression Systems ?
Deluge Valve Operation using Solenoid Valve Animation
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
Flammable Gases and Vapors Class 1 & Class 2
Gas Detectors Standards
How to identify location of Fire Detectors
foam fire protection system
Basics of Foam Fire Fighting System
Beam-Detectors-Working-Principle-2
Beam Detectors Working Principle Animation
Control Valve Parts
Control Valve Parts Questions and Answers
Analog Demodulators Objective Questions
Automatic Box Filling System using PLC Programming
AND Gate Logic Animation
Digital Building Blocks – GATES
Firmware Version in Siemens PLC
What is the Firmware Version of a PLC? – Siemens PLC Hardware
Types of Diodes Objective Questions
PLC Programming for Level Switches
PLC Programming using Level Switches
quantum computer
Vacuum Technology is Enabling New Era of Ultra-Powerful Computers: Quantum Computing
