Reading: What is a Square Root Extractor? – DP Flow Measurement
Inst Tools > Blog > Flow Measurement > What is a Square Root Extractor? – DP Flow Measurement
In the olden days of DP Flow Measurement, the square-root function was performed in a separate device called a square root extractor.
Last updated: November 2, 2023 12:16 pm
Flow Measurement
The relationship between flow rate and differential pressure for any fluid-accelerating flow element is non-linear. When plotted on a graph, the relationship between flow rate (Q) and differential pressure (∆P) is quadratic, like one-half of a parabola.
Relationship of Flow rate and Differential pressureSquare Root ExtractorInternal Parts of Square-root ExtractorPneumatic Square Root Relay
Differential pressure developed by a venturi, orifice plate, pitot tube, or any other acceleration-based flow element is proportional to the square of the flow rate:
Differential Pressure Transmitter Square-root
The traditional means of implementing the necessary signal characterization was to install a “square root” function relay between the transmitter and the flow indicator, as shown in the following diagram:
Square root extractor for DP flow measurement
In the days of pneumatic instrumentation, this square-root function was performed in a separate device called a square root extractor.
The Foxboro model 557 (2) and Moore Products Model 65 (1) pneumatic square root extractors are classic examples of this technology :
What is Square root extractor
Square root extractor Parts
Pneumatic square root extraction relays provide a square-root function that the relays were able to serve their purpose in characterizing the output flow signal of a pressure sensor to yield a signal representing flow rate.
The following table shows the ideal response of a pneumatic square root relay:
As you can see from the table, the square-root relationship is most evident in comparing the input and output percentage values.
For example, at an input signal pressure of 6 PSI (25%), the output signal percentage will be the square root of 25%, which is 50% (0.5 = √0.25) or 9 PSI as a pneumatic signal.
At an input signal pressure of 10 PSI (58.33%), the output signal percentage will be 76.38%, because of 0.7638 = √0.5833, yielding an output signal pressure of 12.17 PSI.
When graphed, the function of a square-root extractor is precisely opposite (inverted) of the quadratic function of a flow-sensing element such as an orifice plate, venturi, or pitot tube:
When we connect the output of the DP transmitter to the input of Square Root Extractor, the square-root function applies to the output signal – the result is an output signal that tracks linearly with flow rate (Q).
An instrument connected to the square root relay’s signal will, therefore, register the flow rate as it should.
Note: We are not using the square-root extractor devices anymore, these are replaced with modern DP Transmitters.
The modern solution to this problem is to incorporate square-root signal characterization either inside the transmitter or inside the receiving instrument (e.g. indicator, recorder, or controller).
Either way, the square-root function must be implemented somewhere in the loop in order that flow may be accurately measured throughout the operating range.
Read: Square-root in DCS or Transmitter?
Author: Tony R. Kuphaldt
  • Flow Meter Calibration
  • Averaging Pitot Tube
  • Flow Meter Verification
  • MPFM Working Principle
  • Flow Transmitter Questions
Orifice Flowmeter Rangeability
Configure the Instruments in Flow Control Loop
Optical Flow Meter Principle
Flow Transmitter Rangeability
Vortex Flow meter Animation
Short Notes on Differential Pressure Flow Meters
Different Types of Flow Elements
Coriolis Meter Explained with Animation
Orifice Plate Turndown ratio
Basics of Venturi Flow Meter
Open Channel Flow Measurement Principle
Flow Transmitters Questions and Answers – Instruments Test
Flow Measurement
Continuous Flow Measurement
How to Select a Rotameter? – Parameters and Applications
Types of Flow Meters MCQ - Instrumentation and Control
Types of Flow Meters MCQ – Instrumentation and Control
Flow Meter Reading Unstable
What Factors Affect the Stability of Flow Meter Readings?
Flow meter Turndown Ratio
Importance of Flow Meter Turndown Ratio
Volumetric Flow Calculations
Ultrasonic Flowmeters Principle
Factors Affecting the Performance of Ultrasonic Flow Meters
Demystifying Reynolds Number
Why Viscosity is Not Included in the Orifice Equation?
Remote User Authentication
Security of Industrial Automation Systems
3φ AC Power Connections
Three Phase Systems
Applications of SCADA
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
Digital Instrument Example
Digital Measuring Instruments – Types, Functions, Advantages, Disadvantages
PLC program to control a water pump
PLC Program to Control a Water Pump
Liquid Crystal Display Objective Questions
thermocouple voltages
Manually Interpreting Thermocouple Voltages
