Reading: Working of Rupture Disk
Inst Tools > Blog > Control Valves > Working of Rupture Disk
Last updated: March 21, 2019 11:42 pm
Control Valves
2 Comments
A Rupture Disk is a non-reclosing pressure relief device actuated by static differential pressure between the inlet and outlet of the device and designed to function by the bursting of a rupture disk.
What is Rupture Disk ?Terms Related with Rupture Disc:
A rupture disk device includes a rupture disk and a rupture disk holder.
A rupture disk holder is the structure which encloses and clamps the rupture disk in Position
Burst Pressure:
The burst pressure of a rupture disk at the specified temperature is the value of the upstream static pressure minus the value of the downstream static pressure just prior to when the disk bursts.
When the downstream pressure is atmospheric, the burst pressure is the upstream static gauge pressure. The specified burst pressure is the burst pressure specified by the user.
Now the manufacturer takes the min of two rupture disc per lot and performs the test.
Here comes the two term Marked burst pressure and Manufacture range.
Marked Burst Pressure:
The marked burst pressure, or rated burst pressure of a rupture disk, is the burst pressure established by tests for the specified temperature and marked on the disk tag by the manufacturer.
Now what value is to be marked? It may be specified burst pressure or any value other than specified burst pressure. It is decided by manufacturer range.
Manufacturer Range:
The manufacturing range is the pressure range in which the rupture disk shall be marked. Manufacturing ranges are usually catalogued by the manufacturer as a percentage of the specified burst pressure. Catalogued manufacturing ranges may be modified by agreement between the user and the manufacturer.
For zero manufacturing range rupture discs, a minimum of two burst tests per lot of rupture discs are conducted to determine conformance with the customer’s specified burst pressure. The rated (stamped) burst pressure appearing on the tag will be the customer’s specified burst pressure.
For rupture discs with -5%, -10%, -2.5psig, or -5 psig manufacturing ranges, the rated (stamped) burst pressure is established by bursting a minimum of two discs per lot and averaging the actual burst results. This average burst pressure is the rated (stamped)
burst pressure which will appear on the rupture disc tag.
Now here it is best to tell about Burst pressure tolerance. Burst pressure tolerances the variation around the Marked burst pressure (not around specified burst pressure ) at the specified disk temperature in which a rupture disk shall burst.
In order to maximize the life of the rupture disc, manufacturer recommends the maximum operating pressure for rupture disc called Maximum Recommended Operating Pressure. Reverse-acting rupture disks provide satisfactory service life when operating pressures are 90% or less of marked burst pressure (90% operating ratio). Consult the manufacturer for the actual recommended operating ratio for the specific disk under consideration.
Also Read: Fundamentals of Control Valves
Types of Pneumatic Actuators Animation
Snap Acting Relay Working Principle
Trip Valve Principle
Basics of Gate Valves
Identify Valve Parts Quiz with Answers
Control Valve Cv calculation
2 Comments
  • Jekker says:
    February 8, 2016 at 11:42 pm
    Admin of instrumentationtools.com Excellent & Superb.
    Article useful, the main thing that helped people, Respect to you!
  • Imran Malik says:
    December 12, 2021 at 4:50 pm
    Good article, Just wondering what shall be difference between a design fit for Gas and Another for LIQUID service?
Locked Open (LO) and Locked Closed (LC) Valves
Control Valve Flow Direction
Calculate Flow Coefficient Kv of Solenoid Valve
Control Valves Chemical attack Problems
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Self Actuated Pressure Control Valve Principle
Types of Control Valve Trim
Basics of Globe Valves
Valve Bellows seal
Bellows Seal Valve Working Principle
Procedure for the Repair of Control Valve
Basic Steps and Procedure for the Repair of Control Valve
3-port-2-position-direct-acting-solenoid-valve
3 Port 2 Position Direct Acting Solenoid Valve Working Principle
Dual Solenoid Valve on Control Valve
Why we Require Dual SOV on a Control Valve?
Safety Valve
Compare Relief Valve and Safety Valve
valve-actuator
Pneumatic Control Valve Actuators
Direct operated (direct acting) solenoid valves
Solenoid Valves Types & Functions
Basics of Actuators
Basics of Actuators
Butterfly Valve
Butterfly Valves Construction, Types, Stem & Bonnet Assembly
hall effect speed sensor
Speed Probe Working Principle
Three Phase Induction Motor Interview Questions & Answers
Types of Digital Outputs in PLC
Programmable Logic Controller (PLC) Questions and Answers – 9
Differential Pressure Sensor with pair of Strain Gauges
Differential Pressure Sensor with Pair of Strain Gauges
Brands PLC communication interface and protocol
Communicating Between Siemens PLC and Other PLC Brands
