Reading: What is an Automotive Radiator?
Inst Tools > Blog > Common > What is an Automotive Radiator?
An automotive cooling system consists of a radiator, fan, water pump, coolant reservoir, thermostat, and necessary piping in a car engine.
Last updated: September 28, 2022 4:13 pm
Common
In this post, we will see the concept of automotive radiators.
Automotive Cooling SystemAutomotive Radiator
We all know how ventilation and cooling is an important factor deciding the use of HVAC. HVAC finds its use in each and every part of our daily life cycle. You cannot survive with clean and liveable air around.
In the same way as humans, let us see it’s another important use in cars. We all know about car engines, but only some of us know how it cools down in running condition.
Overheating of engines can damage the overall performance of the car. So, every automotive engine requires a cooling system in order to keep itself cool. One such component of this cooling system is a radiator.
Radiators are terms familiar to automation engineers in HVAC systems. The same concept is used in the working of a car engine’s cooling system.
Car Cooling System Automotive Radiator
An automotive cooling system consists of a radiator, fan, water pump, coolant reservoir, thermostat, and its necessary piping. Heat exchange takes place inside the engine to dissipate heat from the engine.
The sequence starts from coolant reservoirs, which have the coolant liquids stored in them. It is similar to refrigerant gas flowing in the compressor system.
The coolant liquid is flown in the whole engine circuit through a water pump. The coolant absorbs the heat generated from the engine. According to the heat transfer mechanism, heat flows from hot to cold surfaces. So, the heat is dissipated in the coolant liquid.
The thermostat is a sensor-type device that continuously monitors the temperature of the coolant liquid. Typically, when the coolant liquid temperature is raised above the engine operating temperature (200-250 deg. Celsius), the thermostat allows the coolant to pass to the radiator inlet.
So, it basically acts like a regulating valve. Thermostats consist of a chamber filled with wax and a rod that is pressed against it.
Due to an increase in temperature, the wax begins to melt. This melting causes thermal expansion of the wax which pushes the rod and allows the coolant to pass to the radiator.
Automotive Radiator
Once the coolant enters the radiator, the fan is turned on automatically. It is similar to condenser fans in a compressor circuit. Radiators are similar to heat exchanger evaporators used in HVAC systems.
As the fan rotates, the coolant which is flowing in the radiator pipes dissipates the heat in the outer air.
When the coolant reaches the outlet of the radiator, its temperature has been reduced to a great extent. This coolant is then circulated in the cycle again. This whole concept is thus a part of the HVAC system due to the heat transfer mechanism.
Cars when moving support the concept of radiators in a great way due to incoming air flow in a great deal. But, when cars are stationary or moving slow, the internal fans then play an important role.
Radiators require regular cleaning at intervals to prevent the fins and pipes of the radiator from catching up dust and dirt. Otherwise, radiators get choked up and will prevent proper cooling of the coolant liquid.
Radiators thus need to be properly maintained. Also, the level of coolant liquid needs to be checked in regular intervals to prevent overheating of the car engine. Radiators thus play an important role in the cooling system of automotive engines.
  • What is an Automated Guided Vehicle?
  • Wireless Electric Vehicle Charging
  • Voice Activated Automation System
  • Industrial Automation in the Mining Industry
  • Augmented Reality in Factory Automation
Circular Chart Recorder Calibration Procedure
What is C Programming Language? Fundamentals, Pros & Cons
Difference Between Resistive Touch and Capacitive Touch
Data Preparation for AI: For Successful Machine Learning
What is a Vent Filter? – Water Treatment Plant
What is an Instrument Skid? – Example of Metering Skid
Best Online Courses to Learn Electrical Engineering
What is a Solar Pump VFD? – Advantages, Principle
Difference Between Machine Learning and Artificial Intelligence?
5 Ways CNC Machining is Benefiting the Glass Industry
Electronic Diagrams, Prints and Schematics
Hard-Wired Control Logic for the Pressure Alarm
Optical Torsion Meter Principle
How are Data Centers Cooled?
Software Testing Projects
Software Testing Projects – How to Approach the Process Effectively?
Piezo-electric Acceleration Measuring Device
Do You Need a VPN on Your Home Computer?
refrigeration compressors
Why is CO2 the Most Promising Refrigerant in Cooling Industry?
IP transducer
Pilot Valves and Pneumatic Amplifying Relays
Computer Science and Technology Certifications
Computer Science and Technology Majors Certifications
Bracelet Scanner
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
PCB Assembly
Five Types of PCB Assembly that You Should Know
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
What is Hot Water Recirculation Loop
What is Hot Water Recirculation Loop? Advantages & Design
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Problem with Pirani Gauge
Gang Switch Principle
Reading Electrical Schematics
Purpose of Isolation valve
Repeat Failures of Letdown Valves
fundamentals of an AC motor
How does an Electric Motor Operate? – AC Motor Fundamentals
