Reading: What is an Auto Changeover Switch?
Inst Tools > Blog > Electrical Basics > What is an Auto Changeover Switch?
An auto changeover switch is used to automatically switch the electrical power between primary and secondary sources.
Last updated: November 29, 2022 3:33 pm
Electrical Basics
Electricity is a very basic need in our day-to-day life. In today’s world, it is almost impossible to survive without electricity; as almost all devices from a small fan to a PC to an AC work with electricity.
What is an Auto Changeover Switch?Types of ATS connectionsTypes of Switching Mechanisms in ATS
So, even a small amount of interruption for some period of time can hamper our lives. We get power supply from the primary source, which is directly from electrical power distribution grids. This is called a mains power supply.
But, for backup purposes, in case of mains power failure, other secondary sources are used like diesel generators, UPS, or inverters. Related to both of these, we will learn about an important device that is used for power supplies – auto changeover switch.
In this post, we will learn the concept of an auto changeover switch.
Suppose you have two sources of electricity – primary and secondary. Earlier, when the mains power supply went off, the operator used to go and manually turn on the secondary source power supply. This used to take time, especially if he is far away from the power source.
To solve this issue, an auto changeover switch was started to use. As the name implies, an auto changeover switch is used to automatically switch the power between primary and secondary sources. If the mains supply goes off or fails, then this switch will automatically connect the load to the secondary power supply.
On resumption of the mains power supply, this switch will again switch the load to the mains power supply. This acts similarly to a relay. So, this automatic switch acts as a very important element in immediately providing power supply.
It has a microprocessor inside which is programmed to control power supply switching. On one end, it senses the mains power supply and as soon as it senses that there is no supply, it will switchover to a secondary power supply like a diesel generator, UPS, or inverter.
At the same time, it is also sensing the mains power supply continuously, as it is the default connection. As soon as it senses the primary supply again, it will switchover to the mains supply again. Refer to the below image for more details.
It is to be noted that the name is an auto changeover, and it has a selection button – auto and manual. If it is in auto, then changeover will happen automatically; and if it is in manual, then changeover will require manual intervention.
There are various types of connections possible between the primary power supply and the secondary power supply.
Let us have a look at the most general ones available:
  1. Utility – Generator
  2. Utility – Utility
  3. Generator – Generator
Basically, there are two types of mechanisms that work in ATS – open transition and closed transition. Open transition means break-before-make.
Before changing any power supply connection, it will open the existing one first and then make a connection with the other one.
Closed transition means make-before-break. Before breaking any power supply connection, it will switch to the new one first and then break a connection with the previous one.
In this way, we understand the concept of an auto changeover switch.
  • Industrial Circuit Breakers
  • Electrical Motor Concepts
  • Relays in Air Circuit Breaker
  • Induction Motor Over Voltage
  • Purpose of Electrical Substation
Why do we need to Control the Motion using VFD drives?
What is Smart or Intelligent MCC?
Difference Between Circuit Breaker and Fuse
How to Read the Nameplate of a Motor?
What is Electrical Busbar? Types, Advantages, Disadvantages
  • Kyaw Kyaw says:
    December 1, 2022 at 9:31 am
    Thanks alot for sharing knowledge
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
What is SMPS? – Types of SMPS
What is a Protective Relay? Principle, Advantages, Applications
How Do Electrical Shorts and Ground Faults Trip Circuit Breakers?
What is a Buchholz Relay? Working Principle
Motor Control Center – Purpose, Classification, and Advantages
VFD Engineer Roles – Installation and Commissioning
What is Torque Boosting in Variable Frequency Drive (VFD)?
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
Why is Motor Control Required in Control Systems
Why is Motor Control Required in Control Systems?
Difference Between Regenerative and Dynamic Braking
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
What is a Time Delay Relay
What is a Time Delay Relay? Principle, Advantages, Disadvantages
Power Outlet
How does Electrical Power Outlet Work?
Variable-speed motor controls
Variable Motor Speed Control
Automatic Circuit Recloser
What is Automatic Circuit Recloser? Principle and Types
Emergency Shutdown System Philosophy
Shutdown Philosophy
DTS sensors
Distributed Temperature Sensors (DTS) in Power Lines
Guided-wave Radar Level Measurement Animation
Armature Quiz
What is Transparent Solar Panel
What is Transparent Solar Panel? – Working Principle and Theory
Turbine Flow Meter (TFM) Field Calibration
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 1
