Reading: What is a Weigh Feeder?
Inst Tools > Blog > Flow Measurement > What is a Weigh Feeder?
Most common weigh feeder design consists of a conveyor belt with a section supported by rollers coupled to one or more load cells.
Last updated: November 2, 2023 6:34 am
Flow Measurement
3 Comments
A special type of flow meter suited for powdered or granular solids is the weigh feeder.
One of the most common weigh feeder designs consists of a conveyor belt with a section supported by rollers coupled to one or more load cells, such that a fixed length of the belt is continuously weighed:
Weigh Feeder
Weigh feeder Principle
The load cell measures the weight of a fixed-length belt section, yielding a figure of material weight per linear distance on the belt.
A tachometer (speed sensor) measures the speed of the belt. The product of these two variables is the mass flow rate of solid material “through” the weigh feeder:
Weigh feeders formula
Where,
W = Mass flow rate (e.g. pounds per second)
F = Force of gravity acting on the weighed belt section (e.g. pounds)
v = Belt speed (e.g. feet per second)
d = Length of weighed belt section (e.g. feet)
A small weigh feeder (about two feet in length) is shown in the following photograph, the weigh feeder being used to feed powdered soda ash into water at a municipal filtration plant to neutralize pH:
Weigh feeder
In the middle of the belt’s span (hidden from view) is a set of rollers supporting the weight of the belt and of the soda ash piled on the belt. This load cell array provides a measurement of pounds material per foot of belt length (lb/ft).
As you can see in this next picture, the soda ash powder simply falls off the far end of the conveyor belt, into the water below:
Weigh feeder belt
The speed sensor measures belt speed in feet per minute (ft/min). This measurement, when multiplied by the pounds-per-foot measurement sensed by the load cells, translates into a mass flow rate (W) in units of pounds per minute (lb/min). A simple unit conversion (×60) expresses the mass flow rate in units of pounds per hour (lb/h).
A photograph of this weigh feeder’s display screen shows these variables:
Weigh feeder display
Note that the belt loading of 1.209 lb/ft and the belt speed of 0.62 feet per minute do not exactly equate to the displayed mass flow rate of 43.7 lb/h.
The reason for this discrepancy is that the camera’s snapshot of the weigh feeder display screen happened to capture an image where the values were not simultaneous. Weigh feeders often exhibit fluctuations in belt loading during normal operation, leading to fluctuations in calculated mass flow rate.
Sometimes these fluctuations in measured and calculated variables do not coincide on the display screen, given the latency inherent to the mass flow calculation (delaying the flow rate value until after the belt loading has been measured and displayed).
  • Load Cell Principle
  • Coriolis Mass meter
  • Conveyor using PLC
  • Load Cell Checks
  • Mass Flow Meters
Orifice Plate Questions and Answers
What is an Orifice Flange? – Purpose and Applications
Pressure Temperature Compensation Flow Measurement
Interview Questions on Flow Measurement
What is an Insertion Flow Meter? – Types, Principle, Advantages
Flow Meter K-factor and Calculations
3 Comments
  • Eswarateja says:
    July 29, 2018 at 3:23 pm
    Nice
  • R.Sridhar says:
    December 15, 2021 at 8:41 pm
    Very fine easy to understand.
  • Adnan khan says:
    September 7, 2023 at 12:38 pm
    How can calculate the load cell capacity according to the design capacity of feeder
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
Magnetic Flow Meter Animation
Flow Switch : What is it? – Applications
Short Notes on Differential Pressure Flow Meters
Calculate Flow Transmitter Output Current
Classification of Flow Measurement Techniques
Orifice Plate Tapping – Orifice Plate Taps
L2F insertion-style flowmeter
Optical Flow Meter Principle
Oscillating Piston Flow Meters Principle Animation
Venturi Flow Measurement Principle
Why Flow is Directly Proportional to the Square Root of DP?
Servo Operated Electro Magnetic Flowmeter Objective Questions
Orifice Specifications
Measuring Instruments
Flow Instruments – Selection, Principle & Application
Variable Area Flow Meters
All About Variable Area Flow Meters
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Structured Text PLC Example for Motor Interlocking and Control
Overview of Fire Detectors
Overview of Fire/Smoke/Flame/Heat/Gas Detectors
Single-Phase Induction Motors Multiple Choice Questions (MCQ)
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
Elevator Control
Perfume filling system PLC program
CX Programmer Example: Perfume Mixing and Filling System
Calibration Interview Questions and Answers
Variable Frequency Drive - Converter
Variable Frequency Drive (VFD) Working Principle
DP transmitter Elevated 10 Feet above the Vessel
