Reading: What is Differential Pressure Flow Meter?
Inst Tools > Blog > Flow Measurement > What is Differential Pressure Flow Meter?
A differential pressure flow meter works on the principle of partially obstructing the flow in the pipe and measures the flow rate based on DP.
Last updated: October 31, 2023 4:49 pm
Flow Measurement
5 Comments
12 Min Read
Differential pressure meters work on the principle of partially obstructing the flow in a pipe. This creates a difference in the static pressure between the upstream and downstream sides of the device.
What is a Differential Pressure Meter?Differential Pressure Flow MeterTypes of Differential Pressure Flow MeterPros and Cons of DP metersBeta (β)Effect of using different values of betaAdvantagesDisadvantagesDischarge coefficient (C)Turndown of a DP meterCalculating the mass flow rate using DP devices
This difference in the static pressure (referred to as the differential pressure) is measured and used to determine the flow rate.
Differential-pressure meters are hugely popular and it is estimated that at least 40% of industrial flow meters in use at present are differential-pressure devices, with the orifice plate being the most popular. Differential-pressure devices have been used to meter a wide variety of different fluids from gases to highly viscous liquids.
The popularity of differential-pressure flow meters is in part due to their simple design and low cost. By reading this guide you will have a much clearer idea of the benefits, viable metering options, and applications for using differential-pressure meters.
The concept of using the pressure drop caused by a fluid flowing through a restriction in a pipe as a measurement of flow rate dates back to the 18th Century, when it was discovered by Bernoulli.
The basic principle of how a Δp flow meter operates is described in the figure below.
How a flow meters works
The differential pressure principle. Manometer tubes measure the difference in static pressure upstream and downstream of the restriction
When a fluid flows through a restriction, it accelerates to a higher velocity (i.e. V2 > V1 ) to conserve the mass flow, and, as a consequence of this, its static pressure drops. This differential pressure (Δp) is then a measure of the flow rate through the device.
In simple terms for a given size of restriction, the higher the Δp, the higher the flow rate.
The relationship between the differential pressure and flow rate is derived from Bernoulli’s equation.
Using Bernoulli’s equation, and conservation of mass, it can be shown that the differential pressure generated is proportional to the square of the mass flow rate, Qm (kg/s)
DP Flow Meter Equation
Many of the Δp meters available work on this principle of measuring the difference in pressure between upstream and downstream but there are some meters that use the differential pressure in other ways, for example, variable area meters.
The most common types of differential pressure meter are:
  • Orifice plates
  • Venturi tubes
  • Cone meters (e.g. V-cones)
  • Nozzles
  • Low-loss meters (e.g. Dall tubes)
  • Variable area meters
  • Inlet flow meters
  • Venturi cones
  • Venturi nozzles
  • Drag plates
There are a number of general advantages common to most DP meters.
These include:
  • They are simple to make, containing no moving parts
  • Their performance is well-understood
  • They are cheap – especially in larger pipes when compared with other meters
  • They can be used in any orientation
  • They can be used for most gases and liquids
  • Some types do not require calibration for certain applications
The main disadvantages of DP meters are:
  • Rangeability (turndown) is less than for most other types of flow meter
  • Significant pressure losses may occur
  • The output signal is non-linear with flow
  • The discharge coefficient and accuracy may be affected by pipe layout or the nature of the flow
  • They may suffer from aging effects, e.g. the build-up of deposits or erosion of sharp edges
Common Terminology
Beta (β)
The diameter ratio or beta (sometimes referred to as the beta ratio) is the ratio between the diameter of the orifice or throat of the device to that of the pipe.
Orifice beta ratio
Often Δp meters are described in terms of their beta value and diameter to fit a certain pipeline size, for example, a 4-inch β= 0.6 Venturi tube.
To state that a Δp meter has a low beta ratio, for example, β = 0.2, means the plate has a small hole or restriction size.
This causes the pressure loss across the Δp meter to be higher, which may mean that a pump with a higher discharge pressure (hence more expensive) or compressor will be needed to overcome the increased pressure loss and maintain a flow rate achievable with a larger beta Δp meter.
On the other hand, a higher differential pressure can generally be measured more accurately than a lower one.
The effects of using larger values of beta include:
  • an increase in the discharge coefficient uncertainty
  • a lower differential pressure is measured across the orifice plate (and this can be more difficult to measure)
  • longer lengths of upstream straight pipe being required to ensure the velocity profile of the flow through the orifice plate is stable and symmetrical
  • the flow profile of the flow through the orifice being more affected by the roughness of the pipe walls
There are a number of sizing packages for orifice plates available, which will calculate the dimensions of the plate required. The software uses empirical formulae based on actual testing. Most of the results are available for beta values of 0.3 to 0.7.
Advantages
  • Low cost
  • Ease of installation
  • Availability of comprehensive standard (ISO 5167-2)
  • No requirement for calibration – the value of C from the standard
  • Availability of different designs, e.g. for viscous fluids, bi-directional flows, suspended solids
Disadvantages
  • Low turndown (can be improved with dual range Δp cells)
  • High-pressure loss (35 to almost 100% of measured Δp depending on beta)
  • Errors due to erosion/damage to upstream edges
  • Errors due to high sensitivity to upstream installation (especially large beta devices)
The discharge coefficient, C, is a parameter that takes account of non-ideal effects, for example, energy losses due to friction, when using Δp meters.
The discharge coefficient is basically the ratio of the actual to the measured mass flow rate.
The discharge coefficient can either be:
 1. determined from a standard
  •   provides good flow measurement at a reasonable price
  •    is especially suitable where repeatability is more important than accuracy
or
2. determined by calibration
  • provides lower uncertainties on the flow measurement.
In nozzles and Venturi tubes the flow follows the boundary of the tube closely and the value of C is usually close to one.
However, for orifice plates C has a value of approximately 0.6. Values of C can be obtained from the standard (ISO 5167) for nozzles, Venturi tubes and orifice plates that are manufactured to the specified tolerances of the standard.
The turndown of a meter is the ratio of the maximum to the minimum flowrate that can be accurately measured. Ideally a large a turndown ratio is desirable to measure a wide range of flowrates
Square relationship between flowrate and Δp:
  • If the flowrate is 50% of the full scale, then the Δp is at 25% of the full Δp scale
  • If the flowrate is 25% of the full scale, then the Δp is at 6.25% of the full Δp scale
The following graph illustrates the square relationship between the differential pressure and the flowrate.
Turndown of a differential pressure transmitter
This shows that a turndown of 10:1 on flowrate will require a 100:1 turndown on pressure measurement (this is provided the density is approximately constant e.g. for a liquid).
As it is very difficult to obtain accurate measurements over such a large range of Δp values from a simple transmitter, this means that the typical turndown of a Δp meter is actually limited to approximately 4:1 to obtain an accurate measurement of flowrate.
At low values of the flowrate the Δp transmitter uncertainty increases significantly. For example, a Δp cell can typically offer an uncertainty of 0.2% of Full Scale (FS). This means that, at 1% FS, the uncertainty of the differential pressure would be 20%. Therefore at low flowrates it becomes much more difficult to measure the Δp.
The turndown of the meter can be extended to around 10:1 if multiple range transducers are used. For example, one Δp transducer could be ranged for 1 – 10% FS and another over the range of 10 – 100% FS.
Once a value for the Δp has been obtained, the mass flow can be calculated using the following formula.
For liquids the mass flow is given by:
Where:
C is the discharge coefficient
At is the throat area (restriction)
Δp is the differential pressure
p is the density of the fluid
DP Flow Coefficients
d is the diameter of the throat
D is the pipe diameter
Owing to the compressibility of gases an additional parameter called the expansibility factor, ε, is used within the mass flow equation to account for the gas density changing as the pressure drops at the restriction.
For gases the mass flow is given by:
For gases the mass flow DP Flow
  • Integral Flow Orifice Assembly
  • What is an Orifice Flange?
  • Types of Orifice Tappings
  • What are the different Orifice Plates?
  • Turndown ratio of Orifice Plates
V Cone Flow Meter – Principle, Advantages, Disadvantages
Flow Instruments – Selection, Principle & Application
What is a Thermal Flow Meter?
Flow Switch : What is it? – Applications
DP type Flow Transmitter Preventive Maintenance and Calibration
Turbine Flow Meter – Principle, Advantages, Disadvantages
5 Comments
  • dedy says:
    June 12, 2016 at 10:12 am
    thank a lot sir, your website is very good for instrument and control job, sir…can you fill up article step by step commissioning for calibration control valve like fisher or neles metso, thanks
  • Prasad H. Thopte says:
    August 11, 2016 at 6:06 am
    Thank You……………..
  • Nishant jha says:
    November 23, 2016 at 6:02 am
    Dear sir
    Thanks for helping us.
    Please help me how we can get mass flow rate of gases based on differential pressure measurement with orifice plate after temperature and pressure compensation. Please explain and give equation.
  • Jannatul Firdaush says:
    March 28, 2020 at 8:47 pm
    Dear Sir
    your explanation is quite good and thanks a lot for that.
    But can you explain how to determine expansibility factor.
    I will be very grateful to you for this.
    Regards
  • Ali Babar says:
    December 3, 2020 at 10:02 pm
    Dear Sir,
    I’m looking flow meter system with online. We will use it in textile spinning industries where we will control our flow with mobile app or computer. Please send us quotation of 10 meters with complete system.
    We are looking your quick and kind response.
    Feel free and contact us for any further details
Particle Image Velocimetry (PIV) Principle
What is an Orifice Meter?
What are the Orifice Plate Flow Requirements?
Pressure Temperature Compensation Flow Measurement
Types of Flow Meters MCQ – Instrumentation and Control
Orifice Plate Turndown ratio
Step by Step Guide for Gas Flow Meter Calibration
Differential Pressure versus Flow Rate
Orifice Flowmeter Rangeability
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Laminar Flow Meter Working Principle
Velocity-based Flowmeter
What is a Velocity-based Flow Meter?
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
Differential Pressure (DP) Flow Meters Range Calculation Methods
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
What is a Condensate Pot? How to Install it?
Effluent Treatment Plant
Basic Components of Effluent Treatment Plant (ETP)
PID Controller Gains Effect on Setpoint
PID Controller Gains Effect on Manipulated Variable
Electrical Motor Model number and serial number
How to Read the Nameplate of a Motor?
Coil Type Timers in Siemens PLC Programming
Shielded Cables
The Idea Behind Shielded Cables
Top 300 Electrical Circuits Objective Questions and Answers
transformers-questions-answers-part-1
Transformers Questions & Answers Part-1
Abbreviations of Pressure, Temperature & Flow
