Reading: What is a Condensate Pot? How to Install it?
Inst Tools > Blog > Flow Measurement > What is a Condensate Pot? How to Install it?
The main use of a condensate pot is for maximizing the accuracy of differential pressure flow measurement on steam (or vapor) applications.
Last updated: November 2, 2023 1:10 pm
Flow Measurement
4 Comments
Condensate PotHow to Install a Condensate Pot?Condensate Pot Applications
They are used to ensure that the condensation of steam in the impulse lines does not impair the ability to accurately sense differential pressure fluctuations and to minimize gauge line error because of differences between pairs of impulse lines.
Condensate Pot
Condensate Pot
The theory of operation for condensate pots is that between the process taping and the pot is a steam vapor. Between the pot and the differential pressure transmitter is water (liquid) which eliminates any measurement errors due to a liquid/vapor mix at the measurement device.
In order for this to work correctly, both high-pressure (HP) and low-pressure (LP) impulse lines should be the same length. Thus, eliminating pressure head errors. One condensate pot will be required for each impulse line.
Installation can be either vertical or horizontal lines between the primary (Flow Meter) and the secondary (transmitter/ gauge) to act as a barrier to the line fluid permitting direct sensing of the flow conditions.
These Units should be mounted at the same level minimizing possible errors that could arise due to unequal head of fluid in the connecting pressure lines.
1. Evaluate the number of connections required on the condensate pot before ordering (inlets, outlets, fill port, drain port, gas vent port, etc)
2. Define condensate pot volume in liters and system pressure and temperature requirements.
3. Consider the need to trace heat and insulate all impulse lines.
4. Consider the need to add an anti-freeze media such as glycol to the water lines.
5. Keep vapor impulse lines as short as practicable.
6. Ensure both condensate pots are mounted at the same level. The higher connection point should be the reference. Consider both Vertical and horizontal steam pipelines.
7. The differential pressure measuring device (DP) should be mounted below both the condensate pots and the steam pipeline.
8. It is recommended that both impulse lines from the condensate pot to the DP include the facility for ‘blowdown’. Blowing down these lines periodically ensures that the collection of debris is prevented from impacting the measurement accuracy.
The condensate pots also help us to trap any foreign material from the pipeline, preventing damage to the sensitive instrumentation components.
The condensate is drained from the bottom valve connection and is suitable for use with ball valves, which act as the drain port.
Source: Parker
  • Types of Flow Devices
  • Coriolis Mass Transmitter
  • Paddle Wheel Flow Meter
  • Flow Nozzle Principle
  • Venturi Meter Animation
What is a Thermal Flow Meter?
What is a Vortex Flow Meter?
Interferometer Principle
What is Differential Pressure and Pressure Loss?
All About Instrumentation Impulse Lines
Factors Affecting the Performance of Ultrasonic Flow Meters
4 Comments
  • Stephen Morales says:
    April 6, 2021 at 12:06 am
    Thank you for the lesson.
  • Rudolph Aguirre says:
    September 29, 2021 at 8:21 pm
    Is it a fact that condensate pots should not be insulated for their proper operation?
    • Michael says:
      June 11, 2022 at 3:40 am
      Correct. You want the condensate pot uninsulated so the steam will condense to water in the condensate pot like it’s supposed to. If it is insulated, you are not allowing the heat to dissipate and therefore the steam remains steam and can affect your reading.
      Insulators are usually not aware of this requirement so they will insulate everything. On my last project, we had to go back and remove insulation on all of our steam line condensate pots.
  • Arslan says:
    February 4, 2023 at 1:41 pm
    Hi, can I use condensate pot for the dp flow meter of gas service
Open Channel Flow Measurement Principle
Configure the Instruments in Flow Control Loop
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
What is an Averaging Pitot Tube? – Principle, Advantages
Is it Easy to Measure Natural Gas Flow and Volume?
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
What is an Orifice Meter?
Comparison of Venturi and Orifice flow meter
Piston Type Flow Meter Principle
Types of Variable Area Flow Meters
Oscillating Piston Flow Meters Animation
Oscillating Piston Flow Meters Working Principle
How to Select a Rotameter? – Parameters and Applications
Vortex Flow Meter Animation
Magnetic Flowmeter vs. Turbine Flowmeter
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
orifice plate vent hole
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Orifice Specifications
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Total Organic Carbon Analyzers Questions and Answers
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Industrial Star Delta Starter for 3-Phase Induction Motor
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
What is a Inductive Proximity Switch
What is a Inductive Proximity Switch ?
Difference between Butterfly Valves and Ball Valves
Two Wire Transmitter Working Principle
Basics of Two, Three & Four Wire Transmitters
Ultrasonic Thickness Gauge
How to Use a Paint Thickness Gauge?
Quiz on DC Motor Starting
