Reading: Diodes Voltage Tripler
Inst Tools > Blog > Electronic Devices & Circuits > Diodes Voltage Tripler
Last updated: October 5, 2016 12:51 pm
1 Min Read
The addition of another diode-capacitor section to the half-wave voltage doubler creates a voltage tripler, as shown in Below Figure.
The operation is as follows: On the positive half-cycle of the secondary voltage, C1 charges to Vp through D1. During the negative halfcycle, C2 charges to 2Vp through D2, as described for the doubler. During the next positive half-cycle, C3 charges to 2Vp through D3. The tripler output is taken across C1 and C3, as shown in the figure.
What is Kirchhoff’s Voltage Law
Basics of Transistors
Diode Clampers Principle
Transistor as an Amplifier in Common Emitter
Positive & Negative Diode Clippers
Half Wave Rectifier Principle
JFET Working Animation
How a Multi Color LED Works ?
Forward Bias & Reverse Bias Diode Working Animation
Limitations of Resistors
Voltage Divider Rule
Zener Diode Voltage Regulator Operation
What is a Filter Circuit ?
Different Types of Diodes
Full Wave Bridge Rectifier Operation
temperature compensation circuit for PMMC
PMMC Temperature Compensation
zener-diode-as-voltage-regulator
Operation of Zener Diode Voltage Regulator
Diode-vi-characteristic-curve-for-forward-bias
VI Characteristic of a Diode
Basics of Amplifiers Interview Questions
Why Silicon is preferred over Germanium ?
transistor-biasing-circuits
Summary Of Transistor Bias Circuits
Open Circuit without Freewheeling diode
Freewheeling Diode Working Principle
Siemens Industrial Laptop (Simatic Field PG)
Connect to the Siemens S7 PLC
Failure Demand in Safety Control Circuit
Safety Instrumented System Module Failure
Control systems in industrial projects
Interactions With Process Control Systems Philosophy
Force Balance Pressure Transmitters
Pneumatic Pressure Transmitters Principle
FF Function block location
Foundation Fieldbus Logics
Nonlinear Control Systems
Stability of Nonlinear System
Construction of Megger
What is a Megger? Principle, Advantages, Disadvantages, Applications
How to Identify Phase, Earth, and Neutral Wires_
How to Identify Phase, Earth, and Neutral Wires?
