Reading: Basics of Voltage Regulators
Inst Tools > Blog > Electronic Devices & Circuits > Basics of Voltage Regulators
Last updated: April 16, 2019 8:12 am
3 Min Read
While filters can reduce the ripple from power supplies to a low value, the most effective approach is a combination of a capacitor-input filter used with a voltage regulator.
A voltage regulator is connected to the output of a filtered rectifier and maintains a constant output voltage (or current) despite changes in the input, the load current, or the temperature.
The capacitor-input filter reduces the input ripple to the regulator to an acceptable level. The combination of a large capacitor and a voltage regulator helps produce an excellent power supply.
Most regulators are integrated circuits and have three terminals—an input terminal, an output terminal, and a reference (or adjust) terminal.
The input to the regulator is first filtered with a capacitor to reduce the ripple to The regulator reduces the ripple to a negligible amount.
In addition, most regulators have an internal voltage reference, shortcircuit protection, and thermal shutdown circuitry. They are available in a variety of voltages, including positive and negative outputs, and can be designed for variable outputs with a minimum of external components.
Typically, voltage regulators can furnish a constant output of one or more amps of current with high ripple rejection.
Three-terminal regulators designed for fixed output voltages require only external capacitors to complete the regulation portion of the power supply, as shown in Below Figure.
Filtering is accomplished by a large-value capacitor between the input voltage and ground.
An output capacitor (typically ) is connected from the output to ground to improve the transient response. 0.1 mFto1.0mF 610%.
Fig : A voltage regulator with input and output capacitors.
A basic fixed power supply with a +5 V voltage regulator is shown in Below Figure. Specific integrated circuit three-terminal regulators with fixed output voltages are available in the market.
full-wave-bridge-rectifier-with-voltage-regulator
Fig : A basic +5.0 V regulated power supply.
Percent Regulation
The regulation expressed as a percentage is a figure of merit used to specify the performance of a voltage regulator. It can be in terms of input (line) regulation or load regulation.
Line Regulation
The line regulation specifies how much change occurs in the output voltage for a given change in the input voltage.
It is typically defined as a ratio of a change in output voltage for a corresponding change in the input voltage expressed as a percentage.
voltage-regulator-line-regulation
Load Regulation
The load regulation specifies how much change occurs in the output voltage over a certain range of load current values, usually from minimum current (no load, NL) to maximum current (full load, FL).
It is normally expressed as a percentage and can be calculated with the following formula:
voltage-regulator-load-regulation
where VNL is the output voltage with no load and VFL is the output voltage with full (maximum) load.
Full Wave Voltage Doubler using Diodes
Limitations of Resistors
Peak Inverse Voltage of Center Tap Rectifier
Capacitively Coupled Multistage Transistor Amplifier
Photodiode as Variable Resistance Device
Series and Parallel Resistors
Forward Bias & Reverse Bias of a Diode
VI Characteristic of a Diode
Difference between ideal diode & conventional diode
Center Tapped Full Wave Rectifier Operation
Band Gap for Semiconductor Materials
Methods of Transistor Biasing
Transistor Biasing
Ideal Diode Characteristics
pi filter Operation
pi filter Operation
Zener Diode Voltage Regulator Operation
principle of time base generator
Time Base Generator
Transistor Collector Feedback Bias
Transistor Collector Characteristic Curves
transistor-terminals
Basics of Transistors
Voltage Divider Rule
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 7
Control Valve Preventive Maintenance
Use of Isolator in Microwaves
Why do Teenagers want to be Entrepreneurs
Why do Teenagers want to be Entrepreneurs?
Analog Electronics Objective Questions – Set 6
Performance of Systems Objective Questions
Performance of Control Systems Objective Questions
Digital Control Valve (DCV) Calibration Procedure
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
