Reading: Two-Liquid Manometer Principle
Inst Tools > Blog > Pressure Measurement > Two-Liquid Manometer Principle
Last updated: March 11, 2019 10:45 am
1 Min Read
The two-liquid manometer is used to measure very small pressures. This is because a very small applied pressure, will produce a large liquid movement.
The basic arrangement is shown in figure. The manometer consists of two wells, each of the same large cross sectional area, connected by a U-Tube of much smaller cross sectional area.
The U-Tube contains two liquids, one is more densed than the other.
The lower liquid, of density ρ2 is denser than the upper liquid, of density ρ1.
Points to note;
  • The two liquids should be non-mixing and the interface should be clearly visible.
  • The closer the densities of the liquids the more sensitive the manometer.
The scale is usually calibrated by the manufacturer in units of pressure, e.g. mmHg or Pascal, so that the pressure can be read directly from the device.
Difference between Absolute, Gauge and Differential Pressure Transmitters
Pneumatic Pressure Transmitters Principle
Pressure Measurement using Manometer
Purpose of Stop in a Pressure Measuring Instrument
Metal Foil Strain Gauge Principle
Impulse Piping standards for Field instruments
Types of Bourdon Tube
Pressure Unit Conversion Practical Example
Pressure and Temperature Gauges
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Basics of Pressure Measurement
Differential Pressure Gauge Principle
All About Instrumentation Impulse Lines
What is Static Pressure Limit in DP Transmitter ?
Magnehelic Gauge Calibration
Differential Pressure Sensor for Filtration Monitoring
Pressure Switch Construction
Basics of Pressure switches
Pressure Sensor Specifications
Pressure Gauge Accessories
How to Measure Pressure in Inches of Water Column
inductance transducer
Inductance Type Pressure Transducers Principle
Power Systems MCQ Series 13
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Major issues for Sensors Selection
explosion-proof electrical enclosures
Classified Areas and Electrical Safety Measures
vibration probe mounting
Mechanical Vibration Switch Principle
4-20mA Loop Power Supply Questions
Process Plant Risk and Safety Management
Safety Roles & Responsibilities of Process Engineering (Detail Design)
