Reading: Factors for Setting Alarm Levels on Toxic Gas Detectors
Inst Tools > Blog > Fire & Gas System > Factors for Setting Alarm Levels on Toxic Gas Detectors
Last updated: January 2, 2020 3:52 pm
Fire & Gas System
2 Min Read
The use of toxic gas detection, assuming it is required, will follow from the requirements of the risk assessment. There are various factors that should be considered when setting alarm levels on toxic gas detectors to minimize the risk of potentially dangerous exposure levels to personnel in a particular area of the workplace.
In many situations, however, discussion of these factors either does not occur at all or is extremely brief, and “default” values are typically used. While these values may well be adequate for the task required, i.e. to satisfy the risk assessment or safety case, a more thorough analysis of requirements and the actual circumstances would prove beneficial and is likely to lead to more robust risk mitigation.
Toxic Gas Detectors
The following factors relating to setting an alarm should be considered when installing any type of gas detector:
  1.  Whether detectors should be fixed and/or whether personnel should be issued with portable, which includes personal, detectors;
  2. The location of the fixed detector and whether the work area is occupied or unoccupied;
  3. Whether the fixed detector is a point or open-path (also known as beam or line of sight detectors) detector;
  4. Whether egress is difficult and/or time-consuming or there is an emergency;
  5. Whether WELs, other Exposure Limit values or other health-based levels (e.g. IDLH) exist;
  6. Instantaneous or TWA alarm;
  7. Background variations and events from the process, which may trigger “spurious”
  8. alarms
  9. False alarms caused by instrumental effects and interferent gases, which may also be
  10. classified as spurious;
  11. The characteristics of the source(s) and the potential rate of gas build-up;
  12. Time to the alarm of the detection system;
  13. Number of alarm levels (e.g. high and low levels);
  14. The mixture of gases/vapors.
  • Gas Detector Calibration
  • Portable Gas Detectors
  • Addressable Fire Panel
  • Fire and Gas Detectors MCQ
  • Basics of Gas Monitoring
Rate Compensated Heat Detectors Working Principle
Industrial Flame Detectors
What are Linear Heat Detectors?
Fire and Safety
Basics of Fire Detection and Alarm System
Infrared Gas Detectors Working Principle
Fixed Temperature Heat Detector Working Principle
How to identify location of Fire Detectors
Carbon Monoxide Gas Hazards
Chlorine Gas Hazards
Deluge Valve Operation
Fire and Gas system Audible and Visual Alarms
Argonite Fire Suppression System Working Principle
Carbon Monoxide Gas Sensor Principle
Hydrogen Sulfide Gas Detector Calibration Procedure
Diesel Engine Fire Hydrant Pump
Fire Fighting System
Fire Alarm System Commissioning Procedure
Gases LEL and UEL
What is Lower Explosive Limit & Upper Explosive Limit ?
Gas detection system Interview Questions
Interview Questions on Gas detection System
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Hydrogen sulfide gas
Hydrogen Sulfide Gas (H2S)
Fire Extinguisher Operation
Basics of Fire Extinguisher
Paddle Type Level Switch
What is a Level Switch? Types of Level Switches
Transformer voltage and turns ratio
Transformer Current Ratio
PID Controller Tunning Manually
PID Controller Parameters Tuning Manually
Differential Pressure Sensor Calibration
Differential Pressure Sensors Calibration Procedure
Deluge Valve Operation using Solenoid Valve Animation
Process Control Instrumentation Terms Glossary
Stability in Frequency Domain
Assessment of Relative Stability Using Nyquist Criterion
Helix Bimetallic Thermometer Principle
