  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Thermocouples Burnout detection
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Temperature Measurement > Thermocouples Burnout detection
Last updated: May 13, 2019 5:34 pm
2 Min Read
The most common failure mode for thermocouples is to fail open, otherwise known as “burning out.”
An open thermocouple is problematic for any voltage-measuring instrument with high input impedance because the lack of a complete circuit on the input makes it possible for electrical noise from surrounding sources (power lines, electric motors, variable-frequency motor drives) to be detected by the instrument and falsely interpreted as a wildly varying temperature.
For this reason it is prudent to design into the thermocouple instrument some provision for generating a consistent state in the absence of a complete circuit. This is called the burnout mode of a thermocouple instrument.
A simple thermocouple circuit equipped with burnout detection is shown in this diagram:
The resistor in this circuit provides a path for current in the event of an open thermocouple. It is sized in the mega-ohm range to minimize its effect during normal operation when the thermocouple circuit is complete. Only when the thermocouple fails open will the miniscule current through the resistor have any substantial effect on the voltmeter’s indication.
The SPDT switch provides a selectable burnout mode: in the event of a burnt-out thermocouple, we can configure the meter to either read high temperature (sourced by the instrument’s internal milli-voltage source) or low temperature (grounded), depending on what failure mode we deem safest for the application.
Recommended Articles
Basics of Temperature Switch
Resistance Temperature Detectors (RTD) Construction
Types of Thermocouple Measuring Junction
Thermocouple Extension and Compensating Cables
Temperature Coefficient of Resistance (α)
Spiral Bimetallic Thermometer Principle
  • KR says:
    March 7, 2018 at 8:33 am
    I don’t think the diagram makes sense. When assuming burnout ‘high’, the internal mV which is required for indication of ‘high’ will have voltage drop at the resistor and there will be no indication at the voltmeter. If my understanding is incorrect, please advise me.
208kSubscribersSubscribe
Recent Comments
Related Articles
Thermocouple Reference Junction
Thermocouple Working Principle
Temperature Controller
What is a Temperature Controller? – How to Choose?
Thermowell Wake Frequency Calculation
Thermocouple Reference junction compensation
Difficulties with Thermocouples for Temperature Measurement
What is an RTD
Components of RTD
calibrating-and-testing-rtd-sensors
RTD Calibration Procedure
Thermowell Installation near Critical Equipment
Celsius and Fahrenheit Temperature Values
What Temperature are Celsius and Fahrenheit Value Same ?
More Articles
Float Level Measurement
Types of Level Measurement
Power Transistor Quiz
Digital Electronics Objective Questions – Set 9
RC Triggering
SCR Triggering Methods
Valve Diaphragm Actuator
Spring and Diaphragm Pneumatic Actuators
Thermocouple Questions
Thermocouple Terminal block Questions
What is an Oil Separator in HVAC?
How to Test a Thermocouple with a Multimeter
Testing a Thermocouple With a Multimeter
