Reading: Thermocouple Software compensation
Inst Tools > Blog > Temperature Measurement > Thermocouple Software compensation
Last updated: April 20, 2019 5:52 pm
3 Min Read
Previously, it was suggested that automatic compensation could be accomplished by intentionally inserting a temperature-dependent voltage source in series with the circuit, oriented in such a way as to oppose the reference junction’s voltage:
If the series voltage source Vrjc is exactly equal in magnitude to the reference junction’s voltage (VJ2), those two terms cancel out of the equation and lead to the voltmeter measuring only the voltage of the measurement junction J1:
  • Vmeter = VJ1 + 0
  • Vmeter = VJ1
This technique is known as hardware compensation, and is employed in analog thermocouple temperature transmitter designs.
Previously we saw an example of this called an ice point, the purpose of which was to electrically counter the reference junction voltage to render that junction’s voltage inconsequential as though that junction were immersed in a bath of ice-water.
A modern technique for reference junction compensation more suitable to digital transmitter designs is called software compensation:
Instead of canceling the effect of the reference junction electrically, we cancel the effect arithmetically inside the microprocessor-based transmitter. In other words, we let the receiving analog-digital converter circuit see the difference in voltage between the measurement and reference junctions (Vinput = VJ1 āˆ’ VJ2), but then after digitizing this voltage measurement we have the microprocessor add the equivalent voltage value corresponding to the ambient temperature sensed by the RTD or thermistor (Vrjc):
  • Compensated total = Vinput + Vrjc
  • Compensated total = (VJ1 āˆ’ VJ2) + Vrjc
Since we know the calculated value of Vrjc should be equal to the real reference junction voltage (VJ2), the result of this digital addition should be a compensated total equal only to the measurement junction voltage VJ1:
  • Compensated total = VJ1 āˆ’ VJ2 + Vrjc
  • Compensated total = VJ1 + 0
A block diagram of a thermocouple temperature transmitter with software compensation appears here:
SMART Temperature Transmitters
Perhaps the greatest advantage of software compensation is the flexibility to easily switch between different thermocouple types with no hardware modification. So long as the microprocessor memory is programmed with look-up tables relating voltage values to temperature values, it may accurately measure (and compensate for the reference junction of) any thermocouple type.
Hardware-based compensation schemes (e.g. an analog ā€œice pointā€ circuit) require re-wiring or replacement to accommodate different thermocouple types, since each ice-point circuit is built to generate a compensating voltage for a specific type of thermocouple.
Introduction to RTDs
Ambient Temperature Effects on RTD
Temperature Controller Problem
Types of Thermocouples
Difference Between RTD, Thermocouple and Thermistor
Thermistor Working Principle
  • Simon Watah says:
    March 17, 2021 at 8:49 am
    Very helpful knowledge when trying trying to understand how bimex calibrator is connected and used to do function testing on thermocouple.
Thermocouple and its Principle
Free Download Thermocouple Calculator
Components of RTD
What is a Three-wire RTD ?
RTD Standards
Thermocouples Law of Intermediate Metals
Temperature Sensor Accessories
Filled-bulb Temperature Sensors
Why have been limits imposed on the frequency ratio for thermowells?
Temperature Sensors Interview Questions
Thermowell Installation near Critical Equipment
Temperature Transmitter Foundation Fieldbus Configuration
Foundation Fieldbus Temperature Transmitter Configuration
What to Choose RTD or Thermocouple ?
Thermowell Problems
Thermowell Problems
Temperature Switch Working
Basics of Temperature Switch
Two Wire RTD Lead Wire Resistance Error
Temperature Error of 2-Wire, 3-Wire & 4-Wire RTD
Electrical Conductivity Meter
What is the Application of Electrical Conductivity Meter?
Venturi Flow Measurement Principle
Why Flow is Directly Proportional to the Square Root of DP?
Induction Motor Phasor Diagram
Sump Tank Level Transmitter
Problem with Sump Tank Level Transmitter
Current to Voltage Conversion Circuit
How to Convert Current to Voltage using Resistor ?
Configuration of Siemens Scada and PLC
Hydraulic Motor Forward and Reverse Control with Simulation
PLC Data comparison instructions
PLC Data Comparison Instructions
