Reading: Temperature Measurement Multiple Choice Questions
Inst Tools > Blog > Instrumentation MCQ > Temperature Measurement Multiple Choice Questions
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
3 Min Read
Question 1
Identify the thermocouple type with the highest temperature limit from those listed here:
(A) Type J
(B) Type K
(C) Type S
(D) Type T
(E) Type E
Answer  : C
Question 2
The negative lead of a thermocouple is always colored:
(A) Blue
(B) Yellow
(C) Red
(D) White
(E) Black
Answer  : C
Question 3
The most rugged temperature sensing element listed here is a/an:
(A) Thermocouple
(B) Orifice plate
(C) RTD
(D) Filled bulb
(E) Fire eye
Answer  : A
Question 4
Convert a temperature measurement of 250 deg C into Kelvin.
(A) 523.2 K
(B) -209.7 K
(C) 709.7 K
(D) -23.2 K
(E) 23.2 K
Answer  : A
Question 5
When the reference junction is the same temperature as the measurement junction in a thermocouple circuit, the output voltage (measured by the sensing instrument) is:
(A) Zero
(B) Reverse polarity
(C) Noisy
(D) AC instead of DC
(E) Unreliable
Answer  : A
Question 6
A “thermowell” is a:
(A) Heat sink
(B) Small vessel for holding liquids at high temperature
(C) Protective tube for a temperature sensing element
(D) Temperature sensing device
(E) Safety relief device for high pressure
Answer  : C
Question 7
Reference junction compensation is necessary in thermocouple-based temperature instruments because:
(A) Copper extension wire has a tendency to corrode
(B) Thermocouples are inherently nonlinear
(C) The reference junction generates a temperature-dependent voltage
(D) The junction’s electrical resistance varies with temperature
(E) Electrical noise may interfere with the measurement otherwise
Answer  : C
Question 8
Latent heat is:
(A) The heat required to raise the temperature of a substance
(B) The amount of heat energy present in ambient conditions
(C) The potential energy residing in a sample of unburnt fuel
(D) The heat released when a gas suddenly decreases pressure
(E) The heat required to make a substance change phase
Answer  : E
Question 9
Thermocouple extension wire may be readily distinguished from regular thermocouple-grade wire by:
(A) Different metal types
(B) Outer sheath color
(C) Special markings on the wire’s insulation
(D) Thickness
(E) Flexibility (stranded instead of solid)
Answer  : B
Question 10
A type J thermocouple is made of the following metals:
(A) Aluminum and Tungsten
(B) Iron and Constantan
(C) Platinum and Platinum/Rhodium alloy
(D) Copper and Constantan
(E) Chromel and Alumel
Answer  : B
Credits : by Tony R. Kuphaldt
Chemical Sensors Objective Questions
Flow Measurement Objective Questions
PID Controller Multiple Choice Questions
Control of the Effects of Disturbance Signals by Use of Feedback
Common Valve Abbreviations in US Engineering Drawings
Single Beam and Double Beam Instruments
  • Junaid says:
    September 24, 2018 at 3:24 pm
    Excellent according to test and interview point of view
Adaptive Control
Electrical Measurements and Instrumentation Objective Questions & Answers
Pressure and Instrumentation MCQ – Questions & Answers
State Models for Linear Continuous Time Systems
Seismic Transducers Objective Questions
Piezo Electric Transducers Objective Questions
Radio Telemetry Objective Questions
Time Response of Second Order Systems – IV
Transducers MCQ
Transducers MCQ
Instrumentation Diagrams Multiple Choice Questions
Control Systems Stability and Algebraic Criteria
Concept of Stability in Control Systems
Time Response Analysis
Standard Test Signals Objective Questions
Fibre Optic Sensors Objective Questions
Nitrogen Oxides Questions & Answers
Optimal Control Systems
Actuators Questions and Answers
Tagging Philosophy for Junction Box
Tagging Philosophy for Junction Box, Cable, and Cable Drum
PRV
3-15 psi to 4-20mA Conversion
Example of 3-15 psi to 4-20mA Conversion
Understanding-a-Process-Control-Loop
Understanding a Process Control Loop
different flow measurement technologies
Different Flow Measurement Technologies
needle valve applications
Applications of Needle Valves
Basic Components of HVAC System
PLC Engineers Interview Questions
PLC SCADA Engineers Interview Questions and Answers
