Reading: Solenoid Valve Terminology Questions and Answers
Inst Tools > Blog > Instrumentation MCQ > Solenoid Valve Terminology Questions and Answers
Test your knowledge with solenoid valve terminology questions and answers for technicians and engineers in fluid dynamics.
Last updated: August 31, 2024 8:28 pm
Instrumentation MCQ Solenoid Valve
14 Min Read
Solenoid Valve TerminologyWhat is the function of the Bleed-Orifice or Bleed Hole in a solenoid valve?What is the primary role of the Bonnet in a solenoid valve?What is the Coil in a solenoid valve responsible for?What is the function of the Core Spring in a solenoid valve?What is the purpose of the Core Tube in a solenoid valve?What is the role of the Valve Disc in a solenoid valve?What does the Main Orifice refer to in a solenoid valve?What is the function of the Retaining Clip in a solenoid valve?What does the Plugnut do in a solenoid valve?What is the purpose of the Shading Coil in a solenoid valve?What is the role of the Diaphragm in a solenoid valve?What is the purpose of the Back-up Washer in a solenoid valve?What is the function of the Seal in a solenoid valve?What is the Valve Seat in a solenoid valve?What is the Solenoid Base Sub-assembly in a solenoid valve?What is the primary purpose of the Solenoid in a solenoid valve?What is the role of the Solenoid Construction in a solenoid valve?What does the Solenoid Enclosure protect against?What is the function of the Valve Body in a solenoid valve?What is Maximum Ambient Temperature in the solenoid valves?What does Maximum Operating Pressure Differential (M.O.P.D.) refer to in a solenoid valve?What does Maximum Operating Pressure Differential (M.O.P.D.) refer to in a solenoid valve?What is the Minimum Ambient Temperature in the solenoid valves?What is the Minimum Operating Pressure Differential in a solenoid valve?What is the purpose of the Pilot Orifice in a solenoid valve?What is the role of the Plugnut in the solenoid valve assembly?What is Response Time in the solenoid valves?What is the purpose of the Seating or Valve Seat in a solenoid valve?What is a Solenoid?What does Solenoid Construction involve in a solenoid valve?What is the purpose of a Solenoid Enclosure?What is the function of the Valve Body in a solenoid valve?What are ISO Symbols of solenoid valves indicate?
Watch this video on solenoid valves to learn the detailed explanations.
Question 1
A. To relieve pressure during operation
B. To allow a small flow to control a larger flow
C. To regulate the main flow of fluid
D. To isolate the valve from the main system
Show the Answer
Question 2
A. To seal the core tube
B. To cover and protect the internal components
C. To allow fluid to pass through
D. To house the electrical connections
Show the Answer
Question 3
A. Holding the valve components together
B. Controlling the flow of fluid through the valve
C. Generating a magnetic field to move the core
D. Providing a seal for the valve body
Show the Answer
Question 4
A. To open the valve when power is applied
B. To close the valve when power is removed
C. To maintain pressure balance
D. To enhance the magnetic field
Show the Answer
Question 5
A. To provide a passage for fluid flow
B. To house and guide the core
C. To insulate the coil
D. To protect the valve disc
Show the Answer
Question 6
A. To protect the core from damage
B. To control electrical connections
C. To block or allow fluid flow
D. To generate the magnetic field
Show the Answer
Question 7
A. The connection point for electrical wires
B. The area where the coil is located
C. The smallest opening in the valve
D. The primary flow path for fluid
Show the Answer
Question 8
A. To prevent the coil from moving
B. To hold the valve seat in place
C. To secure the core in the tube
D. To keep the valve body sealed
Show the Answer
Question 9
A. Controls fluid pressure
B. Provides a sealing surface
C. Aligns the core
D. Generates the magnetic field
Show the Answer
Aligns the core
Question 10
B. To maintain a magnetic field for smooth operation
C. To reduce noise during operation
D. To prevent the valve from overheating
Show the Answer
Question 11
A. To connect electrical components
B. To act as a flexible seal
C. To generate magnetic force
D. To guide the core
Show the Answer
Question 12
A. To prevent fluid leakage
B. To provide structural support
C. To enhance magnetic field
D. To secure the coil
Show the Answer
Question 13
A. To prevent fluid from leaking
B. To secure the valve components
C. To maintain the magnetic field
D. To guide the core movement
Show the Answer
Question 14
A. The part that houses the core tube
B. The surface against which the valve disc seals
C. The area where the coil is mounted
D. The location where fluid exits the valve
Show the Answer
Question 15
A. A component that generates fluid pressure
B. A sub-assembly that houses the coil and core tube
C. A part that connects the valve to the fluid line
D. A structure that provides electrical insulation
Show the Answer
Question 16
A. To control the flow of fluid directly
B. To provide a seal for the valve body
C. To measure the fluid pressure
D. To generate the magnetic force needed to move the core
Show the Answer
Question 17
A. To control the electrical power to the valve
B. To determine the magnetic strength of the coil
C. To specify the design and materials of the solenoid
D. To dictate the valve’s flow rate
Show the Answer
Question 18
A. Fluid leakage
B. Electrical interference
C. External environmental factors
D. Fluid flow
Show the Answer
Question 19
A. To provide the structural framework for the valve
B. To control the opening and closing of the valve
C. To generate the magnetic field
D. To house the electrical components
Show the Answer
Question 20
A. The highest temperature at which the coil can operate
B. The highest fluid temperature the valve can handle
C. The maximum temperature at which the seal remains effective
D. The highest temperature of the environment where the valve can operate
Show the Answer
Question 21
A. The maximum pressure difference across the valve ports
B. The pressure at which the valve will burst
C. The highest pressure the coil can handle
D. The highest pressure the valve body can withstand
Show the Answer
Question 21
Show the Answer
Question 22
A. The lowest temperature at which the valve will operate correctly
B. The lowest temperature the valve can handle without freezing
C. The lowest temperature at which the coil will activate
D. The minimum fluid temperature the valve can control
Show the Answer
Question 23
A. The minimum fluid flow rate for proper operation
B. The lowest pressure the valve can handle
C. The minimum pressure needed to prevent fluid leakage
D. The minimum pressure difference required for the valve to operate
Show the Answer
Question 24
A. To relieve excess pressure from the valve
B. To seal the valve when not in use
C. To control the main flow of fluid
D. To allow a small controlled flow to open or close the main valve
Show the Answer
Question 25
A. To secure the coil to the valve body
B. To guide and align the core
C. To block fluid flow
Show the Answer
Question 26
A. The time it takes for the valve to fully open or close
B. The time it takes to replace the solenoid
C. The time it takes for fluid to start flowing
D. The time it takes for the coil to cool down
Show the Answer
Question 27
A. To provide a surface for the valve disc to seal against
B. To generate magnetic force
C. To guide the core movement
D. To protect the valve from overpressure
Show the Answer
Question 28
What is a Solenoid?
A. A part that insulates the valve from heat
B. A device that regulates fluid flow directly
C. A component that measures pressure
D. A coil of wire that generates a magnetic field when energized
Show the Answer
Question 29
A. The configuration of the fluid passages
B. The process of sealing the valve from the environment
C. The design and materials used in the valve body
D. The assembly of the coil, core tube, and associated components
Show the Answer
Question 30
A. To reduce the valve’s response time
B. To protect the solenoid from environmental damage
C. To enhance fluid flow
D. To increase the valve’s operating pressure
Show the Answer
Question 31
A. To generate the magnetic force
B. To house the internal components and connect to the fluid system
C. To adjust the pressure of the fluid
D. To control the electrical current
Show the Answer
Question 32
A. To indicate the electrical connections of the valve
B. To standardize the graphical representation of valve functions
C. To display the valve’s operating pressure
D. To represent the physical size of a valve
Show the Answer
  • Control Valve Maintenance
  • How to Install a Control Valve?
  • Motor Operated Valve Problems
  • Linear and Rotary Actuators
  • What is a Float Control Valve?
Control Valve Parts Questions and Answers
Quiz on Optical Fiber Cable, Splice, Connector
Thermography and Thermometry Objective Questions
Circuit Control Devices Multiple Choice Questions & Answers
Instrumentation Engineering Quiz – Set 2
Oscillators and Signal Generators Objective Questions
Feedback Control Loop Questions & Answers
Magnetostrictive Transducers Objective Questions
Application of Feedback Objective Questions
Solenoid Valves Selection Guidelines
Process Pressure Measurement Objective Questions
Four Way Solenoid Valve Working Principle
Nuclear Power Plant Multiple Choice Questions
80+ PLC MCQ
80+ PLC MCQ Questions
Micro Sensors Objective Questions
Analog Demodulators Objective Questions
Electrical Switch Questions and Answers
Top 50 Electrical Switch Questions and Answers
Measurements & Instrumentation Quiz – Set 7
Standard Test Signals Objective Questions
Top 80+ Valve Questions and Answers
Loop Powered Pressure Transmitter
Programmable Logic Controller (PLC) PLC Maintenance Check Points
Programmable Logic Controller Maintenance Check Points
Basic Electricity Objective Questions and Answers
100+ Basic Electricity Objective Questions and Answers
Organization block Siemens
Tia Portal – OB30 Cyclic Interrupt Organization Block
Closed-Tank-DP-Type-Level-Measurement-with-wet-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Wet leg and Installed Below Tapping Point
Role of Flow Meters in a Laboratory
What is a Non-Linear Device
What is a Non-Linear Device? Example – Advantages
Essential Safety Tips for Glass Workers
