Reading: Smart Spray System using Wecon PLC
Inst Tools > Blog > PLC Tutorials > Smart Spray System using Wecon PLC
WECON designed a smart spray system for improving the environment protection and dustproof place using PLC and HMI automation.
Last updated: May 6, 2022 12:45 pm
3 Min Read
Modernization brings us a lot of high-rise buildings and apartments to our cities and towns but this also increases the dust and increases the environment & pollution problems and degrades the quality of life of the people.
Smart Spray System using PLCStructureAdvantagesPLC ProjectApplications
Industrial automation is now moving towards home automation, building automation, and city automation.
WECON designed a smart spray system for improving the urban environment protection and creating a dustproof place using advanced automation systems.
This control system consists of high-pressure pumps to atomize the water from the nozzles and then the atomized particles will float in the surrounding air, merge with the dust particles in the air, and fall, so as to increase air humidity, and reduce the ambient temperature and dust.
As an all-around smart monitoring system, the scheme realizes the dust suppression effect under various conditions through dust sensors, magnetic induction of loading vehicles, time control, etc.
Structure
The smart spray control system uses Wecon PLC and HMI to collect real-time data and upload the collected data to an online cloud server.
PLC and HMI with Cloud
The PLC stores data in real time. You can remotely check the on-site situation of various equipment through mobile phones and computers.
You can do real-time monitoring and control of applications.
Wecon PLC
Advantages
The following are the advantages of a PLC-based water spray system.
Remote debugging
If there are any issues with the control system then you can remote debug from your mobiles and laptops, and troubleshoot the online PLC program.
Multi-mode
You can configure different modes as per our needs like manual, automatic, time-based control, fixed cycle, external third-party control, zone-wise control, etc.
Big data analysis
The PLC monitors the equipment running time, water consumption, and electricity consumption in real time. We can analyze these data from remote access and optimize the system accordingly.
Smart Control
We can use advanced smart control to reduce the pollution in the surrounding environment by turning ON and OFF the respective spray systems automatically if the pollution values exceed the setpoint.
Customization
We can deploy the personalized alarm functions to warn the operators about starting or stopping the spray systems as per the required site environment.
PLC Project
The sample PLC ladder diagram program is shown below.
The sample Wecon PLC ladder diagram program
Applications
Fire Spray System
With its cost-effective, simple operation, and flexible to control, The PLC-based smart spray system can be widely used in greening, fire protection, construction sites, mines, and other fields.
You can contact Wecon for any product queries and technical information. Contact Us
Hardwired I/O and Serial I/O – Differences Explained
Top 100 PLC Objective Questions and Answers
Flood Warning System using Programmable Logic Controller
Single-Acting Cylinder Control using Proximity Sensor
PLC Data Comparison Instructions
Wet Contacts and Dry Contacts in PLC Systems
What is Alarm Prioritization? – Types of Alarms
FB Block in Siemens PLC Programming
PLC Problems Troubleshooting
Car Parking System using PLC Programming
PLC Program for Stage Control: Curtains and Stage Elevation
Omron PLC washing machine automation
Omron PLC Logic for Washing Machine Automation
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
VFD Braking
DC Injection Braking in VFD
Configure Analog Inputs and Outputs in Delta PLC
Instrumentation and Control Project Packages
Omron PLC for Product Painting with Integrated Weighing System
Masked Move Instructions
How to use Masked Move Instruction in PLC
STL Programming - SET, RESET, ASSIGN
STL Programming – SET, RESET, ASSIGN
How to Install Ultrasonic Level Transmitters 5
MCQ on Rotating Electrical Machines
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
Electrical & Instrumentation QC Interview Questions
Basic Control Systems Questions
14 Basic Control Systems Questions for Interview Preparation
Pressure Transmitter Re-Range Questions
Three Element Drum Level Control System
