Reading: How to Select a Flow Meter
Inst Tools > Blog > Instrumentation Design > How to Select a Flow Meter
Last updated: November 24, 2017 9:27 am
6 Min Read
Selecting Magflow Flow Meters
he main questions which need to be considered before selecting a magnetic flow meter:
  • – Is the fluid conductive or water based?
  • – Is the fluid or slurry abrasive?
  • – Do you require an integral display or remote display?
  • – Do you require an analogue output?
  • – What is the minimum and maximum flow rate for the Magmeter?
  • – What is the minimum and maximum process pressure?
  • – What is the minimum and maximum process temperature?
  • – Is the fluid chemically compatible with the Magflo flow meter wetted parts?
  • – What is the size of the pipe?
  • – Is the pipe always full?
Selecting Turbine Flow Meters
The main questions which need to be considered before selecting a turbine flow meter:
  • – Is the fluid clean; are there any solids present?
  • – What is the viscosity of the fluid at the operating temperature?
  • – What is the degree of accuracy required?
  • – What is the maximum pressure drop allowed across the turbine meter?
  • – What is the minimum and maximum working flow range?
  • – Is the fluid compatible with stainless steel?
  • – What type of connection is required?
Selecting Vortex Flow Meters
The main questions which need to be considered before selecting a vortex flow meter:
  • – What is the preferred pipe size?
  • – What is the degree of accuracy required (full scale or reading)?
  • – What is the maximum pressure drop allowed across the vortex meter?
  • – Is pressure and temperature compensation required?
Selecting Oval Gear Flow Meters
The main questions which need to be considered before selecting an oval gear flow meter:
  • – What is the viscosity range of the fluid being metered?
  • – Is an output required and, if so, what type?
  • – Is the meter operating in a hazardous area?
  • – Are specific approvals (eg ATEX) required?
  • – Is a flow instrument required?
Selecting Coriolis Mass Flow Meters
The main questions which need to be considered before selecting a coriolis flow meter:
  • – What is the mass flow range?
  • – What is the density of the fluid at the working temperature / pressure?
  • – What is the viscosity of the fluid?
  • – What accuracy range is required?
  • – Is any air present in the liquid?
  • – Are flow & mass flow output required?
Selecting Thermal Mass Flow Meters
The main questions which need to be considered before selecting a thermal mass flow meter:
  • – Are the thermal properties of the gas known and consistent?
  • – Is any moisture present in the gas?
Selecting Ultrasonic Flow Meters
The main questions which need to be considered before selecting a ultrasonic flow meter:
  • – What is the minimum and maximum flow rate for the flow meter?
  • – Is the pipe material compatible with ultrasonic measurement (eg concrete, fiberglass and plastic lined pipes may be incompatible)?
  • – Are there any air spaces in the pipe?
  • – Does the fluid contain particulates or bubbles and, if so, of what size and distribution?
The main questions which need to be considered before selecting a rotameter or variable area (VA) flow meter:
  • – Is the fluid liquid or gas?
  • – What accuracy range is required from the flow meter?
  • – What is the maximum operating pressure?
  • – What is the maximum operating temperature?
Selecting Paddle Wheel Flow Meters
The main questions which need to be considered before selecting a paddle wheel flow meter:
  • – Is the liquid clean; are there any solids present?
  • – What is the minimum and maximum flow rate for the paddlewheel meter?
  • – What is the pipe work material?
  • – What is the required accuracy?
  • – Is local indication required?
What is Cable Schedule and Junction Box Schedule?
Guided Wave Radar Level Sensor Pressure and Temperature Effects
Difference between DCS & PLC Systems
Difference between Axial and Radial Diaphragm Seal Connection?
Determine the Status of Lamps and Relays in the Circuit ?
All About Variable Area Flow Meters
NACE Standards – MR0103 Vs MR0175
What to Choose RTD or Thermocouple ?
Thermowell Installation near Critical Equipment
What is Contact bounce ?
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Troubleshooting a Power Supply Circuit
Instrument Air Sizing
General Specification of Thermowell
Orifice Specifications
Twisted Pair Cable Noise Supression
Why We use Shielded Cable and Twisted Pair Cables ?
float-type level switch control a pump
Thermowell Outer Diameter larger than Nozzle Inside Diameter
Thermowell Outer Diameter Larger than Nozzle Inside Diameter?
Turbine-Compressor System Architecture
Automating Car Parking with Advanced PLC Logic
pn-junction-with-depletion-layer
How a PN Junction Formed in a Diode
Fieldbus Control
Fieldbus Control
PLC Programming Example on Bottle Line Control
Ladder Logic of Motor Forward and Reverse
PLC Programming Example for Motor Forward and Reverse Control
Gas Suppression System
What is Gas Suppression Systems ?
Distributed Control System Architecture
