  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Ripple Voltage in Rectifiers
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Electronic Devices & Circuits > Ripple Voltage in Rectifiers
Last updated: October 4, 2016 1:33 pm
2 Min Read
Ripple Voltage As you have seen, the capacitor quickly charges at the beginning of a cycle and slowly discharges through RL after the positive peak of the input voltage (when the diode is reverse-biased). The variation in the capacitor voltage due to the charging and discharging is called the ripple voltage. Generally, ripple is undesirable; thus, the smaller the ripple, the better the filtering action, as illustrated in Below Figure.
rectifier-ripple-voltage
half-wave-rectifier-ripple-voltage
Fig : Half-wave ripple voltage (blue line).
For a given input frequency, the output frequency of a full-wave rectifier is twice that of a half-wave rectifier, as illustrated in Figure 1. This makes a full-wave rectifier easier to filter because of the shorter time between peaks. When filtered, the full-wave rectified voltage has a smaller ripple than does a half-wave voltage for the same load resistance and capacitor values. The capacitor discharges less during the shorter interval between full-wave pulses, as shown in Figure 2.
full-wave-rectifier-ripple-voltage
Fig 1 : The period of a full-wave rectified voltage is half that of a half-wave rectified voltage. The output frequency of a full-wave rectifier is twice that of a half-wave rectifier.
capacitor-filter-ripples
Fig 2 : Comparison of ripple voltages for half-wave and full-wave rectified voltages with the same filter capacitor and load and derived from the same sinusoidal input voltage.
Ripple Factor
The ripple factor (r) is an indication of the effectiveness of the filter and is defined as
ripple-factor
where Vr(pp) is the peak-to-peak ripple voltage and VDC is the dc (average) value of the filter’s output voltage, as illustrated in Below Figure. The lower the ripple factor, the better the filter. The ripple factor can be lowered by increasing the value of the filter capacitor or increasing the load resistance.
ripple-factor-graph
For a full-wave rectifier with a capacitor-input filter, approximations for the peak-to-peak ripple voltage, Vr(pp), and the dc value of the filter output voltage, VDC, are given in the following equations. The variable Vp(rect) is the unfiltered peak rectified voltage. Notice that if RL or C increases, the ripple voltage decreases and the dc voltage increases.
ripple-factors-equation
Phototransistor Working Principle
Insulators, Conductors and Semiconductors
Photodiode as Variable Resistance Device
Forward Bias & Reverse Bias Diode Working Animation
Transistor Cut off, Saturation & Active Regions
208kSubscribersSubscribe
Recent Comments
Related Articles
Capacitively Coupled Multistage Transistor Amplifier
Transistor as an Amplifier in Common Emitter
Why Silicon is preferred over Germanium ?
Bipolar Junction Transistor Construction
diode-limiter-principle
Diode Limiters/Clippers Operation
temperature compensation circuit for PMMC
PMMC Temperature Compensation
pn-junction-with-depletion-layer
How a PN Junction Formed in a Diode
phototransistor-circuit
Phototransistor Circuit Example
More Articles
Pressure Measurement Objective Questions
Effects of Capillary Tubing on Pressure Measurement
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
Radiation Detectors Questions & Answers
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Top 100 Power Plant Engineering Objective Questions & Answers
MOSFET Quiz
Distributed Control System Architecture
Learn SCL programming from scratch
How to Start Writing SCL Language in Siemens Tia Portal?
