Reading: Rate Compensated Heat Detectors Working Principle
Inst Tools > Blog > Fire & Gas System > Rate Compensated Heat Detectors Working Principle
Last updated: February 26, 2019 8:35 pm
Fire & Gas System
2 Min Read
Rate compensated heat detectors are designed to initiate an alarm when the temperature of the surrounding air reaches a predetermined level, regardless of the rate of temperature rise.
Rate Compensated Heat DetectorsAdvantages of Rate Compensated Heat detectors:Disadvantages of Rate Compensated Heat detectors:
Rate-compensated heat or thermal detectors are devices that are designed to activate at a predetermined temperature in a space regardless of the rate at which the temperature in the space increases.
This is accomplished by compensating for the thermal lag between the room temperature and the interior of the device.
Construction consists of an outer metal tube that expands at a fixed rate. Within this tube, alarm contacts close when a certain expansion distance is reached, but this expansion is opposed by another metal device.
At a slow rate-of-rise in temperature, the outer tube expands drawing the contacts closer together.
The inner metal device exerts a counter force, keeping the contacts separated until the entire device has been heated to its rated temperature.
At a rapid rate-of-rise in temperature, the outer tube expands faster than the inner device can compensate.
Therefore, the alarm contacts close when the entire device has been heated to a lower level, thus compensating for thermal lag.
These detectors are designed to eliminate the thermal lag associated with a fixed temperature detector as well as the problem of false alarms and the risk of missing slow heat release combustion that are inherent with rate-of-rise detectors.
  • Responds accurately and positively to fire threats
  • Virtually eliminates false alarms
  • Not affected by dusty or dirty environments
  • More reliable than a smoke detector
  • Less expensive than smoke detector units
  • Minimal maintenance
  • Slower to respond than smoke detectors
  • Will not detect products of combustion
  • Only suitable for protection of property
Articles You May Like :
Fire Detection System
Oxygen Safety Analyzer
Catalytic Type Gas Sensor
Fire Extinguishers Mock Test
Basics of Sprinkler System
How to identify location of Fire Detectors
Gas Detectors Working Principle
Types of Fire and Gas Detectors
What is Lower Explosive Limit & Upper Explosive Limit ?
Industrial Flame Detectors
Basics of Gas Monitoring
Smoke Detector Testing Procedure
Fire Water Sprinklers Working Principle
Fire and Gas System Loop Checks Procedure
Basics of Fire Fighting Hydrant Systems
Sensor Technologies in Gas Detectors
Why Fire and Gas Detectors are 3-Wire types instead of 2 Wire?
Why LEL important in Gas Detection?
Chlorine Gas Hazards
Carbon Monoxide Gas Hazards
Lower Explosive Limit (LEL)
Argonite/CO2 Flooding System Master & Slave Cylinder Operation
Infrared Hydrocarbon Gas Detector Calibration Procedure
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Fire-Triangle-in-Gas-Detection-System
Basics of Fire Detection System
oxygen Safety Analyzer
Flare KOD
Flare Knockout Drums Working Animation
Transformer Efficiency and Loses Formula
PID Controller Graph - 3
PID Controllers Graphical Analysis
open vs closed loop
Open Loop and Closed Loop Animation
Ball Valve Pictures
How Ball Valves Work ?
BJT Amplifiers Interview Questions & Answers
PLC Program for fan control unit system
PLC Programming for Fan Control Unit System for Industry
Configure Analog Inputs and Outputs in Delta PLC
