Reading: Programmable Logic Controller Questions and Answers
Inst Tools > Blog > Instrumentation Interview Questions > Programmable Logic Controller Questions and Answers
Programmable Logic Controller Questions and Answers : Read complete PLC Multiple Choice Questions, PLC Interview Questions and Answers.
Last updated: November 2, 2023 5:00 pm
Instrumentation Interview Questions PLC Tutorials
Refer the below Programmable Logic Controller Questions and Answers which are useful for the exam preparation.
Programmable Logic Controller QuestionsPLC Answers
1. A switch or a pushbutton is a ________ input.
2. A lamp or a solenoid is an example of a ______ output.
3. The ____________ makes decisions and executes control instructions based on the input signals.
4. _________ _________ is a PLC programming language that uses components resembling elements used in a line diagram.
5. A _________ consists of one or more instructions that accomplish a task.
6. Memory is divided into three areas: _________ , _________ , and ________ _________ space.
7. When talking about computer or PLC memory, 1K refers to _________ bits, bytes, or words.
8. Software that is placed in hardware is called _________ .
9. Which of the following is not required when creating or changing a PLC program?
a. PLC
b. Programming Device
c. Programming Software
d. Connector Cable
e. Printer
10. A special cable, referred to as a _______ cable, is needed when a personal computer is used as a programming device.
11. Label the following statements as TRUE or FALSE.
11.a) Most PLCs have a fixed number of timers
11.b) Normally closed contacts “invert” the state of the signal they reference
11.c) PLCs are advantageous for use in fixed-circuit or fixed program operations
12. Complete the following statements.
12.a) PLC process scanning consists of the ____ scan, ____ scan and ____ scan.
12.b) ____ scanning and ____ scanning are the two methods (orders) in which PLCs solve ladder logic programs.
13. Describe the differences between an [XIC] and an [OSR] instruction.
14. Label the following statements as TRUE or FALSE.
14.a) PLC scan time is dependent on the complexity of the PLC program
14.b) Most PLC timers have microsecond resolution
Also Read : PLC Program for Analog Input Sampling
PLC Answers
1) discrete;
2) discrete;
3) CPU;
4) Ladder logic;
5) program;
6) program, data, configuarable parameter;
7) 1024;
8) firmware;
9) e;
10) PC/PPI.
11.a ) FALSE
11.b ) TRUE
11.c ) FALSE
12.a) INPUT, PROGRAM, OUTPUT
12.b) RUNG, COLUMN
13. An [XIC] (examine if closed) instruction is used in a ladder logic program to determine if a bit is on (1). When the instruction is executed, if the bit addressed is on (1), then the instruction is evaluated as TRUE.
When the instruction is executed, if the bit addressed is off (0), then the instruction is evaluated as FALSE. The [OSR] (one shot rising) instruction is true for one PLC scan when the rung conditions preceding the OSR go from false-to-true.
14.a) TRUE
14.b) FALSE
  • PLC Objective Questions
  • SCADA Questions
  • DCS Questions
PLC Ladder Logic Simulator Mobile Apps For Android
Types of PLC Memory
Flow Transmitters Questions and Answers – Instruments Test
Factory I/O PLC Automation Training Course (Free)
PLC Program for Washing Machine
Functional Block Diagram in PLC for Oil and Water Process
  • Robert says:
    February 4, 2020 at 1:21 pm
    I’m wondering if it’s possible to learn it by oneself with having a degree. I know that many people managed to learn programming without going to a college I myself managed to learn how to code in python and c# by only reading books and taking various courses from sites like Udemy, Linda, etc. I have two questions:
    1.) How difficult it would be to get started with plc programming and how different is from software engineering?
    2.) Where can I find a good and preferably not too expensive PLC just to get started ? https://www.AutomationDirect.com,
    https://www.Famaga.ch is there a better option?
Timer in Studio 5000 – TON, TOF, RTO
Rules for Writing SCL Language in Tia Portal
Extended Timer Logic in PLC
Ultrasonic Level Measurement Questions and Answers
Motor Trip Logic using PLC Programming
Why is RTO used in the Place of TON Timer?
Valves Pressure Loss – Questions and Answers
PLC Programming for Garden Sprinkle System
PLC Programming for Garden Sprinkler System
Open User Communication in Siemens Tia Portal - PLC to PLC
Open User Communication in Siemens Tia Portal – PLC to PLC
Preventive Maintenance of Variable Frequency Drive
PLC Program to Control Motor Speed using VFD Drive
Motor Speed Control using VFD and PLC Programming
SCADA Multiple Choice Questions
Master Control Reset (MCR) ladder logic
How to use Master Control Reset (MCR) Instruction in PLC
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
Control Panel
RTD Measuring with three leads
How 3 Wire RTD Lead Wire Resistance Eliminated?
Piezo-electric Acceleration Measuring Device
5-Port-2-Position-Valve-Animation
5 Port 2 Position Valve Working Principle
PLC Automatic Control of Two Outputs with one Input
What is a Router
PLC Logic Example on Multiple Switches and Motors
Determine the statuses of all lamps and relay coils in the circuit
Determine the Status of Lamps and Relays in the Circuit ?
Surge Protection Device
