Reading: PLC Electric Motor Interlocks
Inst Tools > Blog > PLC Tutorials > PLC Electric Motor Interlocks
Last updated: March 4, 2021 4:51 pm
PLC Tutorials Practical Questions
7 Comments
Programmable Logic Controller Questions and Answers
PLC Electric Motor InterlocksAnswer :High vibration:Low inlet pressure:High outlet pressure:
The following PLC program was written to control the operation of a large electric motor-driven pump. A variety of “permissive” inputs protect the pump from damage under abnormal conditions:
Identify the type of contact (either NO or NC) necessary for each of these electrical switch contacts, based on the trip condition (either high or low) and how each input is applied in the PLC program:
  1. Start pushbutton = NO or NC?
  2. Stop pushbutton = NO or NC?
  3. High vibration = NO or NC?
  4. Low inlet pressure = NO or NC?
  5. High outlet pressure = NO or NC?
  6. High motor temperature = NO or NC?
  7. High pump temperature = NO or NC?
Answer :
  3. High vibration = NC
  6. High motor temperature = NC
A helpful problem-solving technique is to first identify the necessary coloring which will allow the motor to run (i.e. the condition of all permissives during correct operating conditions):
PLC Motor Permissive
We know the NO contact instruction labeled “Permissive” in the upper rung needs to be colored if ever the “Motor” coil instruction is to receive color.
This means the entire series string of contact instructions in the second rung needs to be colored under proper operating conditions.
Once we know this, we may determing the necessary “normal” statuses of all permissive switches in order to make their corresponding PLC program contact instructions colored. A few examples will be given here:
High vibration:
The PLC contact instruction for this permissive is normally-open, which means that PLC input must be energized with electricity in order to color that contact instruction.
This means the high vibration switch must be in the closed condition while everything is running as it should (i.e. low vibration), and open if vibration becomes excessive.
A vibration switch that is closed when vibration is below the trip threshold is a normally-closed (NC) vibration switch.
Low inlet pressure:
This means the low inlet pressure switch must be in the closed condition while everything is running as it should (i.e. adequate inlet pressure), and open if inlet pressure becomes too low.
A pressure switch that is open when pressure is below the trip threshold is a normally-open (NO) pressure switch.
The PLC contact instruction for this permissive is normally-closed, which means that PLC input must be de-energized in order to color that contact instruction.
This means the high outlet pressure switch must be in the open condition while everything is running as it should (i.e. moderate outlet pressure), and close if outlet pressure becomes excessive.
Share Your Answer / Comments
Credits : by Tony R. Kuphaldt – under CC BY 1.0
For More PLC Questions : CLICK HERE
  • PLC Pump Permissive Interlocks
  • Permissive and Interlock Circuits
  • Basics of Trips, Interlocks, Permissives & Sequences
  • Troubleshooting PLC Permissive Inputs
  • PLC Permissive for Motor Control
PLC based Drink Dispenser System
Schneider PLC Example: Control Lamps Sequences
Wood Sawing and Blower System: PLC Control Design
PLC Program for Stage Control: Curtains and Stage Elevation
7 Comments
  • Dimitris says:
    September 1, 2017 at 5:04 pm
    Hello and thanks for the interesting arcticles that you post .I would to like to ask something because i m a bit confused .I can’t understand why he uses n.o contact for high pressure and XIO in PLC? Wouldn’t be more safe to use n.c contact for high pressure and XIC in PlC? In a case of a loss of the cable the motor won’t cut from high outlet pressure . Thanks
  • Debabrata Rout says:
    January 28, 2019 at 6:09 pm
    This ladder diagram is excellent . Send me more ladder diagram.
  • M Iqbal says:
    March 10, 2019 at 10:06 pm
    Dears,
    The Interlocking is good but one mistake still exists and that is stop push button must be in NC else it will not run.
  • chuangbing chen says:
    March 30, 2021 at 6:06 pm
    I agree with M Iabal
  • Alfred G Kebbie says:
    February 19, 2022 at 5:58 pm
    I’m interested in training the PLC programming Automation
  • J.BALAJI says:
    September 3, 2022 at 6:20 am
    I am plc working and full and fully interested so while all control and interlocking circuit improve tha movement
  • Rotimi Adeyeye says:
    April 23, 2025 at 7:39 pm
    A button to ON lamp same button to OFF the lamp.
Allen Bradley SLC 500 PLC Programming
Developing PLC Logic for Water Pumping and Chemical Addition
Paint Mixing System
Displacer Level Transmitter Question & Answer
Down Counter PLC Program
Oil and Water Separation Process using PLC Programming
Calculate Hydraulic System Fluid Pressure
How to Create Faceplate in FactoryTalk View Studio?
Omron PLC real-time clock street lighting program
Automatic Highway Lights Program using RTC in Omron PLC
Shift Bit Register in PLC
Convert an Electrical Diagram into PLC Program
How to Convert an Electrical Diagram into PLC Program?
Motor Library in Studio 5000 PLC
Create User-Defined Data Types and Function Blocks in Studio 5000
Dual-junction thermocouple circuit
Find Thermocouple Ouput Voltage
Siemens PLC Simulator and Plant Simulation Software
PID block from the PLC library
How to Configure PID Controller in Various Schneider PLCs?
Does Really a Safety Barrier is Important
Does Really a Safety Barrier is Important? – PLC DCS Systems
Three Phase To Single Phase Wiring Connections
Single Phase Power Wiring Schemes
Ultrasonic Flow Meters Working Principle
Piston Type Flow Meter Principle
Types of Variable Area Flow Meters
Current Divider Rule
quantum computer
Vacuum Technology is Enabling New Era of Ultra-Powerful Computers: Quantum Computing
Electrical Cabinet Air Conditioner
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Use of Isolators and Barriers in Electrical Panel
