Reading: Pressure Transmitter Re-Range Questions
Inst Tools > Blog > Practical Questions > Pressure Transmitter Re-Range Questions
If a smart (digital) pressure transmitter configured with re-range then does it need to be re-trimmed as well?
Last updated: September 7, 2020 8:47 pm
Practical Questions
2 Min Read
The pressure transmitter PT-89 on this natural gas separator vessel presently has a calibrated range of 0 to 400 PSIG.
Operations personnel would like you to re-range this transmitter for 300 to 375 PSIG instead:
Answer the following questions about the task of re-ranging, explaining each of your answers:
1. Does the new, requested range constitute a zero shift, a span shift, or both?
2. If this is a “smart” (digital) transmitter, does it need to be re-trimmed as well as re-ranged?
3. Will the control room indicator PIR-89 need to be re-calibrated, re-ranged, or both?
4. Will the local pressure gauge PG-131 need to be re-calibrated as well?
5. Will the pressure safety valves PSV-11, PSV-12, and/or PSV-13 need to be set for lower “lift” pressures?
6. If the maximum (factory) range of this pressure transmitter is 0 to 750 PSI and the maximum turndown ratio for the required accuracy is 20:1, will it be able to meet the new range? If not, what might you have to do in order to fulfill the operations’ request?
7. Why do you suppose operations would like you to re-range this transmitter? In other words, what operational advantage(s) might be gained from doing so? Are there any potential disadvantages of having the new range versus the old?
  • Water Filter Instrumentation
  • Steam Eductor Question
  • Instrument Zero Calibration
  • Flow Meter Calculations
  • Smart Transmitter LRV & URV
Credits: Tony R. Kuphaldt
Liquid Level Switch Control Logic
Displacer Type Density Transmitter Question
Programmable Logic Controller (PLC) Questions and Answers – 17
What Affect the Pressure Measurement Accuracy of a Manometer?
Electronic Pressure Sensor with Bourdon Tube and LVDT
Calculate Amount of Weight Indicated by the Scale
Solenoid Valves Questions & Answers – 4
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
Galileo Thermometer
Analytical Control System of Heat Exchanger Questions
Determine LRV and URV settings for the Level Transmitter
PLC Electric Motor Interlocks
Analyze the Relay Circuit and Find the Status ?
DP Transmitter Block and Bleed Valve
DP Transmitter Block and Bleed Valves
Thermocouple measurement and reference junction temperatures
Thermocouple Measurement and Reference Junction Temperatures
Pneumatic Transmitter
Pneumatic Level Transmitter Calibration Table
steam heat exchanger
Practical Process Control System Questions & Answers – 9
Problem on Solar Hot Air Collector and Variable Speed Fan
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
measure the temperature of RTD
Measure the Temperature of the RTD
4-wire pH Transmitter Problem
Level Transmitter trend
Identify Level Control Loop Tuning Problems
Optocoupler Principle
Optocouplers Working Principle
Digital Electronics Objective Questions – Set 11
Factors to Consider When Choosing Power Tools
Pre-commissioning or Commissioning Activities
Flare KOD
Flare Knockout Drums Working Animation
Certified Automation Professional (CAP) Exam Questions
Determine Calibration Range of Pneumatic Pressure Transmitter
