Reading: Pressure Gauges with Diaphragm Sensor Principle
Inst Tools > Blog > Pressure Measurement > Pressure Gauges with Diaphragm Sensor Principle
Last updated: August 1, 2019 7:41 pm
1 Min Read
Diaphragm elements are circular-shaped, convoluted membranes. They are either clamped around the rim between two flanges or welded and subject to the pressure of the media acting on one side.
The deflection caused in this way is used as a measurement for the pressure and is indicated by a pointer.
Compared with bourdon tubes these diaphragm elements have a relatively high activating force and because of the annular clamping of the element they are insensitive to vibration.
The diaphragm element can be subject to higher overload through load take-up points (by bringing the diaphragm element up against the upper flange).
Moreover, the measuring instrument can also be protected against extremely corrosive media by coating with special material or covering with foil.
Wide connection ports, open connection flanges and purging plugs can be integrated for measuring highly viscous, impure or crystallizing media.
Pressure ranges are between 0 ~ 16 mbar and 0 ~ 40 bar in accuracy class from 0.6 to 2.5 %.
Credits : N Asyiddin
Temperature Compensation for Pressure Measurement
Differential Pressure Transmitter Working Principle
Basics of Differential Pressure Transmitters
Pressure Transmitter Manifolds
McLeod Gauge Working Principle
Vacuum Gauges Working Principle
Questions on Pressure Transmitter Calibration Setup
Pressure Gauge Accessories
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
What is Hammer Effect in Gauges ?
Pressure Measurement Objective Questions
Differential Pressure Sensors Calibration Procedure
Pressure and Temperature Gauges
Types of Pressure – Instrument Questions and Answers
Inclined-limb Manometer Formula - 2
Inclined-limb Manometer Principle
Types of Pressure
Basics of Pressure Measurement
pressure gauge snubber
Pressure Gauge Snubbers
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Absolute and Gauge Pressure
Difference Between Absolute and Gauge Pressure
strain gauge with Diaphragm
Strain Gauge Working Principle
Diaphragm
Diaphragms
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
PLC TB Wiring
Electrical Signal and Control Wiring
Top 100 Home Automation Projects
Measurements & Instrumentation Quiz – Set 9
DC Generators Characteristics Quiz
LEL vs Percent By Volume vs Parts Per Million vs Parts per Billion
DCS System Layout and its Different Parts
Control Valve Passing Problem after Overhauling Job
