  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Pressure Gauge Installation at Pump Discharge
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Pressure Measurement > Pressure Gauge Installation at Pump Discharge
Last updated: October 14, 2019 9:55 am
2 Min Read
Remember everyone! Pressure gauge shall be installed after pump discharge nozzle and before check valve. The consequence is if you have two pumps (one is running and another is stand by, then you have to install two pressure gauge). The reason is:
what is the big deal if I will put the pressure gauge after check valve?Can you please tell me how to do and verify pump depressuring for maintenance in detail?
To show actual pump discharge pressure. If you install pressure gauge after check valve, the value of discharge pressure won’t be actual due to pressure loss of check valve
In the case of check valve failure, pressure gauge will show actual discharge pressure. If the pump has problem, pressure gauge will show pressure value lower than usual
Also Read : Pressure Transmitter Working Animation
1- You cannot verify pump depressuring for maintenance
2- You cannot check actual pump discharge pressure for performance evaluation
3- You cannot meet some codes (e.g. ANSI K61.1) requirement to install pressure gauge immediately after the pump discharge nozzle
4- You cannot make true reading of discharge pressure of the pump
5- Looking at maintenance point of view, you cannot evaluate check valve leakage when the pump is tripped and the discharge line isn’t blown down
It means if you would isolate a pump by closing suction/discharge isolation valves during maintenance and decide to depressure the pump (e.g.by opening the pump vent), you would realize the time mentioned pump is depressured by reading the PG, only when the pressure gauge has already been installed between pump and the check valve.
Also Read : Pressure Sensors Principle
Recommended Articles
Basics of Pressure Measurement
Purpose of Stop in a Pressure Measuring Instrument
Well Manometer Principle
Pressure Gauges : Remote and Chemical Seals
Differential Pressure Transmitter Working Principle
Differential Pressure Transmitter with 5 Way Manifold Valve
208kSubscribersSubscribe
Recent Comments
Related Articles
Three Valve Manifold
3 Valve Manifold Operation
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
The Principle of Dead Weight Pressure Tester
Differential Pressure Sensor Calibration
Differential Pressure Sensors Calibration Procedure
Pressure Transmitter Impulse Lines Heat Trace
Pressure Transmitters Heat-traced impulse lines
Pressure Unit Conversion Practical Example
Inclined-limb Manometer Formula - 2
Inclined-limb Manometer Principle
Pressure Transmitter Basics
Pressure Transmitter Applications
More Articles
Ziegler-Nichols open-loop Tuning
Ziegler-Nichols Open-Loop Method
OTDR testing
OTDR Testing
Instrumentation Word Game
Network topologies
Different Types of Network Topologies
Gas-Insulated Transmission Line
What is Gas-Insulated Transmission Line? Principle Advantages
Fire Alarm System Commissioning Procedure
Direct Lift Diaphragm Normally Open Solenoid Valve
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Basic Requirements of Sizing the Control Valves
Basic Requirements of Control Valves Sizing
