Reading: Example PLC Program
Inst Tools > Blog > PLC Tutorials > Example PLC Program
Example PLC Program
A PLC has been programming to control the starting and stopping of a three-phase electric motor.
Last updated: March 4, 2021 10:59 am
PLC Tutorials Practical Questions
2 Min Read
Shown here is a partial wiring diagram and offline PLC program display for the system:
Example PLC Program
Example PLC Program
Identify the problem(s) in this PLC program, and modify it so that it will work as it should.
Answer:
The PB_stop and OL_switch instructions in the second rung of the PLC program need to be connected in parallel with each other rather than in series.
Being NC real-world switches and NC contact instructions, each one will “color” when the motor is supposed to stop (i.e. the PB_stop instruction colors when anyone presses the Stop pushbutton, and the OL_switch instruction colors when the motor overheats).
Right now, programming in series with each other, both conditions would have to take place in order to stop the motor!
To make the motor stop if either condition occurs, we need these two instructions to be programmed in a logical “OR” fashion, and that necessitates a parallel connection between the two contact instructions.
More PLC Questions :
PLC Programming Questions & Answers – 1
PLC Programming Questions & Answers – 2
PLC Programming Questions & Answers – 3
PLC Programming Questions & Answers – 4
PLC Programming Questions & Answers – 5
PLC Programming Questions & Answers – 6
PLC Programming Questions & Answers – 7
Purpose of Stop in a Pressure Measuring Instrument
How to Retrieve PLC Project From Memory Card?
Draw the appropriate Pressure Switch Symbol ?
Allen Bradley PLC to PLC Communication in Studio 5000
3 to 8 Line Decoder PLC Ladder Diagram
  • Paul Nguyen says:
    September 27, 2021 at 2:52 am
    It seems to be wrong for this answer.
How to Create Project in Wonderware Intouch?
PLC Program for Ceramic Burning Oven Conveyor System
Smart DP Transmitter Flow Meter Calculations
Test and Process Modes in Siemens PLC
Programmable Logic Controller Questions and Answers
#9 PLC Best Practices – Validate indirections
Online PLC Ladder Logic
Mis-conceptions of PLC Ladder Logic
PLC Program Upload
How to Upload Siemens PLC Programs?
Omron PLC programs
ICS System Design
Micro PLC
Micro PLC Hardware Configuration
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Difference Between Normal Counters and Fast Counters - PLC Basics
Difference Between Normal Counters and Fast Counters – Learn PLC
Chemical Sensors Objective Questions
Flare KOD
Flare Knockout Drums Working Animation
Cable Trays
Types of Cable Trays – Purpose, Advantages, Disadvantages
Three Wire RTD Temperature Compensation
Ambient Temperature Effects on RTD
Sugar Industry Logics
Mill Interlocks in the Sugar Industry
Yokogawa DCS Tutorials - Configuration of Analog Input (Transmitter)
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
Field Transmitter Damping
What is Field Transmitter Damping ?
