Reading: Output Regulator & the Tracking Problem
Inst Tools > Blog > Multiple Choice Questions > Output Regulator & the Tracking Problem
1. For output regulator problem in performance index the parameter which is set to zero:
a) Input vector
b) Output vector
c) Control vector
d) State vector
Answer: b
Explanation: As the problem is to minimize the performance index involving output vector then the output vector must be close to zero.
2. In tracking problem the parameter reduced is :
a) Error
b) Output
c) Input
d) State
Answer: a
Explanation: In tracking problem the main objective is to reduce error and this is the main concern so as to reduce error.
3. Riccati equation is formed by using:
a) Output regulator problem
b) Finite state regulator problem
c) Infinite state regulator problem
d) Tracking problem
Answer: d
Explanation: Riccati equation can be formed using the results of the tracking problem as it is mainly applied in the cases where the errors are reduced to the minimum.
4. The value of K must further follow the following constraint that the closed loop system must be:
a) Asymptotically stable
b) Stable
c) Marginally stable
d) Conditionally stable
Answer: a
Explanation: The value of Ki must further follow the following constraint that the closed loop system must be asymptotically stable and this is due to the fact that the value of k matrix can be varied.
5. For suboptimal control the value of R is assumed to be:
a) Positive definite
b) Non-positive definite
c) Negative
d) Complex
Answer: b
Explanation: For suboptimal control the value of R is not assumed to be positive definite but it can also be assumed to be zero.
6. Which one of the following compensation is required for improving the transient response of the system?
a) Phase lead compensation
b) Phase lag compensation
c) Gain compensation
d) Both phase lag compensation and gain compensation
Answer: a
Explanation: For increasing or improving the transient response derivative controller is used and which is the phase lead compensation.
7. Pneumatic controller
a) Flexible operation
b) High torque high speed operation
c) Fire and explosion proof operation
d) No leakage
Answer: c
Explanation: Pneumatic controllers are fire and explosion proof operation as they require air and gas fuel for its operation.
8. Hydraulic controller:
d) No leakage
Answer: b
Explanation: Hydraulic controller must have no leakage and also it requires high torque and high speed operation due to high density of the controller.
9. Electronic Controller:
d) No leakage
Answer: a
Explanation: Flexible in all sense as it does not require heavy components or extra torque or high speed operations.
10. Which one of the following statement is correct?
A plant controlled by a proportional controller. If a time delay element is introduced in the loop its:
a) Phase margin remains the same
b) Phase margin increases
c) Phase margin decreases
d) Gain margin increases
Answer: c
Explanation: The introduction of a time delay element decreases both the phase and gain margin.
Continuous Wave NMR Spectroscopy Questions & Answers
Infrared Spectrometers Questions & Answers
Fuzzy Logic Control
IR Instrumentation Questions & Answers
Split-Range, Auto-Selector, Ratio & Cascade Systems
Feedback and Non-feedback Systems Objective Questions
Robotic Control System – Part II
Pneumatic Systems Objective Questions
Chromatographic Behaviour of Solutes Questions & Answers
Preliminary Considerations of Classical Design
Z & S Domain Relationship
The Z-Transform
The Infinite Time Regulator Problem
Time Response Analysis
Effect of Adding a Zero to a System
Ionization of Gases Questions and Answers
Stability in Frequency Domain
Mathematical Preliminaries
Nuclear Magnetic Resonance Spectrometer Questions & Answers
Flow Measurement Questions
MCQ on Flow Measurement
Ion Transducers Questions & Answers
Instrumentation for Electron Spectroscopy
Liquid Scintillation Counters Questions & Answers
Vortex flow meter Bluff Body
Types of Vortex Flow Meter Sensors
Explain how this is an example of Ratio Control?
Questions on Ratio Control System
Pulse Generation using Timer in Siemens PLC
Annunciators - 2
What is a Annunciator ?
What is Heat Pump Water Heater?
radar-level-sensor-
Non-Contacting Radar Level Transmitter Working Principle
Transformer MCQ - Multiple Choice Questions
200+ Transformer MCQ – Multiple Choice Questions
Create PLC Program based on Logic Circuit
