Reading: Optical Torsion Meter Principle
Inst Tools > Blog > Common > Optical Torsion Meter Principle
Last updated: August 26, 2018 8:02 pm
Common
2 Min Read
Basic Principle
Due to torque, an angular twist (angular displacement) occurs on the shaft between its ends. This angle of twist is measured by using optical means where in angular deflection of light rays is proportional to twist and hence the torque.
Construction of optical torsion meter
The main parts of an optical torsion meter as follows:
  1. A shaft is used on which two casting M and N are connected at a known distance.
  2. A tension strip linking the two castings.
  3. Two mirrors which are fitted and aligned on the castings.
  4. A light beam falling on the mirrors, an optical system and a torque calibrated scale.
Operation of optical torsion meter
When the shaft is transmitting torque, a relative movement occurs between castings M and N, and due to this, the mirrors will change position ( partial inclination between the two mirrors) since they are attached to the castings.
As the mirrors are constantly made to reflect a light beam on the torque calibrated scale, due to the changed position of the mirrors, there will be an angular deflection of the light rays which is measured from the calibrated scale.
This angular deflection of the light rays is proportional to the twist on the shaft (relative movement of casting M and N) and hence the torque of the shaft.
Applications of optical torsion meter
It is used in steam turbines and I.C engines
Best Online Courses to Learn Electrical Engineering
Types of Sensors used in the Dairy Industry
How to Use Production Line Failures for Your Gains?
Basics of Two, Three & Four Wire Transmitters
Why PDMS is Used For Fabrication?
What are Oil Burners? Types, Advantages, Applications
What Type of Heating is Best for Your Home?
Web Tension Measurement and Control Technologies
Hydraulic Shaper Machine – Components, Circuit, Principle
Career Opportunities and Scope in Industrial Automation
Liquid Nitrogen in Instrumentation
Understanding the Chiller Maintenance – HVAC Tutorials
CNC Programming – Definition, Types, and Tips
Smart Transmitters Advanced Diagnostics
Industrial Automation Controls used in HVAC
Supermarket HVAC Ventilation System
Supermarket Ventilation System – HVAC Basics
Instrumentation Word Game
Benefits of IoT in the Manufacturing Industry
Wrong Orifice Installation
How Not to Install an Instrument and Wrong Practices
Instrument Interactive User Experience
Streamlining Field Instrumentation: The Role of Advanced Overlays
What is a cable gland?
How Many Types of Cable Glands Are There?
Alternative Optical Proximity Sensor
Proximity Sensor
Features of Scada Which are Must in an IoT System
Switchgear & Protection Objective Questions and Answers
Faceplate in WinCC
Siemens HMI Training – Using UDTs with Faceplates
Diagnosing the Electric Motor Circuit
Diagnosing Electric Motor Circuit
Electromagnetic Subject Quiz
Pressure Transmitter Circuit
ultrasound
Ultrasonic Gas Leak Detectors (UGLD)
Important Factors Consider during Piping Design
