Reading: Online Analyzers Questions & Answers
Inst Tools > Blog > Instrumentation MCQ > Online Analyzers Questions & Answers
Last updated: June 21, 2025 10:05 am
Instrumentation MCQ Multiple Choice Questions
1. Conductivity and pH measurement are:
a. Two different techniques
b. Similar in operation
c. identical but given different names
d. Two techniques that use the same equipment
Answer: a
2. The three factors that control the conductivity of an electrolyte are:
a. Specific gravity, density, and volume
b. Concentrations, the material in solution, and temperature
c. Color index, turbidity, and temperature
d. Hydrogen on concentration, temperature, and pressure
Answer:b
3. pH is a measure of:
a. Effective acidity or alkalinity of a liquid
b. The oxidation or reduction properties of a solution
c. Specific conductance of an electrolyte or total ionic activity
d. Purity in an aqueous solution
Answer: a
4. A buffer solution is used with pH-measuring instruments to:
a. Standardize the equipment
b. Protect the equipment
c. Clean the electrodes
d. Platinize the reference electrode
Answer: a
5. Oxidation-reduction potential (ORP) is a measurement of :
a. The oxidizing or reducing chemical properties of a solution
b. The oxygen present in any quantity of a given gas mixture
c. The hydrogen ion concentration in a given solution
d. The degree of ionization for a particular solution
Answer: a
6. Capacitance measurement are usually applied to:
a. Conducting liquids
b. Non Conducting liquids
c. Gas measurements
d. Ionized gases
Answer: b
7. Which of the following are electrochemical measurements
a. Humidity and density
b. Turbidity and differential vapor pressure
c. pH and ORP
d. Dew point and boiling point rise
Answer: c
8. A salt (NaCl) solution must be controlled at a concentration of 12 percent.The best choice of measurement for the control system would be
a. Conductivity
b. pH
c. ORP
d. Capacitance
Answer: a
9. An industrial effluent stream is to be neutralized by adding a sodium hydroxide solution. The best choice of analytical measurement for the control system would be:
a. Conductivity
b. pH
c. ORP
d. Capacitance
Answer: b
10. Ion-selective measurements
a. Are similar to conductivity in operation but use a different cell
b. Are similar to capacitance measurement but use a different instrument
c. Are similar to pH measurement but use different electrodes
d. Are similar to density but use more exact techniques
Answer: c
11. A pH control system is used to neutralize a chemical waste stream being dumped into a municipal sewage system. The desired pH is 7 or complete neutrality. An unfortunate accident short circuits the cable connecting the electrodes to the measuring transmitter.The result will be:
a. The control valve admitting the neutralizing agent will fully open
b. The control valve will close
c. The control valve will remain approximately at its half-open position
d. The system will cycle
Answer: c
12. The concentration of salt in a liquid used to carry a slurry must be monitored. The best choice for measurement will be:
a. Electrodeless conductivity
b. pH
c. ORP
d. An ion-selective system
Answer: a
13. A pH system is to be selected. It is required that the system function with little or no maintenance The reference electrodes elected would be
a. A flowing type
b. A pressurized flowing type
c. A nonflowing type
d. A pressurized nonflowing type
Answer: c
14. The pH of 8 streams is to be monitored accurately. It is discovered that the temperature of this stream varies from 40 to 60°F
a. A measuring system with automatic temperature compensation is indicated
b. Temperature compensation is not necessary
c. A manual temperature compensation will be adequate
d. The pH range will determine the need for temperature compensation
Answer: a
15. The most popular carrier gas used in gas chromatograph is :
a. Helium
b. Air
c. Hydrogen
d. Oxygen
Answer: a
Measurements & Instrumentation Quiz – Set 10
Measurement of Current Objective Questions
Stability Analysis
100+ Questions and Answers on Industrial Automation and Control
Column Efficiency and Column Resolution Questions and Answers
Pneumatic Control Mechanisms Objective Questions
Types of Flow Meters MCQ – Instrumentation and Control
Control Loop Multiple Choice Questions
Instrumentation Materials Test
Measurements & Instrumentation Quiz – Set 6
Measuring Instruments MCQ
Electronics and Instrumentation Students Quiz
NO2 Analyzer Questions & Answers
Types of NMR Spectrometers Questions & Answers
Top 100 Control Systems Objective Questions & Answers
Analog Recorders Objective Questions
Frequency Response MCQ
Bode Plots MCQ
Digital Circuits Questions & Answers
Filtering and Dynamic Compensation Objective Questions
Valves MCQ
Valves MCQ
Time Response Analysis
Effect of Adding a Zero to a System – II
Instrument Calibration Multiple Choice Questions
Hammer Effect in Gauges
What is Hammer Effect in Gauges ?
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Transistor Transistor Logic (TTL) Objective Questions
Instrumentation Engineering Students Test
Gas Detectors Location Installation
Gas Detectors Installation Techniques
RTD with Thermowell
Temperature Sensor Accessories
Process vessel for measuring water level
Level Measurement Lab Exercise
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
