Reading: MCB vs Fuse Questions and Answers
Inst Tools > Blog > Electrical Basics > MCB vs Fuse Questions and Answers
Study the key insights on MCB versus fuse through our questions and answers and learn about circuit protection and electrical safety.
Last updated: August 31, 2024 8:09 pm
Electrical Basics Electrical MCQ
14 Min Read
MCB vs Fuse QuestionsWhat is the basic working principle of an MCB?How does a fuse operate to protect an electrical circuit?How does an MCB differ from a fuse in terms of reusability?What is a significant advantage of MCBs over fuses in detection?Which is more reliable for long-term use, MCBs or fuses?How do MCBs and fuses compare in terms of response time?Which offers better protection against short circuits, MCBs or fuses?Which device is more cost-effective in the long run, MCB or fuse?How do MCBs and fuses differ in terms of thermal stability?In terms of maintenance, how do MCBs and fuses compare?Which device provides more precise protection settings?How do the safety features of MCBs compare to fuses?In what aspect do fuses outperform MCBs in certain applications?In terms of environmental impact, which is better, MCBs or fuses?How does the installation process of MCBs compare to that of fuses?How do the response characteristics of MCBs compare to those of fuses?What is a practical advantage of using MCBs in industrial applications?How does the reset capability of MCBs enhance their usability?Why might fuses still be used despite the advantages of MCBs?How does the physical size of MCBs compare to fuses?How does the trip curve flexibility of MCBs compare to fuses?Which device generally requires more inventory management, MCBs or fuses?How do MCBs and fuses compare in terms of response to transient currents?How does the physical construction of MCBs compare to fuses?How do MCBs and fuses differ in terms of response to gradual overloads?In terms of operational noise, how do MCBs compare to fuses?How do MCBs and fuses differ in terms of their impact on system downtime?Which device offers better integration with remote monitoring systems, MCBs or fuses?How does the response time of MCBs compare to fuses in detecting overloads?What is a major disadvantage of using MCBs compared to fuses?How does the response to short circuits differ between MCBs and fuses?What is a disadvantage of fuses in terms of long-term use?How does the magnetic trip function in an MCB work?What is a key disadvantage of fuses in terms of system downtime?How does the design complexity of MCBs compare to fuses?What is a disadvantage of using MCBs in terms of physical size?What is the impact of the thermal element in an MCB on its tripping time?What is a common limitation of fuses in high-power applications?What disadvantage does the complexity of MCBs introduce compared to fuses?What is a significant disadvantage of fuses regarding selective coordination?
This video provides the detailed explanations for these MCB questions.
MCB vs Fuse - Most Asked Electrical Interview Questions
Question 1
A. Mechanical relay
B. Hydraulic pressure
C. Chemical reaction
D. Magnetic and thermal tripping
Show the Answer
Question 2
A. Uses a solenoid to trip
B. Melts its internal element
C. Changes its physical state
D. Activates a mechanical switch
Show the Answer
Question 3
A. Both are reusable
B. Fuses are reusable; MCBs are not
C. Neither are reusable
D. MCBs are reusable; fuses are not
Show the Answer
Question 4
A. Fuses can detect only short circuits
B. MCBs provide clear tripping indication
C. Fuses provide clear tripping indication
D. MCBs can detect only overloads
Show the Answer
Question 5
A. Both are equally reliable
B. Neither are reliable
C. MCBs are more reliable
D. Fuses are more reliable
Show the Answer
Question 6
A. MCBs have a faster response time
B. Both have similar response times
C. Fuses have a faster response time
D. Response times vary widely for both
Show the Answer
Question 7
A. Both offer equal short circuit protection
B. Fuses offer better short circuit protection
C. Neither offers adequate short circuit protection
D. MCBs offer better short circuit protection
Show the Answer
Question 8
A. Neither is cost-effective
B. Both are equally cost-effective
C. Fuses due to low initial cost
D. MCBs due to reusability
Show the Answer
Question 9
A. Fuses offer better thermal stability
B. Both offer equal thermal stability
C. MCBs offer better thermal stability
D. Neither offers thermal stability
Show the Answer
Question 10
A. Neither requires maintenance
B. MCBs require more maintenance
C. Fuses require more maintenance
D. Both require the same maintenance
Show the Answer
Question 11
A. Neither provides precise protection
B. MCBs due to adjustable settings
C. Fuses due to their fixed nature
D. Both provide equally precise protection
Show the Answer
Question 12
A. MCBs have fewer safety features
B. Fuses have more safety features
C. MCBs have advanced safety features
D. Fuses have advanced safety features
Show the Answer
Question 13
A. Reusability
B. Reset capability
C. Adjustable settings
D. Cost
Show the Answer
Cost
Question 14
A. MCBs due to longer lifespan
B. Fuses due to lower production footprint
C. Both have similar environmental impact
D. Neither is environmentally friendly
Show the Answer
Question 15
A. Both have equally complex installations
B. MCBs are easier to install
C. Neither is easy to install
D. Fuses are easier to install
Show the Answer
Question 16
A. MCBs and fuses respond at the same speed
B. Fuses have a delayed response
C. MCBs have a delayed response
D. Neither device responds quickly
Show the Answer
Question 17
A. Ability to handle higher fault currents
B. Faster response to overloads
C. Adjustable tripping settings
D. Lower initial cost
Show the Answer
Question 18
A. Allows for quick restoration of power
B. Ensures higher breaking capacity
C. Provides better visual indicators
D. Reduces the need for additional protection devices
Show the Answer
Question 19
A. Lower cost and simplicity
B. Better for high-voltage applications
C. Higher breaking capacity
D. More reliable in all conditions
Show the Answer
Question 20
A. MCBs are generally larger
B. Neither has a standardized size
C. Fuses are generally larger
D. Both have similar sizes
Show the Answer
Question 21
A. MCBs offer adjustable trip curves
B. Fuses offer adjustable trip curves
C. Both offer adjustable trip curves
D. Neither offers adjustable trip curves
Show the Answer
Question 22
A. Both require the same level of management
B. MCBs
C. Fuses
D. Neither requires inventory management
Show the Answer
Fuses
Question 23
A. MCBs handle transient currents better
B. Fuses handle transient currents better
C. Both handle transient currents equally well
D. Neither handles transient currents effectively
Show the Answer
Question 24
A. Fuses have a more complex construction
B. Neither has a complex construction
C. MCBs have a more complex construction
D. Both have similar physical construction
Show the Answer
Question 25
A. Fuses handle gradual overloads better
B. Both handle gradual overloads equally well
C. Neither handles gradual overloads effectively
D. MCBs handle gradual overloads better
Show the Answer
Question 26
A. Fuses are noisier
B. Both generate the same level of noise
C. MCBs are noisier
D. Neither generates operational noise
Show the Answer
MCBs are noisier
Question 27
A. Fuses reduce system downtime
B. Neither impacts system downtime
C. MCBs reduce system downtime
D. Both have the same impact on system downtime
Show the Answer
Question 28
A. Fuses offer better integration
B. Both offer equal integration
C. MCBs offer better integration
D. Neither integrates well with remote monitoring
Show the Answer
Question 29
A. Both have similar response times
B. Fuses have a faster response time
C. MCBs have a faster response time
D. Neither responds quickly
Show the Answer
Question 30
A. Slower response to short circuits
B. Lack of reusability
C. Higher initial cost
D. Lower breaking capacity
Show the Answer
Higher initial cost
Question 31
A. Neither responds quickly
B. Both respond at the same speed
C. MCBs respond faster
D. Fuses respond faster
Show the Answer
Question 32
A. Difficult to install
B. Higher maintenance due to replacement needs
C. Complex operational mechanism
D. Limited availability
Show the Answer
Question 33
A. Relies on hydraulic pressure
B. Changes the physical state of the material
C. Uses a chemical reaction
D. Activates a solenoid with high current
Show the Answer
Question 34
A. They blow too slowly
B. They require resetting
C. They cannot handle high currents
D. They need to be replaced when blown
Show the Answer
Question 35
A. Fuses have a simpler design
B. MCBs have a simpler design
C. Both have equally complex designs
D. Neither has a complex design
Show the Answer
Question 36
A. They are larger and take up more space
B. They require additional cooling systems
C. They are too small for high currents
D. They are difficult to install
Show the Answer
Question 37
A. It prevents the MCB from tripping
B. It causes an instant trip
C. It delays the tripping
D. It has no impact on tripping time
Show the Answer
Question 38
A. They cannot be reset
B. They are too large for compact systems
C. They have a high initial cost
Show the Answer
Question 39
A. Increased risk of failure
B. Reduced durability
C. Higher cost and potential for mechanical issues
D. Inability to handle high currents
Show the Answer
Question 40
A. They are too expensive for large systems
B. They lack selectivity in tripping
C. They offer too much coordination
D. They require frequent adjustments
Show the Answer
  • Difference Between MCB and MCCB
  • What are Ground Faults and Earth Faults?
  • Difference Between MCB and RCBO
  • Control Two Motors in Sequence Circuit
  • Difference Between Earth and Neutral
  • Types of Tripping Protection in MCCB
Power Systems MCQ Series 15
Control Two Motors in Sequence after Time Delay – Circuit, Operation
Synchronous Motors Power and Torque Questions
Top 10 Common Mistakes on Electrical Systems
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Why Are Neutral and Earth Separated?
Why is IGBT used in VFD?
What is a Buchholz Relay? Working Principle
What is Variable Air Volume Controller in HVAC?
Motor Maintenance, Troubles, Regular Checks, Performance
Why is White Powder Used in Electrical Cables?
Power Systems MCQ Series 4
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Industrial Drives Multiple Choice Questions and Answers
Fence grounding specifications
All About Electric Fence Gates
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
Components of Electrical Motor
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
Industrial Star Delta Starter for 3-Phase Induction Motor
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
Geothermal Energy Power Plants
Current Earth Leakage Circuit Breaker
Types of Earth Leakage Circuit Breaker
Vacuum Tubes Multiple Choice Questions and Answers
Mixing Tank Relay Circuit
PLC Program for Mixing Tank
Difference between Single-phase and three-phase power supply
Difference between Single-phase and Three-phase Power
PID control block located in fieldbus transmitter
Foundation Fieldbus Device addressing
Applications of Photo diodes
Omron PLC Mixing System
Mixing Program with Timers and Counters in Omron PLC
