Reading: MCB vs Fuse – Basic Questions and Answers for Engineers
Inst Tools > Blog > Electrical MCQ > MCB vs Fuse – Basic Questions and Answers for Engineers
Get ready for your electrical interview with this guide on MCB vs fuse. Commonly asked questions for electrical and electronics engineers.
Last updated: September 11, 2024 9:44 am
Electrical MCQ
14 Min Read
Get ready for your electrical interview with this guide on MCB vs fuse. Understand the main differences and commonly asked questions for electrical and electronics engineers.
MCB vs Fuse Basic QuestionsWhat is the basic working principle of an MCB?How does a fuse operate to protect an electrical circuit?How does an MCB differ from a fuse in terms of reusability?What is a significant advantage of MCBs over fuses in detection?Which is more reliable for long-term use, MCBs or fuses?How do MCBs and fuses compare in terms of response time?Which offers better protection against short circuits, MCBs or fuses?Which device is more cost-effective in the long run, MCB or fuse?How do MCBs and fuses differ in terms of thermal stability?In terms of maintenance, how do MCBs and fuses compare?Which device provides more precise protection settings?How do the safety features of MCBs compare to fuses?In what aspect do fuses outperform MCBs in certain applications?In terms of environmental impact, which is better, MCBs or fuses?How does the installation process of MCBs compare to that of fuses?How do the response characteristics of MCBs compare to those of fuses?What is a practical advantage of using MCBs in industrial applications?How does the reset capability of MCBs enhance their usability?Why might fuses still be used despite the advantages of MCBs?How does the physical size of MCBs compare to fuses?How does the trip curve flexibility of MCBs compare to fuses?Which device generally requires more inventory management, MCBs or fuses?How do MCBs and fuses compare in terms of response to transient currents?How does the physical construction of MCBs compare to fuses?How do MCBs and fuses differ in terms of response to gradual overloads?In terms of operational noise, how do MCBs compare to fuses?How do MCBs and fuses differ in terms of their impact on system downtime?Which device offers better integration with remote monitoring systems, MCBs or fuses?How does the response time of MCBs compare to fuses in detecting overloads?What is a major disadvantage of using MCBs compared to fuses?How does the response to short circuits differ between MCBs and fuses?What is a disadvantage of fuses in terms of long-term use?How does the magnetic trip function in an MCB work?What is a key disadvantage of fuses in terms of system downtime?How does the design complexity of MCBs compare to fuses?What is a disadvantage of using MCBs in terms of physical size?What is the impact of the thermal element in an MCB on its tripping time?What is a common limitation of fuses in high-power applications?What disadvantage does the complexity of MCBs introduce compared to fuses?What is a significant disadvantage of fuses regarding selective coordination?
Watch the video below to test your knowledge of MCB and Fuse devices. You will get detailed explanations for each question in the video.
MCB vs Fuse - Most Asked Electrical Interview Questions
Question 1
A. Hydraulic pressure
B. Mechanical relay
C. Magnetic and thermal tripping
D. Chemical reaction
Show the Answer
Question 2
A. Uses a solenoid to trip
B. Melts its internal element
C. Changes its physical state
D. Activates a mechanical switch
Show the Answer
Question 3
A. Fuses are reusable; MCBs are not
B. Both are reusable
C. Neither are reusable
D. MCBs are reusable; fuses are not
Show the Answer
Question 4
A. Fuses can detect only short circuits
B. MCBs provide clear tripping indication
C. MCBs can detect only overloads
D. Fuses provide clear tripping indication
Show the Answer
Question 5
A. MCBs are more reliable
B. Neither are reliable
C. Both are equally reliable
D. Fuses are more reliable
Show the Answer
Question 6
A. Response times vary widely for both
B. MCBs have a faster response time
C. Both have similar response times
D. Fuses have a faster response time
Show the Answer
Question 7
A. Neither offers adequate short circuit protection
B. MCBs offer better short circuit protection
C. Fuses offer better short circuit protection
D. Both offer equal short circuit protection
Show the Answer
Question 8
A. Neither is cost-effective
B. Both are equally cost-effective
C. Fuses due to low initial cost
D. MCBs due to reusability
Show the Answer
Question 9
A. Fuses offer better thermal stability
B. Neither offers thermal stability
C. MCBs offer better thermal stability
D. Both offer equal thermal stability
Show the Answer
Question 10
A. Neither requires maintenance
B. Both require the same maintenance
C. Fuses require more maintenance
D. MCBs require more maintenance
Show the Answer
Question 11
A. Both provide equally precise protection
B. MCBs due to adjustable settings
C. Fuses due to their fixed nature
D. Neither provides precise protection
Show the Answer
Question 12
A. MCBs have fewer safety features
B. Fuses have advanced safety features
C. MCBs have advanced safety features
D. Fuses have more safety features
Show the Answer
Question 13
A. Reusability
B. Reset capability
C. Cost
D. Adjustable settings
Show the Answer
Cost
Question 14
A. Fuses due to lower production footprint
B. Neither is environmentally friendly
C. Both have similar environmental impact
D. MCBs due to longer lifespan
Show the Answer
Question 15
A. MCBs are easier to install
B. Both have equally complex installations
C. Fuses are easier to install
D. Neither is easy to install
Show the Answer
Question 16
A. Neither device responds quickly
B. MCBs and fuses respond at the same speed
C. Fuses have a delayed response
D. MCBs have a delayed response
Show the Answer
Question 17
A. Faster response to overloads
B. Lower initial cost
C. Adjustable tripping settings
D. Ability to handle higher fault currents
Show the Answer
Question 18
A. Allows for quick restoration of power
B. Reduces the need for additional protection devices
C. Provides better visual indicators
D. Ensures higher breaking capacity
Show the Answer
Question 19
A. Better for high-voltage applications
B. Higher breaking capacity
C. Lower cost and simplicity
D. More reliable in all conditions
Show the Answer
Question 20
A. MCBs are generally larger
B. Neither has a standardized size
C. Both have similar sizes
D. Fuses are generally larger
Show the Answer
Question 21
A. Fuses offer adjustable trip curves
B. Neither offers adjustable trip curves
C. Both offer adjustable trip curves
D. MCBs offer adjustable trip curves
Show the Answer
Question 22
A. MCBs
B. Neither requires inventory management
C. Both require the same level of management
D. Fuses
Show the Answer
Fuses
Question 23
A. Both handle transient currents equally well
B. MCBs handle transient currents better
C. Fuses handle transient currents better
D. Neither handles transient currents effectively
Show the Answer
Question 24
A. Fuses have a more complex construction
B. MCBs have a more complex construction
C. Both have similar physical construction
D. Neither has a complex construction
Show the Answer
Question 25
A. Fuses handle gradual overloads better
B. MCBs handle gradual overloads better
C. Both handle gradual overloads equally well
D. Neither handles gradual overloads effectively
Show the Answer
Question 26
A. MCBs are noisier
B. Neither generates operational noise
C. Both generate the same level of noise
D. Fuses are noisier
Show the Answer
MCBs are noisier
Question 27
A. Neither impacts system downtime
B. MCBs reduce system downtime
C. Fuses reduce system downtime
D. Both have the same impact on system downtime
Show the Answer
Question 28
A. Both offer equal integration
B. Fuses offer better integration
C. Neither integrates well with remote monitoring
D. MCBs offer better integration
Show the Answer
Question 29
A. Fuses have a faster response time
B. Neither responds quickly
D. MCBs have a faster response time
Show the Answer
Question 30
A. Higher initial cost
B. Slower response to short circuits
C. Lack of reusability
D. Lower breaking capacity
Show the Answer
Higher initial cost
Question 31
A. Both respond at the same speed
B. MCBs respond faster
C. Neither responds quickly
D. Fuses respond faster
Show the Answer
Question 32
A. Difficult to install
B. Higher maintenance due to replacement needs
C. Complex operational mechanism
D. Limited availability
Show the Answer
Question 33
A. Relies on hydraulic pressure
B. Uses a chemical reaction
C. Activates a solenoid with high current
D. Changes the physical state of the material
Show the Answer
Question 34
A. They require resetting
B. They blow too slowly
C. They need to be replaced when blown
D. They cannot handle high currents
Show the Answer
Question 35
A. Neither has a complex design
B. Fuses have a simpler design
C. Both have equally complex designs
D. MCBs have a simpler design
Show the Answer
Question 36
A. They are too small for high currents
B. They require additional cooling systems
C. They are difficult to install
D. They are larger and take up more space
Show the Answer
Question 37
A. It causes an instant trip
B. It delays the tripping
C. It prevents the MCB from tripping
D. It has no impact on tripping time
Show the Answer
Question 38
A. They have a high initial cost
B. They are too large for compact systems
D. They cannot be reset
Show the Answer
Question 39
A. Increased risk of failure
B. Reduced durability
C. Inability to handle high currents
D. Higher cost and potential for mechanical issues
Show the Answer
Question 40
A. They lack selectivity in tripping
B. They require frequent adjustments
C. They are too expensive for large systems
D. They offer too much coordination
Show the Answer
  • Power System Protection Questions
  • Difference Between MCB and MCCB
  • Automatic Motor START and STOP
  • Electrical Engineer Objective Questions
Electrical Machines MCQ Series 6
Top 200 Electrical Engineers Objective Questions and Answers
Electromagnetic Field MCQ
Rotating Machines Objective Questions
Electrical Machines MCQ Series 2
Electrical Machines MCQ Series 1
Electric Circuits Objective Questions – Set 2
Induction Motor Phasor Diagram
Starting of Polyphase Induction Motors Quiz
100 Electrical Circuit Breaker Quiz
Electrical Machines MCQ Series 20
Batteries MCQ – Multiple Choice Questions
Components of MCB
Components of MCB – Electrical Engineering Questions
Induction Motor Rotor EMF, Current and Power
Alternators Multiple Choice Questions
Electric Circuits Objective Questions – Set 9
Electrical Switch Questions and Answers
Top 50 Electrical Switch Questions and Answers
DC Machine Quiz
Electromagnetic Field Theory Questions and Answers
Power Systems MCQ Series 7
Loop Powered Pressure Transmitter
PLC Program for Food Processing
PLC Program for Food Processing Industry
Parallel RLC Circuit
Resonance, Resonant Frequency, Series and Parallel Resonance
Transistor as Switch Working Animation
How a Transistor Switch Works
Impulse Line Purging and Close Coupling
Impulse Line Purging and Close Coupling of Instruments
Pulse Width Modulation Inverters Questions
Types of Fire Detectors
